[Plugin] FredoTools - v4.0a - 17 May 20
Re: [Plugin] FredoTools - v3.2c - 12 Mar 18
Postby JQL » Mon Apr 09, 2018 11:36 pm
fredo6 wrote:By the way, if you are lucky to have 'ill-edged' models, I am interested for testing EdgeInspector.
What exactly are we supposed to find in these models?
User avatar
JQL
Premium Member
Premium Member
Postby fredo6 » Tue Apr 10, 2018 7:14 am
Tiny edges, needle eyes, etc....
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] FredoTools - v3.2d - 09 Apr 18
Postby Areczan » Mon May 14, 2018 3:21 pm
Hi, I'm struggling with the following error. Seems like there's some problem between Fredo Tools and V-ray. I had to reinstall Sketchup and made sure I installed it with "Run as Administrator". Repair function doesn't help either...
Error: #<ArgumentError: wrong number of arguments (0 for 1)>
c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:158:in `initialize'
c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:in `new'
c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:in `show'
c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:66:in `time_for_check?'
c:/users/am/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:377:in `block in after_startup'
C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `call'
C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require'
C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb:1:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in `load'
C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:26:in `register_extension'
C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:26:in `<module:VRay>'
C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:4:in `<top (required)>'
Areczan
Postby fredo6 » Tue May 15, 2018 7:40 am
Areczan wrote:Hi, I'm struggling with the following error. Seems like there's some problem between Fredo Tools and V-ray. I had to reinstall Sketchup and made sure I installed it with "Run as Administrator". Repair function doesn't help either...
Do you have the problem if you disable VRay?
User avatar
PluginStore Author
PluginStore Author
Postby Areczan » Thu May 17, 2018 2:13 pm
No. But there's also no problem when I only disable Fredo Tools.
Areczan
Postby fredo6 » Thu May 17, 2018 4:00 pm
Areczan wrote:No. But there's also no problem when I only disable Fredo Tools.
It's probably a conflict between Plugin (although I don't have it on my machine with VRay 3.6). So removing one or the other should eliminate the issue.
User avatar
PluginStore Author
PluginStore Author
Postby bharralure » Mon May 28, 2018 9:32 am
Bonjour Fredo
Je viens de découvrir un petit problème avec les outils "Volume Solides" et "Étiqueter les Surfaces"(SketchUp Pro 2018).
Je ne peut plus sélectionner les valeurs affichées dans la boite de dialogue, pour les copier (Ctrl + C). Il me semble que le problème soit lié à la dernière mise à jour de Lib Fredo6 (v8.4d). En effet, je ne rencontre pas le problème dans SU Make 2017 que je n'ai mis à jour.
C'est un problème mineur, mais si il existe une solution pour y remédier, je vous en serais très reconnaissant.
bharralure
Postby fredo6 » Mon May 28, 2018 11:40 am
bharralure wrote:Bonjour Fredo
Thanks for signaling. I identified it and will publish an update to fix it.
User avatar
PluginStore Author
PluginStore Author
Postby xroo2 » Fri Sep 07, 2018 8:48 pm
When I download the .rbz file...it comes in as a PDF. What's up wtih that?
-1
xroo2
Postby Gábor » Mon Sep 10, 2018 9:24 am
xroo2 wrote:When I download the .rbz file...it comes in as a PDF. What's up wtih that?
Where did you download it from? Try from here: https://sketchucation.com/pluginstore?pln=FredoTools
Gábor
SketchUcation IT
Postby Pixero » Mon Sep 10, 2018 10:15 am
Maybe you have accidently chosen that rbz files shall open with Acrobat? In that case right click and open with and set it to always open .rbz with SketchUp instead.
User avatar
Pixero
Postby xroo2 » Mon Sep 10, 2018 6:54 pm
..found out that it is just my computer which inserts Adobe icon and suffix for 'whatever' reason. The .rbz file opens find through Extension Manager :?
xroo2
Re: [Plugin] FredoTools - v3.3a - 21 Oct 18
Postby fredo6 » Sun Oct 21, 2018 8:09 pm
NEW RELEASE: FredoTools v3.3a - 21 Oct 18
Requirement: LibFredo6 v8.6i or above
FredoTools 3.3a fixes bugs in FredoTools::ReportLabelArea.
See FredoTools plugin home page for Download.
See also main post of this thread for User Discussion.
User avatar
PluginStore Author
PluginStore Author
Postby Pascalou54 » Thu Oct 25, 2018 7:19 am
Bonjour,
J'ai toujours une erreur sur SU2017,
"erreur de chargement du fichier Fredo6_FredoTools/__loader__FredoTools
Could not find included file 'Fredo6_FredoTools/__loader__FredoTools"
Dans quel répertoire doit on mettre \Fredo6_FredoTools_-_v1.8c ?
merci
Pascalou54
Postby pilou » Thu Oct 25, 2018 10:45 am
Il vaut mieux utiliser le Ruby rouge pour installer les plugins, comme cela aucun problème de savoir où il faut les installer, dans quels répetoires etc...dans cette jungle de windose! :mrgreen: (bouton rouge "Installer l'Extension" (bas de page)
Il faut installer aussi la dernière Fredo Lib avant! :ugeek: (avec le même Ruby rouge! ;)
Toujours avec le Ruby rouge, il vaut mieux dé-installer les anciennes versions des plugins à venir avec la section "Gérer"! (haut de page)
Speedy Galerie
User avatar
Top SketchUcator
ThruPaint and orbiting - problem!
Postby dedmin » Tue Dec 04, 2018 10:38 am
See the video. Windows 10, SU Pro - all up to date.
https://imgur.com/a/jyUEA0P
dedmin
Re: ThruPaint and orbiting - problem!
Postby fredo6 » Wed Dec 05, 2018 3:52 am
dedmin wrote:See the video. Windows 10, SU Pro - all up to date.
This is fixed in LibFredo6 8.6n, just published.
User avatar
PluginStore Author
PluginStore Author
Postby dedmin » Wed Dec 05, 2018 5:14 am
Thanks, Fredo.
dedmin
Report on Areas - Export CSV problem
Postby masloprojekt » Thu Mar 14, 2019 4:31 pm
First of all, a great plugin, the reporting part is probably the only one and the best one available. However, I encountered a problem while using it. I generated a space report sorted by Container. Group of components, components are simple planes. The report looks good and contains correct data, but unfortunately when I try to export to CSV I get a file containing only some kind of the header. There is also no popup confirming the correct export. Has anyone encountered such a problem?
masloprojekt
Re: Report on Areas - Export CSV problem
Postby fredo6 » Thu Mar 14, 2019 6:55 pm
masloprojekt wrote:First of all, a great plugin, the reporting part is probably the only one and the best one available. However, I encountered a problem while using it. I generated a space report sorted by Container. Group of components, components are simple planes. The report looks good and contains correct data, but unfortunately when I try to export to CSV I get a file containing only some kind of the header. There is also no popup confirming the correct export. Has anyone encountered such a problem?
I guess you talk about the ReportLabelArea tool.
There is a small bug, which exists only for the views by Container and by Layer.
I have fixed them and will republish soon.
PS: this should only happen when the unit contains a square exponent.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] FredoTools - v3.3b - 14 Mar 19
Postby fredo6 » Thu Mar 14, 2019 7:05 pm
NEW RELEASE: FredoTools v3.3b - 14 Mar 19
FredoTools 3.3b fixes bugs in FredoTools::ReportLabelArea for CSV export, as signaled by masloprojekt.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] FredoTools - v3.3c - 24 Mar 19
Postby fredo6 » Sun Mar 24, 2019 10:21 pm
NEW RELEASE: FredoTools v3.3c - 24 Mar 19
FredoTools 3.3c fixes bugs in FredoTools::EdgeInspector preneting it to work in SU2019.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] FredoTools - v3.4a - 12 Apr 19
Postby fredo6 » Sat Apr 13, 2019 1:58 am
NEW RELEASE: FredoTools v3.4a - 12 Apr 19
FredoTools 3.4a improves performance when the Outliner is open. This may be important for ThruPaint, when you paint a complex model.
User avatar
PluginStore Author
PluginStore Author
Postby miguelgba » Sat Apr 27, 2019 1:23 pm
Hi Fredo, Your Plugin is simply one of the best and most usefull of Sketchup. But I have a request, the ReportLabelArea (report) is not exported in a CSV format that the Layout of Sketchup can read, every time I tried to copy and paste the .csv into layout it give me a blank table. I'm trying to use your plugin to make a quantity takeoff and insert the table on Layout, if this turns into possible and practical will be a wonder to my tries to use de Layout for construction drawings.
Thanks in advance
miguelgba
Postby Dave R » Sat Apr 27, 2019 1:53 pm
miguelgba wrote:the ReportLabelArea (report) is not exported in a CSV format that the Layout of Sketchup can read, every time I tried to copy and paste the .csv into layout it give me a blank table.
Open the CSV file in a spreadsheet program such as Excel and save it as XLSX or make it an RTF file. Both of these file types are supported by LayOut.
Additionally, you shouldn't copy and paste files into LayOut. The reference that is created with copy and paste links to a temporary file location which will be removed when the operating system does its normal cleanup. You should use File>Insert and insert the file from its real location.
User avatar
Global Moderator
Postby Wise Vast » Sun Apr 28, 2019 6:53 pm
I had installed libfredo v8.8a. And then, I install the fredotools v3.4a. I cannot find any tools, although extension manager shows that fredotools had been installed.
Wise Vast
Postby TIG » Mon Apr 29, 2019 12:45 pm
Have you restarted SketchUp following the installations ?
That will ensure everything gets properly synced...
Also, are you looking in the right places ?
Many of Fredo's tools have their own Toolbar.
And most of them also appear under SketchUp's "Tools" menu - in large submenus - "Fredo Tools" and "Fredo6 Collection"...
User avatar
Global Moderator
Postby ardesigninterior » Sat May 04, 2019 5:27 am
Thanks for the Plugin by Fredo6. it is awesome to help my works.
ardesigninterior
Postby designerbursa » Mon Jun 03, 2019 8:41 pm
Can you add a command that shows the external dimensions of the solid part?
User avatar
designerbursa
Postby designerbursa » Mon Jun 03, 2019 8:46 pm
solid volume command. It would be nice to have a report window that shows the dimensions of the part I selected on the screen.
User avatar
designerbursa
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: Cimborrio, jankovicplanung, ovelhanegra, tampaalmeida, yosmanyalonso and 7 guests
Visit our sponsors:
