MS Physics and SU 2019
Moderator: CPhillips
Postby Pixero » Wed Feb 27, 2019 8:41 am
Does MS Physics work with SU 2019?
I get error messages when loading it.
11
User avatar
Pixero
Re: MS Physics and SU 2019
Postby samnorth » Wed Feb 27, 2019 11:19 am
I got errors at startup too. I disabled it for now as i don't use it very often.
6
samnorth
Premium Member
Premium Member
Postby Anton_S » Thu Feb 28, 2019 4:27 am
Pixero wrote:Does MS Physics work with SU 2019?
No it doesn't work with 2019 as of yet.
Anton_S
PluginStore Author
PluginStore Author
Postby Eric Shively » Sun Sep 22, 2019 1:13 am
I don't get error messages, it just doesn't show up when I download it. :?
Eric Shively
Postby alvin meza » Wed Oct 23, 2019 3:35 pm
lastimosamente no corre en 2019 es una pena considerando el potencial del pluguin esta revisando continuamente para ver si se resuelve el problema...
alvin meza
Postby LEGOsketcher » Thu Nov 14, 2019 10:55 am
Only works for SU 2017. Is there an update in scope or do you know of a similar plugin to drop stuff at random in a basket for example? Really hope for a 2019 update - such an awesome plugin.
LEGOsketcher
Postby veyslk » Wed Nov 27, 2019 6:07 pm
When will MSPhysics SU2019 work. Year is over.
veyslk
Postby Sisu » Sun Jan 26, 2020 1:11 pm
Has there been any movement on this? Would love to use it in SU2020.
Sisu
Premium Member
Premium Member
Postby nesztler » Wed Apr 29, 2020 4:47 pm
Hi All,
MSPhysics works well for me !
For that, you must put the MSPhysics directory and MSphysic.rb directly in the library directory of SKetchup 2019. Futhermore, you must add AMS_library 3.5.0 + with the extension manager.
if you have any difficulties, ask to me and i answer you
Best regard
Thierry
nesztler
Postby dandrak37 » Mon May 04, 2020 3:03 am
nesztler wrote:Hi All,
Best regard
Thierry
Hi Thierry,
Do we need to install first the library? or it doesn't matter the order of installation.
Thanks in advance,
Jose Castellot
dandrak37
Postby carsanl5 » Sun May 24, 2020 3:50 pm
Best regard
Thierry
Hey, could you let me know the exact route where you paste it ?i'm pretty nooby at this, also, do you copy the MSPhysics.rbx ?
thanks in advance!
carsanl5
Postby asd123dsa » Mon Aug 17, 2020 5:41 am
I can't load
asd123dsa
Postby KadirSket » Wed Nov 11, 2020 11:17 am
2020 ?
KadirSket
Postby Jiivandev » Mon Apr 19, 2021 1:10 pm
Hello
I am new on MSPhisics and still using SU 2019. Already tryed to install first AMS Library and MSPhisics by using "Install extension" and and locate the file .rbz in the plugin Folder.
The plugin after installation seems are installed but alway this message:
Error Loading File C:/Users/Giuseppe.-------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb
Error: #<IOError: The required, staged c extension file, "C:/Users/Giuseppe.-------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/libraries/stage/win64/2.5/msp_lib.so", is missing!>
C:/Users/Giuseppe.---------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:in `block in require_all'
C:/Users/Giuseppe.-------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in `each'
C:/Users/Giuseppe.--------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in `require_all'
C:/Users/Giuseppe.--------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main.rb:70:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in `require'
C:/Users/Giuseppe.--------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in `load'
C:/Users/Giuseppe.-------------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in `register_extension'
C:/Users/Giuseppe.---------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:21:in `<module:MSPhysics>'
C:/Users/Giuseppe.------/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb:5:in `<top (required)>'.
Any one have suggestions ?
What's going one ?
Thank's
Giuseppe
Jiivandev
Postby Dave R » Mon Apr 19, 2021 2:04 pm
If you read through this thread you will see that the author has indicated it doesn't work in SketchUp 2019. See:
viewtopic.php?f=61&p=669802#p646407
As of this date it has not been updated to work with SketchUp 2019 or newer.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchyPhysics
cron
Who is online
Users browsing this forum: No registered users and 2 guests
Visit our sponsors:
