[Plugin] AMS Library 3.6.0h (15 Nov 2018)
Re: [Plugin Tool] AMS Library 3.2.1 (Mar 30, 2016)
Postby Anton_S » Tue Apr 05, 2016 6:52 am
Ok I am able to reproduce it with Spanish localization. I even get frozen strings errors, which I have no idea what's causing them and how to prevent them. I will look into into it and do my best to fix it.
Anton_S
PluginStore Author
PluginStore Author
Re: [Plugin Tool] AMS Library 3.2.2 (Apr 05, 2016)
Postby Anton_S » Tue Apr 05, 2016 12:14 pm
Hi perecollo2000. Try the new version. I think it should be fixed now.
Anton_S
PluginStore Author
PluginStore Author
Postby perroloco2000 » Tue Apr 05, 2016 10:59 pm
hi Anton .... YOU SOLVED IT!!!
100% working, thank you very much for your work, and quick reply
your plugins really help my work on the laptop screen
great autor, thanks
perroloco2000
Postby pnickles » Thu Apr 07, 2016 4:35 pm
Forgive me but I'm a newb who can barely work his way through/around Extensions.
I'm unable to get the MSphysics to load/run. It is registered under Plugins but I receive the following message when I open Sketchup2016. I've tried copying/pasting the "main.rb" file into every imaginable Plugin folder but it still fails to see/find the file.?
(I installed the AMS Library v3.2.2 AFTER I installed the MSphysics extension but the order of installation shouldn't matter, correct?)
I'm running Win8 via Parallels, SU2016.
pnickles
Premium Member
Premium Member
Postby Anton_S » Fri Apr 08, 2016 7:48 am
Pnickles, you got it into the correct plugins folder, but placed the content improperly.
I suggest deleteding whatever you placed in the plugins folder manually (including MSPhysics which is placed improperly based on your screenshot) and starting over with the following instructions. Download ams_Lib_3.2.2.zip, extract it, and place ams_Lib folder and ams_Lib.rb file into the plugins folder. Same applies to MSPhysics_0.5.0.zip. It should look something like this:
Anton_S
PluginStore Author
PluginStore Author
Postby pnickles » Fri Apr 08, 2016 5:36 pm
Different error messages now. See attached. Perhaps it's because I'm running Win8 via Parallels?
pnickles
Premium Member
Premium Member
Re: [Plugin Tool] AMS Library 3.3.0 (July 10, 2016)
Postby Bryan K » Sat Jul 16, 2016 4:57 am
Are there how to use instructions somewhere?
User avatar
Postby Anton_S » Sat Jul 16, 2016 11:06 am
Bryan, in case you're wondering if it's a plugin, well it's not. AMS library is more of a dependency for a few of my other plugins.
Anton_S
PluginStore Author
PluginStore Author
Postby wikii » Sat Jul 16, 2016 2:40 pm
How to get the version number?
AMS.ver ?
wikii
PluginStore Author
PluginStore Author
Postby Anton_S » Sat Jul 16, 2016 5:16 pm
Use AMS::Lib::VERSION It returns a string like "3.3.0".
Anton_S
PluginStore Author
PluginStore Author
Postby Bryan K » Sat Jul 16, 2016 6:52 pm
Anton_S wrote:Bryan, in case you're wondering if it's a plugin, well it's not. AMS library is more of a dependency for a few of my other plugins.
Thanks Anton, but what I'm looking for is how to use it. It's installed without a problem but I need some kind of instructions or tutorial on how to use the controls.
Thanks.
User avatar
Postby Anton_S » Sun Jul 17, 2016 7:20 am
The first post contains a link to the library's documentation. I not particularly sure if that's what you desire though.
Anton_S
PluginStore Author
PluginStore Author
Re: [Plugin Tool] AMS Library 3.4.0 (31 October 2016)
Postby Bryan K » Thu Nov 03, 2016 7:51 am
Anton, thanks. I found some great video tutorials. https://www.youtube.com/user/samketner/ ... shelf_id=0
My new problem is that the UI menu is not displaying correctly nor or the contents.. There are no tabs and the menu window is not resizable so I cannot access the contents at the bottom of the screen.
Here is a screen shot.
Any ideas?
User avatar
Re: [Plugin] AMS Library 3.5.0 (9 July 2017)
Postby ladyquestio » Sun Jul 16, 2017 10:01 pm
I keep getting this error. What is happening?
ladyquestio
Postby Anton_S » Mon Jul 17, 2017 12:04 am
Hmm. I'm not getting any errors in my SU8. Are you using the latest versions of both plugins? If not, try completely removing both and installing once again.
Edit: Actually I'm getting a similar error when I attempt to start MSPhysics simulation in SU8. I haven't been able to determine the cause, so try sticking to SU2013+.
Edit: I will ensure the compatibility with SU version prior to 2013 at some point.
Anton_S
PluginStore Author
PluginStore Author
Re: [Plugin] AMS Library 3.5.1 (17 July 2017)
Postby ladyquestio » Sun Jul 23, 2017 3:55 pm
Anton:
I removed all the files as per instruction. Defragged the HD. then reloaded SU8 . I have a video of what happens.
Watch and see. then Tell me what I did wrong.
https://youtu.be/nUL87J2N79A
ladyquestio
Re: [Plugin] AMS Library 3.5.2 (25 July 2017)
Postby Anton_S » Tue Jul 25, 2017 8:33 am
Sorry, I forgot to test it on Windows XP. It should be fixed now. Upgrade to AMS Library, version 3.5.2.
Anton_S
PluginStore Author
PluginStore Author
Re: [Plugin] AMS Library 3.6.0h (15 Nov 2018)
Postby GalvinHRO » Thu Feb 14, 2019 5:20 pm
with the AMS library i can get the name of the default tray but not the object itself or the child dialogs like "Materials" or "Entity Info" anybody knows if this feature exist or a workaround. If not is it possible to make one with the win32API?
GalvinHRO
Postby Anton_S » Sat Feb 16, 2019 7:53 am
Galvin,
The Tray window structure in SU2018 is as follows:
Provided that you have the handle of the tray, you can then obtain the first two levels of child windows, and then iterate through all windows of that child window to get all the dialogs.
With AMS Library, you can use the following function to get all trays:
Code: Select all
trays = AMS::Sketchup.get_active_dialogs.find_all { |handle|
  AMS::Window.get_class_name(handle) =~ /Afx:MiniFrame/i
# => [133134]
Then once you have the trays, you can get the first two levels of child windows:
Code: Select all
trays.each { |tray|
  c1 = AMS::Window.get_related(tray, 5) # GW_CHILD
  next unless c1
  c2 = AMS::Window.get_related(c1, 5) # GW_CHILD
  next unless c2
  dialogs = AMS::Window.get_child_windows(c2, false, false)
  panes = dialogs.find_all { |dialog|
    AMS::Window.get_class_name(dialog) =~ /CPanelHeader/i
  panes.each { |pane|
    # First child window contains pane caption
    c3 = AMS::Window.get_related(pane, 5) # GW_CHILD
    next unless c3
    puts AMS::Window.get_caption(c3)
# => Layers
# => Shadows
# => Fog
# => Materials
# => Soften Edges
# => Styles
# => Entity Info
Note that this will not work with sketchup versions prior to 14.
Anton
Anton_S
PluginStore Author
PluginStore Author
Re: [Plugin] AMS Library 3.6.0h Does not work with Mac
Postby Headcase6969 » Tue Jul 02, 2019 2:21 pm
Mac=NOPE!
Headcase6969
Re: [Plugin] AMS Library 3.6.0h Does not work in SU 2019
Postby April Zylith » Wed Apr 15, 2020 10:32 am
MSPhysics_v1.0.3 does not work on SU 2019.
What should I do?
System:
OS: Windows 10 Pro 64 bit.
App: Sketchup Pro 2019 64 bit.
April Zylith
Postby Dave R » Wed Apr 15, 2020 1:18 pm
April Zylith wrote:MSPhysics_v1.0.3 does not work on SU 2019.
What should I do?
You're right. It doesn't work. What can you do? Be patient. The author has been working on an update and will release it when it is ready.
User avatar
Global Moderator
Postby young77 » Fri Nov 27, 2020 7:23 pm
Hi...
I just want to make sure is this plugin doesnt work for sketchup 2021 ?
is there any possible way to make this enable to run in skp 2021 ?
thanks,
Hp
young77
Postby pipinek » Fri Jan 15, 2021 1:17 am
young77 wrote:Hi...
thanks,
Hp
Splendid plugin,
any updates for SSU 2021. Even paid?
Thank you in advance if any
pipinek
Premium Member
Premium Member
Postby qifu123 » Wed Jan 20, 2021 11:24 am
I need some help, AMS Library 3.6.0h In sketchup 2021 error
载入文件 C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/main.rb 时出错
Error: #<IOError: The required, staged c extension file, "C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/libraries/stage/win64/2.7/ams_lib.so", is missing!>
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:in `block in require_all'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in `each'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in `require_all'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/main.rb:148:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in `load'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib.rb:32:in `register_extension'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib.rb:32:in `<module:Lib>'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib.rb:7:in `<module:AMS>'
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib.rb:5:in `<top (required)>'
qifu123
Postby pibuz » Mon Feb 08, 2021 9:29 am
Same here. AMS lib is not compatible with SU2021, or so it seems..
It's a pity.. :(
pibuz
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: 83cino, Boghdan, hashik30, johnim, kaoru_komine, kotikplus and 23 guests
Visit our sponsors:
