Ruby Component Insertion and Attributes - Not Updating
Hi all,
I hope this is the right forum to post this in.
I am pretty new to making my own Ruby scripts, so I'm not sure how to do this.
I have some dynamic components I have made, and exported them out of the model as their own .skp files. I want my script to get two points from the user, then load and insert the component at the point specified by the first click, scale it along one axis, then rotate it into position so the second end is at the point specified by the second click. There is also I prompt for the user to set certain values, which are then applied to attributes on the component, as well as the geometry changed.
I have everything working more or less perfectly, with one exception: While the attributes are set on the component, the geometry and textures are not updated on the model until I either edit the components properties manually, or scale it manually.
How would I go about having Ruby update the appearance of the component after all the attributes are changed?
Here's a truncated version/snippet of what I have:#load the file newcomp_def = Sketchup.active_model.definitions.load("Q:\Test.skp") #create insertion transform trans1 = Geom::Transformation.new p1 #transform scale along y to correct size trans2 = Geom::Transformation.scaling p1, 1, (length/12), 1 #move the box over since in my model it's centered and I want it on edge scootvec = Geom::Vector3d.new (width/2),0,0 #create transform from vector trans3 = Geom::Transformation.translation scootvec entities = Sketchup.active_model.active_entities #insert component at point 1 instance = entities.add_instance newcomp_def, trans1 #scale it to length instance.transform! trans2 #move it over by half instance.transform! trans3 #rotate it to the correct angle instance.transform! transrot #set attributes instance.set_attribute("dynamic_attributes", "product", "Name") instance.set_attribute("dynamic_attributes", "width", width) instance.set_attribute("dynamic_attributes", "depth", depth)
I have formulas on the component to set the textures, x and z dimension, etc. I have confirmed the values are changed by going into the component editor, the appearance just doesn't change/isn't updated.
Is it simple to accomplish this?Thanks!
PlacidFury
After the changes you need to force it to regenerate...
Something like this:def self.dc_redraw(ent, pbar_visible=true, undo=false) ldc = $dc_observers.get_latest_class() if undo ldc.method(:redraw_with_undo).call(ent, pbar_visible) else ldc.determine_movetool_behaviors(ent) DCProgressBar::clear() ldc.method(:redraw).call(ent, pbar_visible) DCProgressBar::clear() ldc.refresh_dialogs() end Sketchup.active_model.active_view.refresh rescue TypeError => e # suppress nil to float conversion error that happens # when redraw is called directly with true 2nd arg ? end#def
Then at the end of your changes use:
self.dc_redraw(instance, true, false)
Perfect! Got it going. Thanks!
Thanks TIG for the redraw DC code.
However I have a question about the speed of the redraw.
For my testing DC component that is fairly simple (a window) it takes approximately 4 to 10 seconds to redraw.
Is that normal?
Is there any way of speeding it up?Edit:
Here are a few more times for redraw the same DC.
5.579584 seconds to redraw
5.536248 seconds to redraw
4.532769 seconds to redraw
4.360298 seconds to redraw
4.269832 seconds to redraw
9.777517 seconds to redraw -
No one knows anything about this?
If anyone is interested I tried with this code and it's almost instant.
#Redraw to update the DC dcs = $dc_observers.get_latest_class dcs.redraw_with_undo(cinst)
Just now saw this - I have been unable to get a batch redraw of DC's to not take significant time. It seems the more DC's you redraw in the same operation, the longer each successive one takes to redraw.
Eventually, I found a way around this by simply scrapping my usage of DC's and switching to groups. Operations on groups are essentially instantaneous.
I'd use DC's if it's one or few objects at a time, or something I want the user to be able to interact with via the DC interface, but most of my plugin's objects are not that - I'm manipulating them with my code. Since I'm doing Engineered Wood Products layouts on very large multifamily buildings, I end up with thousands of objects to manipulate, and DC's simply didn't work well enough, as they were too slow. And the fact that even changing one property - even one that doesn't affect geometry - forces you to have to redraw them each, that time involved was a deal-breaker.
