[Plugin Library] LibFredo6 - v14.3b - 31 Mar 24
Is it for all popup dialog boxes ?
I have loaded this plugin but my Fredo tools don't work. I get several prompts on opening SketchUp. According to the Plugin Manager I have the latest plugin.
Seems to be something quite old, because there is no longer a reference to LibFredo6 6.3 in the latest version of my plugins. Can you check for TopoShaper.
Also, ff you run LibFredo6 8.7a, could you send me the trace file (Windows > Library Settings > Trace Log File...
Another user has signaled me an anomaly with popup messages.Thanks
I choose "View Trace Log Files..." and nothing happens. Let me try updating. I know most plugins are recent updates, but some like TopoShaper may not be.
hmm... check for updates doesn't work either.
Same problem as Oxer. You are on Mac, and there seems to be a problem with Web dialog boxes.
Since you have FredoTools installed, could you check if
- the Quick Launcher works
- if Solid Volume displays a dialog box
Ok updating several Fredo6 plugins allows me to open without prompts and FredoTools and Fredo Collection seem to be in place as before!
Still when I choose "View Trace Log Files..." sometimes a window flashes on and off but nothing else happens.
FredoTools Launcher doesn't do anything.
Solid Volume flashes a window briefly. -
Yes, have you probe anther options like Defaults Options..., Translate Language.., etc?
To me, with all these options the popup window appear and disappear immediately.macOS High Sierra 10.13.6 & SU2017
I have Safari 12.0.2 (13606.3.4.1.4)
NEW RELEASE: LibFredo6 v8.7d - 20 Dec 18
LibFredo6 8.7d fixes a major bug preventing dialog boxes to display on MAC
[quote="fredo6"]NEW RELEASE: LibFredo6 v8.7d - 20 Dec 18
...Just installed an on windows, the dialog box for Convexify refused to show. :[
Can we have access to 8.7a again? I've searched absolutely every where I can't find it, 8.7d broke Windows dialog boxes. Thanks!
Thanks Fredo for the help! (I just haven't got back to checking this last one.)
Fredo,
I can not install Cruviloft! This is the error:
Curviloft: This plugin requires LibFredo6 version greater than 68.
Current version is 75.I couldn't find a higher version of LibFredo. What should I do?
Thank you so much.Alireza
@alirezakharazmi said:
Fredo,
Current version is 75.I think the message is that you require LibFredo6 v8.6, and you have an old version (v7.5).
So just upgrade LibFredo6.
I fixed it with LibFredo6 v8.7e.
NEW RELEASE: LibFredo6 v8.7e - 01 Jan 19
LibFredo6 8.7e fixes a major bug preventing some dialog boxes to display
NEW RELEASE: LibFredo6 v8.7f - 10 Jan 19
LibFredo6 8.7f fixes a major bug preventing Animator to generate videos with recent versions of FFmpeg
