[Plugin Library] LibFredo6 - v14.3d - 21 Apr 24
@dave r said:
@rheeeeeeeee said:
hello im having trouble with installing all your rubies..
my sketchup version is 2018 and in extension manager, your file all goes 'unvalid signature'Invalid Signature doesn't indicate there are any problems with the extension. It only means it hasn't been "signed" by the extensibility folks at SketchUp. It has nothing to do with the functionality of the extension.
All my plugins are duly signed and scrambled by the Extension Warehouse.
So there must be something else.
hi Fredo6,
I have downloaded the latest version of fredo6 animator and the library. I am coming up with an issue I think. I have transitioning parts in my model, I select where my model starts transitioning from. However the origin of where my model is transitioning from keeps changing.
Is there something I would need to adjust in my model?
I very much appreciate your help! -
@lionroar41 said:
hi Fredo6,
I very much appreciate your help!It s difficult to avise without the model. Could you please post it.
Also, there is a dedicated subforum for Animator.
The best would be that you open a new thread with your problem there.
NEW RELEASE: LibFredo6 v8.6i - 21 Oct 18
LibFredo6 8.6i is for bug fixing and FredoTools 3.3a.
I have problems with all fredo6 plugins
Have Sketchup 18 pro, uses sketchup extension manager to install
all plugins are updated and are in the same directory.
When I press an icon, it does not respond. Do not get menu and no selections around the object.
Someone who can help me. -
NEW RELEASE: LibFredo6 v8.6j - 30 Oct 18
LibFredo6 8.6j is for bug fixing and small GUI adjustments (size of toolbar icons for high-DPI screens).
NEW RELEASE: LibFredo6 v8.6k - 03 Nov 18
LibFredo6 8.6k provides new instructions for downloading FFmeg on Mac-OS platforms.
IMPORTANT: the previous documentations included a link that is no longer supported and, worse, may have been hacked. So if you use Animator, please use the new link,
https://www.ffmpeg.org/download.htmlAttached are the new PDF instructions
How does one update LibFredo6? Do I have to delete and reinstall?
NEW RELEASE: LibFredo6 v8.6m - 18 Nov 18
LibFredo6 8.6m is for Animator 2.3c (transparent background) and for the size of icons on hi-res screens.
NEW RELEASE: LibFredo6 v8.6n - 05 Dec 18
LibFredo6 8.6n fixes occasional problems in Orbiting, in FredoTools::ThruPaint and possibly in some others of my plugins.
NEW RELEASE: LibFredo6 v8.6p - 05 Dec 18
LibFredo6 8.6p fixes a random bug in Animator when using Movement Along Path.
NEW RELEASE: LibFredo6 v8.7a - 18 Dec 18
LibFredo6 8.7a is a maintenance release providing adjustments to several of my plugins.
Hi Fredo,
I installed the last version of LibFredo v8.7a, there is an issue, I can't access to your plugins through the icons, it appears the options window and it disappears immediately. When I access through plugins Menu or Contextual Menu they work.
When the tool (ex. JointPushPull) is running and I push the Tool Settings icon it happens the same, the settings window appears and it disappears immediately.macOS 10.13.6 & SU2017
@oxer said:
Hi Fredo,
Can you open the Ruby Console.
Do you have the problem with the button palette of my plugins (like JointPushPull or FredoCorner) or is it just for the dialog boxes?
Nothing in Ruby Console.
I open for example Window Menu> LibFredo Options> Check Updates for Plugins and the window appears but it closes immediately.EDIT: After that I can use another Skechup Tools but if I press Cmd+Q (exit SU on Mac) SketchUp doesn't close, I have to force the exit.
It's with the dialogs (popup windows) only, the palletes works fine.
How I said you before to access to yours plugins I can do this through the Tool & Extensions Menu or Contextual Menu only. -
Is it for all popup dialog boxes ?
I have loaded this plugin but my Fredo tools don't work. I get several prompts on opening SketchUp. According to the Plugin Manager I have the latest plugin.
Seems to be something quite old, because there is no longer a reference to LibFredo6 6.3 in the latest version of my plugins. Can you check for TopoShaper.
Also, ff you run LibFredo6 8.7a, could you send me the trace file (Windows > Library Settings > Trace Log File...
Another user has signaled me an anomaly with popup messages.Thanks
