Flowify problems
Flowify problems
Postby taydavid03 » Sat Nov 17, 2018 11:23 am
Hey guys,
Tried using Flowify and it just couldn't work.
I created 3 separate groups (including the 2 connecting lines) and grouped them within a larger group (total 4 groups).
And still no results.
I must mention that I did not use the impose grid function within Flowify and created my own objects.
Would appreciate some help.
I have attached the sketchup file in question.
taydavid03
Re: Flowify problems
Postby pilou » Sat Nov 17, 2018 1:00 pm
Seems you have not understand how works Flowify! :)
You must have a base surface (C) under your object (E) to project!
Speedy Galerie
User avatar
Top SketchUcator
Postby taydavid03 » Sun Nov 18, 2018 1:27 pm
pilou wrote:Seems you have not understand how works Flowify! :)
Hi Frency, thanks for your response.
I am one step closer to getting this right. I did everything you asked me to.
However, when I tried it, it gives me this response :
Input Error : Error while parsing the Target grid.
The grid must conform to :
- A cell consists of exactly four edges. Beware of collinear edge segments
- The grid mus thave four corners
- Every row int he grid must have the same number of cells
- No holes
What do you think I am doing wrong?
taydavid03
Postby pilou » Sun Nov 18, 2018 7:33 pm
your start object must be a simple group (don't take group of groups so explode all to level 0 then group) :ugeek:
-1
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Sun Nov 18, 2018 8:17 pm
I took your file but with a little changement! :)
Always use the Hidden geometry for validate your choice! ;)
Will work but in a little big time! Because your start object is very dense!
And little deformations on the extremities due difference of segmentation!
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Mon Nov 19, 2018 1:57 am
But before use the Curviloft by Fredo , use other Tools by Fredo for transform your 4 curves of the ending surface! (Bezier tools (?) )
Don't touch the 2 verticals (depend of number of segments you want but as it's vertical straight lines...)
Transform Curve in PolyLine (Right Click / ) (upper & bottom curves)
then Segmentor of Polyline (upper & bottom curves)
(for example take 10 segments for upper and bottom Polylines - you can move some points if you want)
then you will obtain that in Curviloft (third icon "Skin contour" )
You will obtain a better result! :enlight: ( 1 minute & 30 seconds) (start surface (C) can be the exact straight rectangle projection of the start volumes (E))
Ps You must also clean your original object! :)
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Mon Nov 19, 2018 3:01 am
If you draw a simple line(s) as vertical(s) (so no middle segments) that will work also ! :ugeek:
and calculus will be some more speedy! 13 seconds! :mrgreen:
Speedy Galerie
User avatar
Top SketchUcator
Postby taydavid03 » Thu Nov 22, 2018 6:04 pm
Wow you are amazing. Thank you!
This was very helpful... Again, thank you Pilou!
taydavid03
Flowify problems (help)
Postby hellolouise » Mon Dec 03, 2018 12:13 am
I am really struggling to get Flowify to work. I don't understand why so any help would be appreciated.
I have attached the file :)
hellolouise
Postby hellolouise » Mon Dec 03, 2018 12:26 am
what does raw faces mean?
hellolouise
Postby pilou » Mon Dec 03, 2018 12:08 pm
You must don't have Group of Groups for the objects to be projected!
Only one Group of faces! (raw face) :ugeek:
But in your case there are also something with all modules!
Maybe some overlapings somewhere!
I investigate! :)
In fact some connections between modules are very bad!
(if only one is existing Flowify will refuse to work! :)
You must have very précise ones! ;)
Redraw precisely your modules between them and you will have no problem! ;)
Here with 2 different modules from side of your model.
Speedy Galerie
User avatar
Top SketchUcator
Postby hellolouise » Mon Dec 03, 2018 4:39 pm
Thank you so much that is very helpful!
I will try again :))
hellolouise
Postby optimaforever » Wed Mar 20, 2019 7:44 pm
I have a strange behaviour too...
The flowify command generates a huge model, with an array of sectional faces.
First the source material: Group 1 composed of A target surface / B source surface / C projection vectors and D the source mesh (exploded)
The resulting groups from the flowify command
I succeeded all the other meshes with the same method but here I've got a bug...
flowify bug.skp
optimaforever
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Extensions & Applications Discussions
Who is online
Visit our sponsors:
