[Plugin] FredoCorner - v1.6b - 18 Apr 19
Re: [Plugin] FredoCorner - v1.4b - 31 Oct 18
Postby fredo6 » Wed Oct 31, 2018 9:47 am
NEW RELEASE: FredoCorner v1.4b - 31 Oct 18
Requirement: LibFredo6 8.6j
FredoCorner 1.4b provides bug fixing and GUI adjusments over v1.4a for the Variable Offset editors.
Please note that, in the current version of FredoCorner:
- there are issues with some shortcut modifiers (Ctrl, Alt) on Mac)
- there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large.
- Terminal corners (that is ending on a single edge) may present issues and bugs
- No documentation yet, so watch the videos that I will publish.
Please report issues, questions and any feedback in the present thread
Home Page of FredoCorner for information and Download.
Main post of this FredoCorner thread.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] FredoCorner - v1.4c - 31 Oct 18
Postby fredo6 » Wed Oct 31, 2018 9:50 pm
NEW RELEASE: FredoCorner v1.4c - 31 Oct 18
FredoCorner 1.4b provides various bug fixing and GUI adjusments over v1.4a and v1.4b for the Variable Offset editors and other features.
User avatar
PluginStore Author
PluginStore Author
Postby excellion02 » Sat Nov 03, 2018 4:17 pm
Error Loading File Fredo6_FredoCorner/__loader__FredoCorner
Could not find included file 'Fredo6_FredoCorner/__loader__FredoCorner'
sir, what is this error? help me please. thank you!
excellion02
Postby TIG » Sat Nov 03, 2018 6:47 pm
excellion02 wrote:Error Loading File Fredo6_FredoCorner/__loader__FredoCorner
Have you installed the downloaded RBZ using the native tool [or SketchUcation's toolset] ?
Assuming this was done OK... have you also downloaded and installed the required Fredo Lib ?
https://sketchucation.com/pluginstore?pln=LibFredo6
Restart SketchUp after the installation of these files to ensure they get synced...
If you still have these issues, then SketchUp itself might not be properly installed... but then that's for the next phase of trouble shooting !
User avatar
Global Moderator
Postby ogg1e » Wed Nov 28, 2018 2:23 am
Can this be used to round the outside corners of this object? It's a headphone case, and I'd like to smooth the edges of the slots that the wires come out.
I've tried to use this plugin (and roundcorners) but I haven't had any luck so far to get it to work.
ogg1e
Postby TIG » Wed Nov 28, 2018 2:46 pm
Your object is too small - SketchUp's tolerance of 1/1000" causes any very tiny edges to get omitted, because the start/end points are deemed to be coincident - then supported faces etc also fail to form.
The 'DaveR' method should circumvent the problem.
Select all of your object, and make it into a component.
Make a temporary copy of it off to one side and Scale that up, by say x100.
Edit the giant component and do the rounding etc - remembering to adjust the radii by the scaling factor - so 0.5mm => 50mm.
Now exit the edit and delete the giant temporary copy.
The original [unscaled] instance will show the desired rounding etc...
Here's a quick screenshot of it with View > hidden geometry ON [a little editing/healing was needed afterwards]...
Very tiny geometry can exist, BUT it cannot be created !
User avatar
Global Moderator
Postby MANaboutTOOLS » Wed Nov 28, 2018 11:25 pm
Having an issue with corners on this geometry. Using a Mac.
User avatar
MANaboutTOOLS
Postby ogg1e » Thu Nov 29, 2018 12:14 am
TIG wrote:Your object is too small - SketchUp's tolerance of 1/1000" causes any very tiny edges to get omitted, because the start/end points are deemed to be coincident - then supported faces etc also fail to form.
That looks like what I want!
I'm not having much luck, even with your instructions. It's still behaving the same as when it was small... No idea what I'm doing wrong.
ogg1e
Postby ogg1e » Thu Nov 29, 2018 1:20 pm
Ok, so I spent some more time with it, and changed things like you suggested with hidden geometry and I think I have a working model now. Thanks. It was painful and time consuming to get it to a point where this extension would actually work though. The problem is if I chose to move some of the holes for the wires, I suspect I'll be back where I was before where this extension won't work.
ogg1e
Postby TIG » Thu Nov 29, 2018 1:34 pm
SketchUp's built in tolerance of 1/1000" is what's causing your grief - not this extension.
You can't create very tiny edges and associated faces either manually, or in code.
However, they can exist.
The Scaling 'trick' is frequently used to get around this.
Complex geometry operations like 'rounding' and 'intersections' can produce some very small facets...
One other possible sidestep/trick is to work in the model with units set to meters, and with units not shown.
Then you enter all dimensions etc as if they were in mm, as simple numbers - 1234.5678 in meters is actually 1234567.8 expressed in mm...
Now your model is 1000x bigger and the tiny edge problems are avoided.
When you finally come to 3d-print the model you can scale it down by 1/1000 and reset the units to mm etc.
User avatar
Global Moderator
Postby ogg1e » Thu Nov 29, 2018 8:52 pm
I wasn't blaming the extension. I apologize if it appeared that way. :-)
I did use metric when I designed this. But not all measurements were whole numbers.
ogg1e
Postby fredo6 » Fri Nov 30, 2018 7:32 am
ogg1e wrote:I wasn't blaming the extension. I apologize if it appeared that way. :-)
The model is interesting, because the geometry seems to be messed up (on top of being extra small).
I'll have a look, but obviously, this makes it difficult for FredoCorner to work properly.
User avatar
PluginStore Author
PluginStore Author
Postby swalder » Fri Nov 30, 2018 3:21 pm
Before I start, thank you so so much for your work. I think it's a great decision to make this payable after all the time you have given to the sketchup community.
I have a question relating to the little mauve control points surrounding the corners.
Is the intention for these to be moveable at some point. I note if I click on them I get an error.
I was just having a click around and wondered if I could increase the curve profile from one end of the edge to the other. That would be amazing.... although the words "stick" and "moon" spring to mind.
I can achieve the same result through the SubD tool with some after manipulation I guess, but just wondered as the points seem interactable (if that's even a word).
Si
swalder
Postby fredo6 » Sat Dec 01, 2018 12:23 pm
swalder wrote:I have a question relating to the little mauve control points surrounding the corners.
I'll surely make the variable offset interactive, both for offset lines and corner offsets. Currently in FredoCorner, you select them and type the new offset in the VCB.
User avatar
PluginStore Author
PluginStore Author
Postby swalder » Mon Dec 03, 2018 1:12 pm
fredo6 wrote:I'll surely make the variable offset interactive, both for offset lines and corner offsets. Currently in FredoCorner, you select them and type the new offset in the VCB.
tested this over the weekend and it worked absolutely seamlessly.
I was able to achieve the exact result I was after, thanks to you.
Si
swalder
Re: [Plugin] FredoCorner - v1.5a - 18 Dec 18
Postby fredo6 » Tue Dec 18, 2018 9:27 pm
NEW RELEASE: FredoCorner v1.5a - 18 Dec 18
Requirement: LibFredo6 8.7a
FredoCorner 1.5a provides various bug fixing and extends the validity.
User avatar
PluginStore Author
PluginStore Author
Postby duanekemp » Fri Dec 21, 2018 2:31 am
You are awesome!
I should have chimed in earlier... but, this is really cool.
Thank you.
Duane Kemp
Kemp Productions
Puidoux, Switzerland
Gallery:
https://duanekemp.artstation.com/
User avatar
duanekemp
Re: [Plugin] FredoCorner - v1.5b - 10 Jan 19
Postby fredo6 » Thu Jan 10, 2019 3:35 pm
NEW RELEASE: FredoCorner v1.5b - 10 Jan 19
Requirement: LibFredo6 8.7f
FredoCorner 1.5b provides various bug fixing and extends the validity.
User avatar
PluginStore Author
PluginStore Author
Postby hssnjsm » Wed Jan 16, 2019 12:59 pm
The new update isn't working,
shows INVALID no good edges at the face message, for every shape.
hssnjsm
Postby fredo6 » Thu Jan 17, 2019 9:15 am
hssnjsm wrote:The new update isn't working,
Can you check the Edge selection filter, and make sure it corresponds to the properties of the edges you want to select.
User avatar
PluginStore Author
PluginStore Author
Postby NWAG Equipment » Wed Jan 23, 2019 10:07 pm
This is Brilliant! Thank you so much!
NWAG Equipment
Postby uwesketch » Mon Feb 04, 2019 10:52 pm
Thanks a lot Fredo for this very useful Plugin.
RoundCorner was already great, but this tops it.
What I realized while using the Plugin:
  • when pointing the mouse directly on an arrow modifier button (for instance to the left and right of the "#Seg" value) and then I click, the button to the left of it is activated. The gap between the button and the click area is about 4 mm. This is as well with other buttons. I have a Win 10 laptop with a 15" screen of 1600x900 Pixels. Not sure, if this is only on my PC.
  • for circles and Bezier curvers, one can choose an odd number of segments. But for Squircle this is not working right. The point/edge below the center point is missing (consistently in the profile sceen, the preview and generated geometry).
  • I would very much like to have a toggle on/off button like in SubD. (SubD is great to smooth organic surfaces as I draw them for furniture, etc.). For technical objects with a lot of planar surfaces and creases containing only some roundings, FredoCorner with a "toggle on/off" would be perfect.
    Very cool would be, if SubD and FredoCorner could share the same "toggle on/off" button concept. The two tools complement each other.
    Currently when I create a FredoCorner geometry and then use SubD, I cannot use the undo/edit function with FredoCorner anymore.
  • With a "toggle on/off" button this point here would get obsolete:
    I tried to use the SubDivision function of FredoCorner to produce thereafter with SubD a rounded corner in the shape of a circle. Since SubD generates C2 surfaces the rounding will not be in the shape of a circle. To approximate a circle after subdividing, a squircle with a factor of roughly 2.3 can be generated. The subdivided corner then is pretty close to a circle. Maybe this setting could be added as a preconfigured option to the FredoCorner SubDivision function.
  • If you need someone to help with the German translation, please let me know. I would be glad to contribute.
User avatar
uwesketch
Postby fredo6 » Tue Feb 05, 2019 5:03 pm
uwesketch wrote:when pointing the mouse directly on an arrow modifier button (for instance to the left and right of the "#Seg" value) and then I click, the button to the left of it is activated. The gap between the button and the click area is about 4 mm. This is as well with other buttons. I have a Win 10 laptop with a 15" screen of 1600x900 Pixels. Not sure, if this is only on my PC.
I have a slight problem with this cursor, because I cannot set the hot point. I fixed the problem by using another 'hand' cursor and it will go in a next release of Sketchup.
By the way, if anyone has a nice 'Cursor hand' png, ideally 28x28, that would be great.
uwesketch wrote:for circles and Bezier curvers, one can choose an odd number of segments. But for Squircle this is not working right. The point/edge below the center point is missing (consistently in the profile sceen, the preview and generated geometry).
Normally, the number of segments should be even, whatever the profile. Although I could allow odd numbers of segments, it's a little bit of a headhache when you come to reassign materials from the bordering faces.
uwesketch wrote:I would very much like to have a toggle on/off button like in SubD. (SubD is great to smooth organic surfaces as I draw them for furniture, etc.). For technical objects with a lot of planar surfaces and creases containing only some roundings, FredoCorner with a "toggle on/off" would be perfect.
That's the whole question of Modifiers in Skecthup (by reference to what exists in Blender). SubDiv and Artisan operates on groups and assume you transform the whole group by subdivision. FredoCorner operates on edges, and you don't need to have your geometry enclosed in a group, and even if this is the case, you can perform several rounding on the edges of that groups. The information for Undo/Repair is stored as attribute of the edges and it might be lost when you do a subsequent subdivision. That's why.
I can probably try to do something to 'simulate' a Modifier for Corner rounding. I just need to think about the most generic way to do that, considering that the current Ruby API is of absolutely NO help for supporting the approach, except if you accept to apply modifiers to Groups / Component.
Good findings and it may be useful. Note that a squircle of degree 2 is a pure circle.
uwesketch wrote: If you need someone to help with the German translation, please let me know. I would be glad to contribute.
Many thanks for that. You can go to the menu Tools > Fredo6 Collection... > FredoCorner > Language Translation. You have an editor to translate to German. It will generate a text file FredoCorner_DE.lang in the FredoCorner subfolder. You just need to send it to me or post it in this thread and I will integrate it for the next release.
Note that a large part of the strings are in LibFredo6, so you may want to refresh the German translation of LibFredo6, which is quite old and anyway incomplete (menu Window > LibFredo6 Settings... > Language Translation)
User avatar
PluginStore Author
PluginStore Author
Postby uwesketch » Thu Feb 07, 2019 12:45 am
by fredo6 » Tue Feb 05, 2019 5:03 pm:
Looking Forward to this. unfortunately I do not have a nice png.
I understand your point with the materials, but sometimes when using only 3 or 5 segments, it just looks better, if the middle part of the rounded edge/corner is flat and does not have the edge.
It is only with squircles where it currently does not work with an odd number of segments. the other profiles work fine with odd segments.
Regarding the German Translation, I will give it a try.
Regarding the toggle on/off:
Ok, understand. It is indeed tricky.
I somehow see four different workflows:
  • Use FredoCorner on edges to generate a geometry. The Undo/edit is used during the construction process. The generated geometry is used as is.
  • use FredoConer as a preparation to SubD. Only a few segments are generated (2 o 5).
  • as a finishing step use FredoCorner to generate nice rounded cornes on certain or all edges of a geometry, which can be toggled on or off.
  • Use FredoCorner to make some corners nicely round and then on the same geometry also use SubD to subdivide remaining surfaces. All this can be toggled on or off: This is for me a not really necessary "nice to have".
Based on above use cases, from a UI perspective, one could therefore separate the undo/edit functionality from the Toggle On/Off functionality. Especially, if this makes the implementation easier.
The first two use cases need the undo/edit, the last two the toggle on/off.
Therefore it would be fine, if the on/off toggle for FredoCorner would as well only work on groups/components like in SubD.
Instead of only an "On/Off", a triple state toggle would be nice: OFF -> low poly -> high poly. The low and high poly would be defined by the user.
For Example low = 4 segments, high = 16 Segments.
User avatar
uwesketch
Postby uwesketch » Sat Feb 09, 2019 1:10 pm
Is there a way to remove all FredoCorner "undo/edit" Information from a geometry?
I have the impression that after using the Edit function several times, it suddenly does not generate a good geometry anymore. When I then redraw the geometry from scratch, FredoCorner works nice again.
So I assume that there is some internal data stored on the geometry that causes the corruption.
What I also see when this happens, is the layer "LIBFREDO_hidden_Layer" in the list of layers.
Normally this layer is not there.
Sometimes one can get back to the "unccorrupted" geometry with Sketchup undo, but sometimes not.
For this and other reasons a "remove all FredoCorner data" would be helpful.
User avatar
uwesketch
Postby fredo6 » Sat Feb 09, 2019 1:34 pm
You can purge all Repair data with the menu Tool > Fredo6 Collection > FredoCorner > Purge All Data.
The Undo / Repair function is always tricky and may not work perfectly all time, because it also depends on the geometry of the neighboring faces and edges of the rounding. It's better than nothing, but until Sketchup provides a real native support of Modifiers, this will always remain approximative.
User avatar
PluginStore Author
PluginStore Author
Postby uwesketch » Sat Feb 09, 2019 6:51 pm
Thanks, I was looking for this option in the "undo/repair" screen, but not in the fredo tools menu.
P.S. yes, it is far better than no undo/edit funtion ! ;-)
User avatar
uwesketch
Postby Einstein » Wed Feb 13, 2019 6:32 pm
Thank you so much for this plugin :D
What's noticeable is that it works "through" groups, however, I experience an issue - when I preselect a few groups, then apply FredoCorner on them, not all of them are affected. Often only one gets rounded and the rest remains with no changes. It refers to SketchUp 2017 and 2018. I tried it many times and eventually I even had a bugsplat in SketchUp 2018.
Another issue comes with Bevel mode when working on a triangulated pseudo-quad mesh. I attached a model to explain the case – automatically created faces, which I painted red, are unnecessarily split. This is quite easy to repair manually so I removed the soft edges and drew single diagonals so that the final mesh is more simple. But in some cases it may be more difficult to fix by hand.
Fredo, have you already made up your mind about FredoCorner price?
Einstein
Postby fredo6 » Wed Feb 13, 2019 10:02 pm
Einstein wrote:What's noticeable is that it works "through" groups, however, I experience an issue - when I preselect a few groups, then apply FredoCorner on them, not all of them are affected. Often only one gets rounded and the rest remains with no changes. It refers to SketchUp 2017 and 2018. I tried it many times and eventually I even had a bugsplat in SketchUp 2018.
Would you have an example of that?
Einstein wrote:Another issue comes with Bevel mode when working on a triangulated pseudo-quad mesh. I attached a model to explain the case – automatically created faces, which I painted red, are unnecessarily split. This is quite easy to repair manually so I removed the soft edges and drew single diagonals so that the final mesh is more simple. But in some cases it may be more difficult to fix by hand.
Thanks for signaling the issue. This is actually a side effect of the approach I used, because FredoCorner does the beveling with 2 segments in case the bordering faces have different materials, and then erases the middle line if it is possible. In your case, since the bevel is not planar and need to be triangulated, you obtain 4 triangles instead of 2. I need to revisit the algorithm.
Einstein wrote:Fredo, have you already made up your mind about FredoCorner price?
Not decided, probably cheap, but it is free for the time being, and the Undo/Edit function would remain free so that you can at least use it on existing rounded model.
User avatar
PluginStore Author
PluginStore Author
Postby Einstein » Thu Feb 14, 2019 11:16 am
Now I realised that the issue I first described (not affecting all selected groups) only occurs when I make a group (say, simple cube) and copy it, so Entity Info says for example: "3 Solid Groups (3 in model)". This is a situation to avoid in general. SketchUp behaves strange when you copy groups and not edit the copies.
If I create groups independently and not duplicate them, FredoCorner works fine.
Nevertheless, due to the crash I caused in SketchUp 2018, I'm reporting this. The attached model contains a group that was duplicated twice and they cause problems with selection.
Referring to the second issue (with face division), I think that perfect solution would be a button toggling whether "chamfer-faces" are divided along, or not.
Einstein
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: Jussiara Caldeira , Markhilo00, Pixero and 22 guests
Visit our sponsors:
