SkethUcation privacy https
@pilou said:
The problem has returned!
And seems to be have been solved again as well
(I'm not seeing the problem now, thus the assumption.)
SCF only works with http and not https now.
No Solo, you need to refresh your browser if that is the case.
Unless of course different servers have different results. -
It still works fine for me with https [if I try http, then my browser uses https anyway !]
Maybe Rich/Gábor have been tweaking the certification again ! -
Solo
Have you cleared your browser's cache ?
I assume you are on Chrome ?
Here's what I got just a minute ago... -
I get the same result with Edge
Chrome and Edge seem to use similar protocols...
But while my Chrome was working OK, now I see Edge has this issue again...
Saying the Certificate has been revoked !WTF ?
I've PM'd Gábor/Rich...
Same bad result with Opera, Chrome, IE, Edge...!
Rich/Gábor are investigating...
Works fine for me with Firefox and Chrome, but a certificate error with IE & Edge... -
You are lucky : here it's the total blockade with any navigators for certificates!
someone give me that!
https://letsencrypt.org/
"That not only gets rid of paying for it but it also simplifies managing them when they expire as well which can also be a pain."Have fun coding!
Is the Sketchucation SSL certificate problem still existing for anybody? The certificate was renewed at the 22nd so it should be ok for everybody by now. Those who still experience the problem, could you make a full cache erase and tell me if the problem still exists or not?
Alas always certificated and not securised after cache killing!
I still have this problem with Firefox and Chrome.
Sorry, I do not understand exactly the phenomenon. If you click the lock icon at the URL line of your browser is it indicating that the certificate is secure? Do you see the certificate details? Could you please send me what you see there?
(For me it is fine with all the browsers I have so I do not see any problems with the site with my browsers.)
Could you please send me a screenshot about what you see? Also could you please click on the lock icon in your browser's URL line and see the certificate details there?
The problem is, it's in German, I don't know if it would be of any use to you. I installed a portable English Firefox version to give you an English error screen, but the page works with that one for some reason. Then I tried creating a new profile, and once again it didn't work.
But now I switched back to my main profile and it appears to be working. Let's hope it stays like this.
It still doesn't work in Chrome, but I only used this to check if Firefox was the problem. There i get the following error:
NET::ERR_CERT_REVOKED Subject: *.sketchucation.com Issuer: COMODO RSA Domain Validation Secure Server CA Expires on: 23.11.2019 Current date: 26.11.2018
And then a huge amount of apparently random characters and numbers.
Edit: Now the problem is back. The forums work without "https://" in front of "sketchucation.com", but when I click the icon in the address bar (there is only a shield, not a lock on this page), it says that the connection isn't secure.
