I have different styles ( created within the SKETCHUP file ) in several Layout pages.
Example, I have 1 page with a shaded textured color style, other one in Monochrome, and so on.
When export them to PDF, all the pages have the shaded textured color style.
Is there a way to export each page with their own style ?
Exporting Layout to PDF - Style problem
• Page 1 of 1
Re: Exporting Layout to PDF - Style problemIt is possible to have each page show a different style if you want. Why it's not happening for you is a guess at the moment. Can you share the LayOut file so I can see how you have it set up? That'll give me the info I need to give you the correct answer. Send it via a PM if you don't want to make it public.
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: Exporting Layout to PDF - Style problemI guess i found a way to achieve it
I render the su drawing in each page either Vector / Hybrid, and apply the style again and it worked. Thank Dave Re: Exporting Layout to PDF - Style problemThat kind of sounds like a work around for the right method but if it works for you, that's fine.
• Page 1 of 1
