Something I have noticed in my short time with SU, is that when you cut a section (say a horizontal section through a houser to create a floor plan), an item that I have pulled from Profile Builder (steel hollow column) that has been cut, the cut plane of the object cannot be snapped or inferenced to.
For example, the section plane cuts through a steel hollow column. The top of this column at the cut plane cannot be snapped to at all.
Normally this has not been a problem, until I take over to layout and try to dimension to it, and cannot get an accurate dimension to edge or centre of column, because I cannot snap to an edge or centre.
This seems to be a pretty big issue, so I am assuming that there is a way around this, which I am currently unaware of.
Need some guidance here. Thank you.
On another note, my triple click has stopped working.
Kerry
