2many faces
General discussion related to SketchUp Pro and Make
2many faces
Postby koenvdw » Wed Jun 13, 2018 10:48 am
I have a model from 3Dscandata. The ceiling from the building is made of thousands of faces. Is there a way to significantly reduce them?
This model is not workable. It's an ifc export from Revit.
koenvdw
Re: 2many faces
Postby Dave R » Wed Jun 13, 2018 1:27 pm
The first thing I would do is run ThomThom's CleanUp3 and let it erase coplanar edges.
User avatar
Global Moderator
Re: 2many faces
Postby koenvdw » Thu Jun 14, 2018 8:03 am
Dave R wrote:The first thing I would do is run ThomThom's CleanUp3 and let it erase coplanar edges.
It reduces the filesize, but the small faces are not coplanar. So it did clean some stuff, but not enough to make it workable.
Is there a plugin that makes 1 face from faces that are next to eachother and with an angle below some value?
koenvdw
Re: 2many faces
Postby Dave R » Thu Jun 14, 2018 9:45 am
You might try TIG's Drop Vertices or there's an old one called Face Flattener which might do the trick.
User avatar
Global Moderator
Re: 2many faces
Postby rv1974 » Thu Jun 14, 2018 5:11 pm
Manual lofting only IMHO
rv1974
Re: 2many faces
Postby Box » Thu Jun 14, 2018 5:19 pm
Looking at that Image I would simply delete the selection and make faces between what appears to be a radial array of beams.
User avatar
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: Google Bot, Wasko and 10 guests
Visit our sponsors:
