[Plugin] ClothWorks v1.7.9 - 18 Apr 2024
Care Frederik!! "The curiosity killed the cat"
The possibilities are endless, you can use ClothWorks to create a lot of different organic objects, more examples at the end of the day or tomorrow.
thank you Oxer for your second sketch
I continue to fail at the simplest things How do I make cloth and Pin sticking together?
But seriously...
When I converge the cloth+frame with the balls (collider), the cloth doesn't bend as I would expect...I press the ClothWorks play button, click the frame (pin) and drag the red arrow towards the balls, but the cloth just remain stiff and doesn't fold around the balls...
I don't get the result HornOxx is showing in his animation...
I assume that's caused by the cloth isn't "inside" the frame...?!? -
HornOxx & Frederik, the trick is to create the frame with 3 elements because if the frame is an unique object ClothWorks creates a box for the pin and this makes that the cloth does not move. See the image.
REMEMBER: The cloth should enter a little in the frame.
But like I wrote...
I don't have the issue HornOxx is experiencing...
The frame and the cloth moves correct when I click the play button, click the frame and move the frame and cloth by dragging the red arrow that emerge, when I click the frame...
REMEMBER: Create the frame with 3 slats to do the cloth moves. See the image of my previous entry.
Ok... I've made the frame with 3 slats...
At first I couldn't make it work - because I had grouped them...One IMPORTANT info is missing...
You need to move the frame-pins one by one...
It can't be done by moving all three in one go...
Select the 6 slats and converge with shift or ctrl key while you move them, that is the trick
Got it...
Hold down the shift-key when clicking the pins and then converge...!
This gives me a ton of new options and ideas...Thanks, Oxer...!
For a non native english speaker. Could you explain what converge is?
Googling it didnt help. -
Bring together.
Move toward each other as if to become one.
Two paths can converge into one and diverge back into two. -
Thanks.
Googling it didnt help.Strange...
I get a lot of results - especially if I write "define: converge" in Google...Even Google translate has a nice explanation...
Nice work with this!
What I meant was simply that I didn’t understood the meaning of the word using Google.
No worries, Jan... I actually just wanted to make you aware of the "define: xxxxx" option available in Google...
I'm fairly sure you would have found reasonable explanation and understanding if you had used that option... -
A new use for ClothWorks, create organic shapes, rendering with Thea Render.
Excellent! But it needs a meatball and some grated parm.
