Skatter causing white background on imported models
General discusson for Skatter for SketchUp
Moderator: jiminy-billy-bob
Postby Victory7s » Fri Apr 13, 2018 1:07 am
Hi there,
I'm a university student working on my final project and I've this year taught myself how to use V-Ray and Skatter.
I purchased the Lotfi Bernoussi Vertical Green Wall photo real models so that I could create a vertical garden (located here: https://gumroad.com/l/tOyB)
For simplicity, I used one of the preset vertical gardens and imported directly into my Sketchup model.
I then attempted to render the scene with V-Ray and for some reason the leaves within the vertical garden have a white background, almost making them look like paper.
I'm not sure if it's scatter or V-Ray causing the issue here.
Does anyone know what's causing this and if so, how I can fix it?
(I just did a quick, unfinished render to try and show what I'm talking about. Apologies for not completely rendering it out, but that would take longer than's needed).
Victory7s
Re: Skatter causing white background on imported models
Postby filibis » Fri Apr 13, 2018 1:58 am
I assume you followed this tutorial, if not please do so.
Does the plant models render correctly without using Scatter?
It looks like opacity maps for the plant material didn't apply. Make sure folder paths for the opacity map is correct in the Vray material editor.
Opacity map is a black & white image as shown below:
User avatar
filibis
Postby Victory7s » Fri Apr 13, 2018 2:19 am
filibis wrote:I assume you followed this tutorial, if not please do so.
Hi Filibis,
Thanks for your reply.
If I open the preset vertical garden in Sketchup and render through V-Ray, it works perfectly and renders without the white backgrounds.
It's however when I import it into my University project model and attempt to render that the issue occurs.
Victory7s
Postby Victory7s » Fri Apr 13, 2018 3:01 am
Hi Again Filibis,
I re-read what you said about the opacity map and realise that this could be the issue.
How do I check the folder path for the opacity map? Is this done through V-Ray?
Victory7s
Postby filibis » Fri Apr 13, 2018 11:45 am
You can find opacity at Material settings. When you clicked this checker icon, you will see the path it uses.
If it renders correctly on empty scene, try also a simple skatter on that empty scene to determine whether your university project file is problematic or not.
User avatar
filibis
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Skatter
Who is online
Users browsing this forum: No registered users and 4 guests
Visit our sponsors:
