Laubwerk Trees not rendering in Thea
General discussion on Thea Render for SketchUp
Moderator: Frederik
Postby sfto1 » Mon Apr 09, 2018 3:08 pm
As the title states, the Laubwerk Trees I placed into the model are not rendering when using Thea.
What am I missing beside the trees? :?
User avatar
sfto1
Premium Member
Premium Member
Re: Laubwerk Trees not rendering in Thea
Postby Frederik » Mon Apr 09, 2018 7:36 pm
Difficult to say...
It works fine on my laptop...
Cheers
Kim Frederik
User avatar
Frederik
Thea Render Support
Thea Render Support
Postby Rich O Brien » Mon Apr 09, 2018 9:17 pm
Are they proxies?
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby jiminy-billy-bob » Mon Apr 09, 2018 10:06 pm
Yes they are proxies generated on the fly at render-time.
User avatar
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby JQL » Mon Apr 09, 2018 11:30 pm
Are you copying the proxies from a model into another or generating new proxies with the plugin in a new model?
User avatar
JQL
Premium Member
Premium Member
Postby sfto1 » Tue Apr 10, 2018 4:29 pm
The tree models were inserted into the model directly using Laubwerks. The file in question is not a copy of a file. I had this problem before when I mixed trees from skatter and Laubwerks trees, but that is not the case here.
User avatar
sfto1
Premium Member
Premium Member
Postby sfto1 » Tue Apr 10, 2018 4:54 pm
:oops: :oops: Very embarrassing to admit that I just figured out that i hadn't installed Laubwerk into SU2018.
It's working fine now.
Thanks for the replies and sorry for wasting your time.
User avatar
sfto1
Premium Member
Premium Member
Postby whiterabbit » Wed Jun 27, 2018 3:39 pm
I'm having the same issue, but as far as I can tell it is installed through the extensions manager. It's been a while since I first installed it, but is there a different installation that I need? The trees do not render in Thea.
whiterabbit
Premium Member
Premium Member
Postby sfto1 » Wed Jun 27, 2018 6:36 pm
whiterabbit wrote:I'm having the same issue, but as far as I can tell it is installed through the extensions manager. It's been a while since I first installed it, but is there a different installation that I need? The trees do not render in Thea.
Are you trying to render a file that has the tree models in already?
Try inserting a Laubwerk tree in from the library and see what happens.
Also, I believe you need to use the Laubwerk installer, not the SU extension installer.
User avatar
sfto1
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Thea
cron
Who is online
Visit our sponsors:
