SUp to Cinema 4D?
General discussion related to SketchUp Pro and Make
SUp to Cinema 4D?
Postby Joe Wood » Wed Feb 14, 2018 4:52 pm
Can I convert a SUp file so it can be viewed and measured by somwone using Cinema 4D?
User avatar
Joe Wood
Re: SUp to Cinema 4D?
Postby Rich O Brien » Wed Feb 14, 2018 5:09 pm
If 4D has measuring tools then yes.
Export to OBJ and make sure model units and Swap Axis is checked.
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby Joe Wood » Wed Feb 14, 2018 5:25 pm
Right on Rich I'll give it a try!
User avatar
Joe Wood
Postby Joe Wood » Wed Feb 14, 2018 7:08 pm
Say Rich, should I select any of the model units like ' or cm? This is going to someone over in the UK if that matters.
User avatar
Joe Wood
Postby Rich O Brien » Thu Feb 15, 2018 12:03 pm
OBJ by default uses its own units. Setting the export to match the model units in SketchUp means the app importing can apply the correct scale.
So if you model in CM then exports in CM.
I'm more interested to know if Cinema 4D dimensions meshes. There's a paid plugin...
http://lesterbanks.com/2014/03/measure- ... cinema-4d/
...so it suggests that Cinema 4D doesn't dimension as standard.
User avatar
Rich O Brien
Administrator
Postby Joe Wood » Thu Mar 01, 2018 2:12 am
So check out what Gus did https://www.shijima.co.uk/ scroll down a bit to my moon gate pics then under is a model he built and rendered from the file I sent him! Look at the texture on the round moon gate faces, how it follows the curve around :-)
User avatar
Joe Wood
Postby pbacot » Thu Mar 01, 2018 5:18 am
That's a beautiful render video and a great model, beautiful design. You can apply texture to orient like that in SketchUp. With Fredo's Thrupaint and other ways. First find a circular board!
Long grain wood material from Sketchucation!
MacOSX Mojave ShetchUp Pro v16...v19? Layout Twilight Pro v2 M2 Kerkythea PowerCADD
User avatar
Top SketchUcator
Postby Joe Wood » Sun Mar 04, 2018 4:49 pm
Hey Rich, Gus is totally stoked with the new measuring tool he has :-) Thanks for suggesting that!
User avatar
Joe Wood
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: makro88 and 10 guests
Visit our sponsors:
