[Plugin][$] Tools On Surface - v2.5a - 22 Apr 21
oh my goodness, I think I got it to work - I deleted a few of the guidelines and zoomed out - not the prettiest looking object but it does the job
thank you for sparing the time to help
the key seems to be to note where the blue/purple dots appear and keep guides to a minimum
Good for you. If you use the inferencing tools you really shouldn't need much in the way of guides.
thanks
Thanks for share.
tonamu -
NEW RELEASE: Tools on Surface 2.3a- 06 Oct 17
This maintenance release is required for:
- the support of usernames with non-ascii characters
- the compatibility for High Sierra for Mac users
- the support for hi-resolution screens
- the certification for SU2017
You will need to migrate to LibFredo6 7.7g or higher
Please see main post for download
Fredo would it be hard to add fillet tool please?
What do you mean?
This is a set of tools "on Surface".Fredo
I mean fillet on 3d surface. See attached:
Say you have AB and CD lines. The red fillet connectig AB abd CD is demanded.
Street - underground parking ramp junction. Example from real life (VERY common an tedious task).
Somehow, you are asking if I could implement teh equivalent of BezierSpline 'on surface', of which the filetting is just one tool.
That's probably possible, but non trivial.
Actually the real difficulty with TOS is to handle the sharp changes in surface, because this is where directions may change abruptly. If everything was on a smooth surfce it would be simpler.
I'll think about it.
I'd gladly use this 3d fillet on more or less 'calm' surfaces and get an error report on sharp ones. no problem.
Hi!
As you can see in the screenshot, I selected two neighbouring surfaces. Offset on Surface creates one big offset for them both, together. I was thinking, if it's possible that offsets would be created separately, independently for each surface?
@einstein said:
Hi!
Why don't you select each face for individual offset?
FredoBecause in another model I have tones of surfaces to offset and selecting them one by one would be haaard.
Use one of lattisizers and then intersect it
NEW RELEASE: Tools on Surface 2.4a- 01 Nov 18
This maintenance release is for bug fixing
You will need to migrate to LibFredo6 8.6j or higher
Please see main post for discussion
See Plugin download page for download
Dear Fredo,
Hello, I kindly reach you to ask you, Is there any possibility to add curve line to the Tools On Surface plugin or link BezierSpline plugin with Tools On Surface in order to draw the F-spline or Catmull Spline. Because sometimes we need to draw the special curve on curved surfaces. (Attachment file).
Sincerely
Hamidreza -
That's relatively difficult to make a Draw Bezier on Surface.
I think in the case of your model, the best would be to proceed with shaped cylinder and then intersect the torus.
Dear Fredo,
Thank you for your prompt reply to my question. Wow, I thought that adding curve line(Bezier) on Tool on surface plugin will be possible in SketchUp as MESH interface because this is just an example in order to show you what I mean and you obviously know that we usually need to add curve line on the curved surface(Like other Software: Rhino and...). Indeed, I ever use Drap(Feature in the SketchUp) or Flowify plugin(Anders L.) in order to put a pattern on my curved surface but most of the time it doesn't work properly or It does not look like what I am looking for.
All in all, I hope so in the near future, we have this feature on SketchUp. Thanks in advance.Yours sincerely,
Hamidreza -
Hi there.
Do you have a link to download the Tools on Surface plugin? I tried on the main page but link doesn't work.
Thanks.
