SketchUp Guide for Woodworkers: Advanced Techniques
To access this forum when logged in, please, sign up to the Woodworking User Group in your User Control Panel.
Re: SketchUp Guide for Woodworkers: Advanced Techniques
Postby Dave R » Sat Dec 30, 2017 1:43 am
Andy, I sent you a PM.
User avatar
Global Moderator
Postby lockha » Mon Jan 01, 2018 12:36 am
Argh!!!
Made the box. Cut the dovetails.
Marked the curve and made the cutter oversize.
Copy to clipboard. Delete the cutter.
Hide the ends (didn't bother to rotate but I've done it.)
Open a side for editing. Edit-> Paste in Place. Everything now within Edit box.
Edit-> Intersect faces with Selection
"No intersections found between selection set
and the rest of the model"
Tried again- same thing
Probably a simple answer- usually is
lockha
Postby Dave R » Mon Jan 01, 2018 12:53 am
Did you make the cutter a component before copying it to the clipboard? Why did you delete the cutter after copying it?
User avatar
Global Moderator
Postby lockha » Mon Jan 01, 2018 7:00 pm
No, it's not a component.
I deleted the cutter after copying it so I could open the side for editing and then paste the cutter back in place.
Was that the wrong way?
lockha
Postby Dave R » Mon Jan 01, 2018 7:10 pm
lockha wrote:No, it's not a component.
Well, there's no need to delete it after copying it. Just open the side component for editing and use Paste in Place. If you tick the Hide boxes in Model Info>Components, the original cutter geometry won't be visible when you are editing the component.
User avatar
Global Moderator
Postby lockha » Thu Jan 04, 2018 9:54 pm
Dave-
I seem to have it working, appreciate your assistance.
We talked about the change from SU Make to SU Free- if I heard you correctly, you said that Make would be continued on offer, but not updated after 2017- did I hear you correctly? Because when I go onto SU.com, I don't see any reference to Make anywhere. Could you clarify? thanx
lockha
Postby Dave R » Thu Jan 04, 2018 10:15 pm
You did hear that right. SketchUp 2017 Make will continue to be available for hobbyist use from SketchUp.com/download/all. Of course anyone using SketchUp in their business will need to use SketchUp Pro and should probably be using SketchUp 2018 Pro at this point.
User avatar
Global Moderator
Postby lockha » Fri Jan 05, 2018 4:07 pm
Thanks I'll try that
lockha
Postby lockha » Fri Jan 05, 2018 4:09 pm
Is it correct that one takes the Pro trial and then after 30 days can licence Make?
lockha
Postby Dave R » Fri Jan 05, 2018 5:16 pm
lockha wrote:Is it correct that one takes the Pro trial and then after 30 days can licence Make?
There is no Make 2018 version. If you install SketchUp 2018 Pro, you'll get a 30 Day trial period. If you choose not to purchase the license, it will be dead in the water after the trial period expires.
User avatar
Global Moderator
Postby lockha » Fri Jan 05, 2018 6:18 pm
Forgot to put the second / in- now all is good.
lockha
Postby Khai » Sun Mar 17, 2019 3:14 pm
heads up for you, the book is not available in the UK or Europe... went to have a look at the price and got :
"Unfortunately we are unable to fulfill your request at this time. Due to GDPR (General Data Protection Regulation) requirements we are unable to support our European Union market through our online store. We apologize for the inconvenience that this may cause and we would be happy to assist you with your print subscription or product purchases as needed. Please contact Customer Service at 515-247-2990. Thank you."
Khai
Postby Dave R » Sun Mar 17, 2019 4:02 pm
Thanks for that. It looks like GDPR affects all of their digital offerings. Unfortunately it's not something I have any control over.
User avatar
Global Moderator
Postby zaz1 » Tue Oct 06, 2020 1:29 pm
Dave,
I had purchased the DVD and didn't realize the ebook had so much more content. Good thing I found this thread with the pdf of the table of contents. Based on viewing it, I purchased the ebook. Looks great and covers a wide variety of furniture. Even a section on using Layout, although that could be the subject of another book. Thanks again Dave for helping me use SketchUp to help with woodworking.
zaz1
Postby deklund » Thu Apr 01, 2021 4:04 pm
Hi Dave,
I purchased both the basic and advanced DVD's and appreciate all the useful tips and techniques. That said, I bought these because I have been using Sketchup intermittently for years to support my woodworking projects and I may have developed some bad habits. For example I have been drawing on different active layers which could be for room 1, room 2, dims etc. I'm annoyed when elements behave strangely when another layer is made visible or not and I read in another post that best practice is to draw EVERYTHING on layer 0 and then assign to layers after the fact. Can you kindly direct me to any posts you have authored that talk about general best practices for trouble free drawing. Even better would be some explanation of the weird behaviors that happen. I use Make 2017 because, again, I am an intermittent user and I hate subscription based software.
Thanks for your contributions to the woodworking community and for any advice on this topic.
Don
deklund
Postby Dave R » Mon Apr 05, 2021 2:20 am
Welcome to Sketchucation, Don.
deklund wrote:Hi Dave,
Thank you. I'm happy to hear you've found them helpful.
deklund wrote:For example I have been drawing on different active layers which could be for room 1, room 2, dims etc. I'm annoyed when elements behave strangely when another layer is made visible or not and I read in another post that best practice is to draw EVERYTHING on layer 0 and then assign to layers after the fact.
Yes. Making layers active is a bad habit and it sounds like you are finding the trouble is has caused. Best practice is to keep Layer 0 active and only give other layers to groups and components (objects). ALL edges and faces keep Layer 0 assigned to them. Only the object containers are given other layers. This means you aren't chasing the active layer and you will avoid the annoyance you describe. The workflow is easier and you won't create problems.
FWIW, you don't really put things "on" layers in SketchUp. You give layers to objects. In later versions of SketchUp they stopped using "layers" and replaced them with "tags" which I think is a more appropriate description considering how they are supposed to be used.
deklund wrote:Can you kindly direct me to any posts you have authored that talk about general best practices for trouble free drawing. Even better would be some explanation of the weird behaviors that happen.
I can't think of specific posts that I've authored for general best practices although I've covered what I find to be best practices for me. The layers/tags thing as above, for example, only components in my models, no groups (That makes some people come unhinged but it's part of my workflow. It's worked for me for more than 15 years of using SketchUp but you can decide for yourself.) Leverage the power of components. Length Snapping off in Model Info>Units and highest precision available for the chosen units. Model in place so you don't need to do so much data entry. As I showed in the Basics video, after setting out a few parts to establish the outer bounds of the model, the rest of the parts are modeled to fit. don't get too excited about adding materials to your model. Make sure the geometry is correct first. Materials can mask problem geometry and you don't need things getting in the way.
deklund wrote:I use Make 2017 because, again, I am an intermittent user and I hate subscription based software.
I expect you should find SU Make more than adequate for your hobbyist use. It's very powerful and if you are making your models correctly, by the time you get to the shop it'll be like you're building the project for the second time. No surprises.
deklund wrote:Thanks for your contributions to the woodworking community and for any advice on this topic.
Don
Thank you! Feel free to start new threads when you have questions. Happy to help.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Woodworking
Who is online
Users browsing this forum: No registered users and 2 guests
