[Plugin] VolumeCalculator v1.8
Postby TIG » Wed Nov 21, 2007 7:48 pm
Here's v1.8. For some reason it's just started to Bugsplat on my new PC (Vista). It didn't before ! This new version avoids a splat since it has a two step undo. The splat seems to come from after it's intersected the volume slicing disc group to make entities inside another vol group and then it is trying to erase that disc group within the same commit/undo as the rest. By making 2 undo steps it doesn't splat - go figure ?
User avatar
Global Moderator
Re: VolumeCalculator v1.8
Postby Tobobo » Wed Nov 21, 2007 7:49 pm
Toby
Philippians 4:13
User avatar
Tobobo
Postby AdamB » Wed Dec 12, 2007 10:53 am
This all seems quite a complex way of getting the volume.. The following analytic approach works nicely.
Code: Select all
def calculateVolume(container)
   volume = 0
   for face in container
      next unless face.kind_of? Sketchup::Face
      volume += (2 * face.area * (face.vertices[0].position.dot face.normal)) / 6
   volume
User avatar
AdamB
LightUp Support
LightUp Support
Postby AdamB » Wed Dec 12, 2007 1:38 pm
Doh. And you need to have Geom::Point3d#dot defined - (which is beyond me why it isn't as standard)
Code: Select all
class Geom::Point3d
   def dot(v)
      self.x * v.x + self.y * v.y + self.z * v.z
User avatar
AdamB
LightUp Support
LightUp Support
Re: [Plugin] VolumeCalculator v1.8
Postby Dan Rathbun » Sat Dec 30, 2017 8:00 pm
I have posted my rendition of the "no temporary group" calculate volume solution.
See: Calculate volume on manifold surface without group & explode
Bonus method for a volume display string in model units:
See: [code] format volume in model units
    I'm not here much anymore. But a PM will fire email notifications.
    User avatar
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    by Ad Machine » 5 minutes ago
    Ad Machine
    Robot
    Return to Plugins
    Who is online
    Users browsing this forum: danowebb and 11 guests
    Visit our sponsors:
