[Plugin] Make Fur v.2.1.0(20140323)
Re: [Plugin] Make Fur v.2.1.0(20140323)
Postby marcodallago » Wed Sep 14, 2016 2:12 pm
I have a problem.. I need to create grass in the green area of the image, so that will look the walkway emerge from the grass. But how can i do? With your plugin grass elements come out from the path and this is not what I want. Is there a workaround?
marcodallago
Postby majid » Mon Oct 31, 2016 5:19 am
فایل آپدیت زبان فارسی
Here is the updated Persian ( Farsi ) language file
My V-Ray book for architects: https://goo.gl/cz1oRc
User avatar
majid
Top SketchUcator
Postby sexypox69 » Thu Nov 03, 2016 7:11 pm
I too had the issue of selecting a surface and when I make fur it would be scattered everywhere except the selected surface. After changing the axis of my proxy that seem to solve the issue. I the tutorial i watch it showed the changing of the axis of the component but not to the proxy created with it. I guest when I changed component to a proxy it changed the imput axis....well this is what worked for me...Im a bit lost when it comes to these things
sexypox69
Postby jaapberg » Wed Aug 09, 2017 3:03 pm
Please can someone teach me who can i create plugin? I need this.
Thank you
jaapberg
Postby Einstein » Mon Dec 25, 2017 3:16 pm
No fur (grass) is created :( The window shows up but there's no preview, no creation :( Sketchup 2017 pro, Win 7 64bit. Any ideas?
Einstein
Postby Dave R » Mon Dec 25, 2017 3:35 pm
Einstein wrote:Any ideas?
My guess is pilot error. I just installed it and it works fine for me. We need more information about what exactly you are doing when you try to use it.
User avatar
Global Moderator
Postby Einstein » Tue Dec 26, 2017 1:18 am
What do you mean by "pilot error", what does it mean?
Now I restarted SketchUp a few times and it started working... almost correclty. I can see the preview and generate nice fur. Unless I change some of the parameters: Length, RootWidth (Main tab) and directions, forces (Detail tab) cause the script to kinda get stuck. The preview doesn't change and the geometry doesn't generate. Nothing happens when I click MAKE FUR. I can only close the window and start again with the same issues. In comparison: if I adjust e.g. Stiffness, Divide (Main tab) or things in Detail tab marked green, everything works properly. Looks like the Author wanted to say: green background means "compatibility guaranteed", white bacground means "you're doing this at your own risk". I don't know if it really matters, if the script somehow checks compatibility. Cuz the Author's menu is all green :P
And one more question - is it possible with this plugin to retain proxies after generation and render fur fully only in external renderer, like v-ray?
I attached the file I'm working with but certainly the problem is not about certain model.
Einstein
Postby Dave R » Tue Dec 26, 2017 2:09 am
Pilot error=user error. I thought Einstein would know that. Sorry.
Maybe you've set the length too short?
As for proxies, I'm not sure that is within the scope of this extension. I think you'd need another approach for that.
User avatar
Global Moderator
Postby Einstein » Tue Dec 26, 2017 2:24 am
Maybe I should change my nickname...
I assume that when you click MAKE FUR, the geometry generates. So yes, this must be something with my sketchup.
The behaviour doesn't change but thank you for your attempt to help me!
Einstein
Postby TIG » Wed Dec 27, 2017 7:52 pm
What settings do you have - compared to Dave's - which work ?
Perhaps a screen-shot ?
If you try it with the Ruby Console open are there any error messages ?
Please be aware that this toolset is getting somewhat old...
User avatar
Global Moderator
Postby Einstein » Fri Dec 29, 2017 1:29 pm
I tried to generate fur with SketchUp 8 also but the same problem exists with the same set of non-working params.
Working parameters: Density, MaxNumber, Stiffness, Divide (Main tab), all Jitters, ValidDistance (Detail tab).
Non-working parameters: Length, RootWidth (Main tab), directions and forces (Detail tab).
No matter what values I am using, errors show up. I tried similar values to Dave's but it didn't change anything.
Example error in Ruby console when adjusting non-working params:
Error: #<ArgumentError: Cannot convert "0.006" to Length>
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/FUR_EN/main.rb:2407:in `to_l'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/FUR_EN/main.rb:2407:in `s_to_l'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/FUR_EN/main.rb:1398:in `start_fur_test'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/FUR_EN/main.rb:1340:in `show_webdialog'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/FUR_EN/main.rb:2407:in `call'
Additionally, when I adjust a non-working param and after that, a working param, also that working param starts to generate Ruby errors. Only when I restart plugin, I can use some of the params again.
Einstein
Postby TIG » Fri Dec 29, 2017 8:26 pm
Code: Select all
def s_to_l( tstr1 )
  if tstr1
    tstr = tstr1.to_s.gsub(/\~ /,"")
    return tstr.to_l ####### THROWS ERROR
In the error-message tstr1 is "0.0006" so if you type this in the Ruby Console it should work:
x="0.0006"
x.to_l
If that works I can't see what's up !
User avatar
Global Moderator
Postby Einstein » Sat Dec 30, 2017 12:26 am
I should type in Ruby Console
x="0.006"
x.to_l
where "0.006" is the value I adjusted with the slider; type it right after moving the slider, right? And then Make Fur.
Sadly this still generates errors :(
Einstein
Postby TIG » Sat Dec 30, 2017 7:47 pm
This was not a FIX.
I wanted to see what got returned when you set a reference to a string and then used .to_l to change that into a length...
It should work in SketchUp >= 6 - particularly when tested outside of the main code.
Fortunately your code in the Ruby Console shows the error.
This should NEVER happen !
What are your Model Info > Units set to ?
A screen-shot might help.
User avatar
Global Moderator
Postby Einstein » Sun Dec 31, 2017 3:27 pm
My units are set to metres.
Einstein
Postby TIG » Sun Dec 31, 2017 11:36 pm
Try typing in values like 0.250m - rather than the bald 0.250, without a units suffix.
See if that helps ?
This is a mystery...
User avatar
Global Moderator
Postby Einstein » Mon Jan 01, 2018 4:21 pm
Yeah! :fro:
This is the point. Adding "m" suffix recovers the preview and makes creating fur possible. Sometimes the solution is so surprisingly simple and you wonder how you couldn't figure it out by yourself :lol:
Thank you so much, TIG!
PS I still cannot use these sliders but this it OK. Typing values by hand is also good.
Einstein
Postby malthuviusrex8 » Sat Apr 21, 2018 3:37 am
I have a bit of a problem... The plugin was working perfectly fine for a bit, but then I must've either pressed some quick key accidentally or inadvertently changed an unknown setting, because suddenly now the grass isn't showing up; no preview, no end result, nothing.
I've moved a bunch of sliders trying to get it back, to no avail. The 'show preview' option is checked. I'm pretty sure it's not making the grass at all, since, when it does my slow pc will slightly lag, (this is aside from the fact that pressing 'Make Fur' does nothing) and now it shows no difference.
What the heck is happening?! :twisted: I've tried changing many of the options in the dialog box... but nothing changes.
This was working perfectly fine, and is a wonderful plugin. I really could use help. :mrgreen:
Thank you!
malthuviusrex8
Postby jeff1harmed » Sun Apr 28, 2019 7:56 pm
Thanks. I'm mainly using the crowd maker and I have found it very useful.
I've used it to make a jungle of kelp. This was straightforward although I had to play around with the parameters to get the correct density. (see https://3dwarehouse.sketchup.com/model/ ... fish-props) Then I tried it on a shoal of fish and this was slightly different. With face-me components they all swim in the same direction, no problem. However, with 3D models I had to move them forward and behind manually, but the plug-in was still a big time-saver.
Then I tried the crowd maker on vegetables packed in crates. Again I had to move components into rough grids but It still saved time. (see https://3dwarehouse.sketchup.com/model/ ... able-props ). Very interesting plug-in.
I would suggest alphabetically ordering components in your drop down list. as in its current (first-in first out) state, it takes some time to find one amongst many.
jeff1harmed
Postby MoonDragon2009 » Mon Feb 03, 2020 7:10 pm
Hi, thank you so much for this add-on.
Since I saw that there are translations in various languages, I translated the language file into Italian, if you want to include it in the next version.
Nice work! :knockout:
MoonDragon2009
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: Cris5556, Grauer, inlimine, Kaffles, malagontravecedo, maryamalavi, migajaspalmer1, tharaB and 22 guests
Visit our sponsors:
