Redraw a dynamic component
Postby TNTDAVID » Sun Oct 22, 2017 3:51 pm
Hello, :D
The code below redraws the instance 0 named with the definition "BOX".
Code: Select all
model = Sketchup.active_model
model_definition = model.definitions
model_def = model_definition['BOX']
$dc_observers.get_latest_class.redraw_with_undo(model_def.instances[0])
How to redraw all the instances being selected without taking their definitions into account?
Thank you
David
* Nouveau !!!
Découvrez notre nouveau Plugin Click-Cuisine 2, pour créer vos cuisines 3D !
User avatar
TNTDAVID
PluginStore Author
PluginStore Author
Re: Redraw a dynamic component
Postby TIG » Sun Oct 22, 2017 3:57 pm
Something like
Code: Select all
Sketchup.active_model.selection.grep(Sketchup::ComponentInstance){|i|
  next unless i.definition.attribute_dictionaries["dynamic_attributes"]
  $dc_observers.get_latest_class.redraw_with_undo(i)
User avatar
Global Moderator
Postby TNTDAVID » Sun Oct 22, 2017 4:01 pm
I get the following error message with your TIG example:
Error: #<ArgumentError: wrong number of arguments (1 for 0)>
<main>:2:in `attribute_dictionaries'
<main>:2:in `block in <main>'
<main>:1:in `each'
<main>:1:in `grep'
<main>:1:in `<main>'
-e:1:in `eval'
nil
* Nouveau !!!
User avatar
TNTDAVID
PluginStore Author
PluginStore Author
Postby TIG » Sun Oct 22, 2017 4:05 pm
Sorry, I adjusted the () to []. I can't actual test this code as I type it !
User avatar
Global Moderator
Postby TNTDAVID » Sun Oct 22, 2017 6:09 pm
Thank you TIG! :D
This solution will give me even more possibilities in the future with the dynamic components. :thumb:
* Nouveau !!!
User avatar
TNTDAVID
PluginStore Author
PluginStore Author
Postby TNTDAVID » Tue Oct 24, 2017 1:53 pm
I found with some tests that it is not possible to add dynamic attributes to neutral components.
The component must have at least an existing attribute for it to be possible to add attributes in ruby.
If not, we have this error message:
Error: #<NoMethodError: undefined method `[]' for nil:NilClass>
<main>:1:in `block in <main>'
<main>:in `each'
<main>:in `grep'
<main>:in `<main>'
-e:1:in `eval'
nil
The goal is certainly to protect the creation of dynamic components, which is only available in Pro version of SketchUp?
* Nouveau !!!
User avatar
TNTDAVID
PluginStore Author
PluginStore Author
Postby TIG » Tue Oct 24, 2017 1:55 pm
Without us seeing your code it's impossible to say what raises your error message.
Perhaps adding an extra test before testing for the DC attribute dictionary [] entry
as the first test will stop it failing, since the DC dictionary can't be tested for without the existence of the attribute dictionaries entry.
User avatar
Global Moderator
Postby TIG » Tue Oct 24, 2017 2:06 pm
You can create a new dictionary thus
Code: Select all
some_definition.set_attribute("dynamic_attributes", "test", "1")
p some_definition.attribute_dictionaries["dynamic_attributes"]
User avatar
Global Moderator
Postby TNTDAVID » Tue Oct 24, 2017 8:58 pm
Sorry TIG for not having specified the method used.
I tried these 2 methods:
Code: Select all
i.set_attribute 'dynamic_attributes','teste', '1'
Code: Select all
i.set_attribute("dynamic_attributes", "test", "1")
i.attribute_dictionaries["dynamic_attributes"]
None of the 2 solutions work on a component without dynamic attributes.
<main>:in `each'
<main>:in `grep'
<main>:in `<main>'
-e:1:in `eval'
nil
But these 2 solutions work on components already have dynamic attributes.
* Nouveau !!!
User avatar
TNTDAVID
PluginStore Author
PluginStore Author
Postby TIG » Tue Oct 24, 2017 9:26 pm
The attributes belong to the instance's defintion NOT the instance.
You mess up trying to set things to the instance, NOT the definition !
Try substituting something like...
Code: Select all
i.definition.set_attribute('dynamic_attributes', 'teste', '1')
Please learn the difference between a definition and its instance !!!!!
User avatar
Global Moderator
Postby TNTDAVID » Tue Oct 24, 2017 9:56 pm
This still does not work for components without attributes:
Code: Select all
* Nouveau !!!
User avatar
TNTDAVID
PluginStore Author
PluginStore Author
Postby TIG » Tue Oct 24, 2017 10:34 pm
WTF !
You really must learn basic principles...
consider this:
Code: Select all
###next unless i.definition.attribute_dictionaries["dynamic_attributes"]
The added ### skips the check for the dictionary [ which you do NOT need ! ]... so IF a definition does NOT have that dictionary set then it makes it anyway !!!!!!
User avatar
Global Moderator
Postby TNTDAVID » Wed Oct 25, 2017 5:53 pm
OK TIG, I understand!
The Ruby is very wide and has many instructions such as:
!,&&,||,and,box,else,elsif,eql?,equal,if,then,not,gold,require,unless,wheen,true, false...
I had not yet read "unless".
I realize that it takes many years of Ruby to totally understand him master it.
As I learn according to my needs, this undoubtedly slows down my general understanding of ruby.
Promised, next time I would make more effort with your examples before publishing it does not work. ;-)
Ps: Your solution works wonderfully TIG
Thanks a lot for your help.
David
* Nouveau !!!
User avatar
TNTDAVID
PluginStore Author
PluginStore Author
Postby TNTDAVID » Thu Oct 26, 2017 4:53 pm
Hello, :enlight:
I now want to refresh the visible dynamic components.
If not, the answer must be "nil".
The methde below works for components that are not nested:
Code: Select all
m=Sketchup.active_model;
s=m.selection;
m.definitions.each{|d|s.add d.instances if d.name=~/#{"BOUTON"}/}
s.grep(Sketchup::ComponentInstance){|i|
next if i.hidden?
Oddly if the components with the "BOUTON" definitions, are nested in another component, they will be considered as visible even if they are hidden.
Do you know what is the problem?
Thank you
* Nouveau !!!
User avatar
TNTDAVID
PluginStore Author
PluginStore Author
Postby TNTDAVID » Sat Oct 28, 2017 2:54 pm
I solved the problem of my previous post!
Now, I'm facing another problem that is much more difficult to solve.
The code below adds an attribute to all the "Handles" definitions that are visible in the components being selected.
Code: Select all
def handlesCI(ents)
    sel = Sketchup.active_model.selection
    ents.each do |e|
    if e.is_a? Sketchup::ComponentInstance
    sel.add e if e.definition.name=~/#{"HANDLES"}/
    handlesCI(e.definition.entities)
    sel.grep(Sketchup::ComponentInstance){|i|
    next unless i.visible?
    i.set_attribute 'dynamic_attributes','attribut', '1'
This method does not work to refresh only visible components.
Code: Select all
def handlesCI(ents)
    ents.each do |e|
I need your help to understand the problem.
Thank you
David
* Nouveau !!!
User avatar
TNTDAVID
PluginStore Author
PluginStore Author
Postby TIG » Sat Oct 28, 2017 8:41 pm
Please stop adding entities into the selection.
What happens if it already contains some selected entities ?
You haven't cleared it ??
Also these additions might not be in the current context and cause various issue down the line...
Simply create an empty array and add entities to that if they meet a certain test.
e.g.
Code: Select all
def handlesCI(ents)
  array = []
  ents.grep(Sketchup::ComponentInstance).each{|e| ### collect only visible instances
    next unless e.visible?
    array << e if e.definition.name =~ /#{"HANDLES"}/
    handlesCI(e.definition.entities) ### repeat for nested entities in visibles
  array.each{|i| ### process this array of instances
User avatar
Global Moderator
Postby TNTDAVID » Sun Oct 29, 2017 3:17 am
Your method works TIG, but it does not keep the "Handles" definitions selected.
The goal is to update all Invisible Handles, then select any definition "Handles" without visibility restrictions.
* Nouveau !!!
User avatar
TNTDAVID
PluginStore Author
PluginStore Author
Postby TNTDAVID » Sun Oct 29, 2017 1:33 pm
Here I am in a paradox!
If I apply your TIG method, the handles selected in Method 2 will also be redrawn.
Code: Select all
def methodeTIG(ents)
    array = []
    methodeTIG(e.definition.entities) ### repeat for nested entities in visibles
def methode2(ents)
    ents.each do |e|
    methode2(e.definition.entities)
def methode_end
    methodeTIG(instances)
    methode2(instances) ### The handles of this method are drawn by the methodTIG!
How can I avoid this?
Thank you
* Nouveau !!!
User avatar
TNTDAVID
PluginStore Author
PluginStore Author
Postby TNTDAVID » Mon Oct 30, 2017 4:51 pm
I ended up bypassing the problem by selecting a different definition than "handles" in method 2.
I asked to select the IKEA definition, which corresponds to the furniture that contains the facades and the handle inside.
Code: Select all
def ikeaCI(ents)
    ents.each do |e|
    sel.add e if e.definition.name=~/#{"IKEA"}/
    ikeaCI(e.definition.entities)
This is possible because I specified the definition of the highest components of the hierachie.
Is it possible to select the highest components of the hierarchy without specifying the name of that definition?
Thank you TIG for your method that allows me to redraw the visible handles. :thumb:
* Nouveau !!!
User avatar
TNTDAVID
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Developers' Forum
Who is online
Users browsing this forum: No registered users and 2 guests
Visit our sponsors:
