Extension Store v3.0
Share or learn with the Pros
Re: Extension Store v3.0
Postby facer » Tue Apr 18, 2017 1:57 am
REQUEST:
It would be helpful to SEE the LOADED sets assigned.
Sets often reflect a set workflow for stages as Sketch Design, Design Development etc.
During the use of SketchUp, extensions/plugins are often added or removed to assist
specific current activities or issues.
When returning to the project it would be helpful to RESET the
WORKING SET - assigned to a given workflow. This would help others using
the same SketchUp file.
Thank you again for all the Teams work on the Extension Store.
User avatar
facer
Premium Member
Premium Member
Postby filibis » Thu May 04, 2017 9:41 am
I mostly downloaded my plugins & extensions manually and realized benefits of Extension Store lately. So is there any way to make it 'recognize' my plugins or should i download them all one by one via Extension Store :ecstatic: ?
Also can Extension Store detect plugins in my path (plugin folder) whether they're available in Sketchucation or not? (Thus, i can distinguish -that i gathered from other sources- easily and zip them)
This question is also asked at the end of this Bundles tutorial and didn't receive any reply.
Besides i have no idea how Plugin-sets work. I created a set but don't know how to add/remove plugins to that set (and i don't know which plugins are applied to my set). Is there any info on that?
User avatar
filibis
Postby Rich O Brien » Thu May 04, 2017 9:47 am
We can't detect anything outside so you need to use it to create a history.
There's a new version of the store coming where we want to offer more in terms of allowing users to add external extensions links into the store. So if there's a scenario where someone finds something they think the community would like to know about you could submit a listing.
You will also be able to create Collections that you could share with others that allows them to install a set of tools you curate as needed for a certain task.
We also want some type of 'Ask' scenario. If you wanted to know how to do A+B then members can reply with their solution.
3
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby powermta » Thu Aug 24, 2017 4:47 pm
Seems great, i hope it still works
powermta
Postby Bob James » Sat Aug 26, 2017 9:43 am
May 04, 2017
"There's a new version of the store coming "
August 26, 2017
:?: :!: :fro:
User avatar
Bob James
Premium Member
Premium Member
Postby gudio83 » Fri Oct 06, 2017 9:46 pm
Hello, I have a problem with the sketchucation plugin store.
I've installed the plugin on my new PC (Windows 10 x64, SU2017 - fresh install of both)
but when I click on "autoinstall", I choose the default plugin folder, after that it show me:
UNZIP ERROR: COULD NOT UNZIP ARCHIVE.
How can I resolve this?
User avatar
gudio83
Postby Rich O Brien » Fri Oct 06, 2017 9:47 pm
gudio83 wrote:Hello, I have a problem with the sketchucation plugin store.
Are you using the latest version? v3.1.3
User avatar
Rich O Brien
Administrator
Postby gudio83 » Sat Oct 07, 2017 4:14 pm
Absolutely. I''ve tried with 3.1.3 and 3.1.2
I've removed it by extension manager, the other time manually from plug-in folder.
I've installed latest JAVA (JRE) and now sketchucation plugin saved my login and I don't have to write my account information every time when I start Sketchup.
Maybe I have no any .Net or Microsoft Visual package to run plugin working correctly ?
User avatar
gudio83
Postby TIG » Sat Oct 07, 2017 5:51 pm
Can you try repairing your SketchUp installation...
Close SketchUp.
Find the SketchUp installer exe file - probably in your Downloads folder - if not download a new copy.
Select the installer exe file's icon.
Right-click > Context-menu
"Run as administrator"
When prompted choose to "Repair"
When you restart SketchUp is it any better ?
Having SketchUp installed in anything but the exact and proper way can cause all sorts of flakiness.
Also try checking your Control-Panel > Internet Options are not set to be too strict and that javascript is set to run [Java is not the same thing].
User avatar
Global Moderator
Postby gudio83 » Sat Oct 07, 2017 6:00 pm
Additional info: Trying to install plugins:
- 3D Text Editor by thomthom (I click install on sketchucation extension store): installed successful.
- TT Library by thomthom (I click install on sketchucation extension store): unzip error.
2 rbz plugins from the same author.
Maybe there is a little bug?
User avatar
gudio83
Postby gudio83 » Sat Oct 07, 2017 6:25 pm
TIG wrote:Can you try repairing your SketchUp installation...
Close SketchUp.
Thanks for support, the results are:
1. I've repaired SU as administrator (I've removed sketchucation plugin manually before) and installed the plugin after repair process. Same result
2. I've uninstalled SU, removed sketchucation plugin manually from plugin folder. Reinstalled SU as administrator. Same result
3. I've updated Windows and I've repeated the steps from above. Same result.
User avatar
gudio83
Postby Ruuds » Thu Oct 19, 2017 1:44 am
Hi guys, my Extension Store window is goes of screen and behind the taskbar... how do i fix that? I cant use the search funktion because its at the bottom of the window :(
Ruuds
Postby TIG » Thu Oct 19, 2017 11:20 pm
Try to resize from maximum ?
Or grab a corner and when the cursor shows it drag to resize, the move onto the window so you can see it all ??
User avatar
Global Moderator
Postby Ruuds » Mon Oct 30, 2017 9:38 pm
TIG wrote:Try to resize from maximum ?
I cant grab a corner because its off screen under my taskbar,
Maximizing the window doesnt work either. it still causes the window to be behinde the taskbar.
Ruuds
Postby mariocha » Fri Nov 10, 2017 5:07 pm
As you probably know, I, more often than not, lead my students to Sketchucation and the plugin store.
Out of the many, bad surprise, one of them has a dialog pane with no icons at all at the bottom. The pane is well fitted in the screen, not over sized in height.
Anyone had that ?
Can this be caused by the company (big) protection filters ?
Win 10.
Mario C.
Certified SketchUp Trainer, QC CA.
Every rule has exceptions, but some.
User avatar
mariocha
Premium Member
Premium Member
Postby Rich O Brien » Fri Nov 10, 2017 5:10 pm
mariocha wrote:As you probably know, I, more often than not, lead my students to Sketchucation and the plugin store.
Anyone had that ?
Win 10.
It could be because we serve the icons over CDN from FontAwesome. It is a font stack and Untrusted Font Stacks can be blocked in networked environments.
User avatar
Rich O Brien
Administrator
Postby CalypsoArt » Thu Nov 23, 2017 8:22 pm
I usually install my plugins through bundles in Extension Store. I did this for 2018 on my work machine and had no warnings or errors. (Except for Scalp 2 which the company says will never be compatible with 2018.)
On my home machine I used the Trimble Extension warehouse to install plugins. This listed several as "Not compatible" with 2018. FredoScale and several others I use a lot were listed as such.
First, is Extension Store 3 compatible with SU 2018? Second, is the Trimble Extension warehouse accurate in saying extensions are not compatible?
CalypsoArt
Premium Member
Premium Member
Postby TIG » Thu Nov 23, 2017 8:42 pm
The ExtensionStore³ is compatible with v2018.
However, each of the installed Extensions themselves need to be compatible !
All of Fredo's RBZs have been updated for v2018 compatibility.
But you need to install the latest versions [including his Lib] from the ExtensionStore³.
If, in the SketchUp native Extension-Manager, an Extension is listed as 'unsigned' or having an 'out of date signature', then this does not necessarily mean that it is incompatible with v2018.
It may well work anyway - provided that the 'Extension Loading Policy' is set to be Unrestricted, so that it can load.
So why not try and see ?
Some Extensions have never been signed, and some were signed for v2016 use and not updated- the signing process changed with v2017 so the 'out of date' can appear...
It is a disproportionate onus on many authors of free extensions - who might have to get them [re]signed and republished, when they'll probably work anyway - provided SketchUp's 'Extension Loading Policy' is set up sensibly...
User avatar
Global Moderator
Postby Paul Russam » Tue Jan 16, 2018 11:22 am
I'd like to request that all my bundles are deleted, my list is a little confusing due to a couple of system rebuilds I'de had to do recently.
Paul Russam
English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
User avatar
Paul Russam
Premium Member
Premium Member
Postby Gábor » Tue Jan 16, 2018 11:28 am
Paul Russam wrote:I'd like to request that all my bundles are deleted, my list is a little confusing due to a couple of system rebuilds I'de had to do recently.
Hi Paul,
I've deleted your bundles as requested. Please check.
Gábor
SketchUcation IT
Postby Paul Russam » Tue Jan 16, 2018 11:31 am
Bingo! Thanks, I can now see where I'm at
Paul Russam
User avatar
Paul Russam
Premium Member
Premium Member
Postby bedavisdesign » Thu Mar 08, 2018 7:36 pm
Install icon/link/button in extension store not working for me. Please help! I'm sure there's something simple that I am doing wrong.
I hope this is the right place to post this. Using SU 15.3.331 and I believe I am properly logged/signed in to both sketchup and sketchucation. I'm going to the Extension Store 3.0 and I am wanting to download/install a plugin/extension. When I click on an install icon for any extension, it does nothing. This is what I thought I am supposed to do to install a new extension.
For example:
S4U Line Tool 1.5.0 .... the "info" icon/link works, the "donate" icon/link works, the "install" icon/link does NOT work for me.
***If I click on the "info" icon for this extension it properly opens http://sketchucation.com/forums/viewtop ... 23&t=61735 in my browser.
***When I click on the "install" icon for this extension, it does nothing. No response, no pop up, no downloading.....,
***If I click on the "donate" icon for this extension it properly opens https://www.paypal.com/vn/cgi-bin/websc ... 35f75fdfb7 in my browser.
What am I doing wrong?
bedavisdesign
Postby TIG » Thu Mar 08, 2018 8:23 pm
Check that sketchucation.com is properly white-listed in your firewall settings.
Also try clearing the cache in Internet Explorer - although you might not use it as a day-to-day browser SketchUp's WebDialogs do use it on a PC...
Also originally you might not have installed SketchUp in the approved manner ?
Try this...
Close SketchUp.
Find the installer exe file [in Downloads ?].
Select its icon and right-click > context-menu >
'Run as administrator'...
When prompted choose 'Repair'
This will reset various flaky settings, which can appear in an installation that is not quite perfect.
Having admin powers and running the exe in other ways - like double-clicking on its icon - can seem to work, but can give all kinds of unpredictable weird issues later on...
User avatar
Global Moderator
Postby bedavisdesign » Thu Mar 08, 2018 9:01 pm
Thanks TIG! I'll give it a go.
bedavisdesign
Postby vinniciusgrangeiro » Tue Apr 10, 2018 6:19 pm
bedavisdesign wrote:Install icon/link/button in extension store not working for me. Please help! I'm sure there's something simple that I am doing wrong.
For example:
Hello! I have the same problem.
There is no action after I click the Install button.
The Donate and Info buttons work perfectly.
I also can not insert the Clothworks plugin license through SCFLicense. The SCFLicense window does not open after
I believe these problems may be related.
I've reinstalled SketchUp in the 2017 and 2018 versions, disabled Windows Firewall, and the problem happens again.
The same thing happens on the other 3 computers in my office.
vinniciusgrangeiro
Postby Rich O Brien » Wed Apr 18, 2018 2:16 pm
vinniciusgrangeiro wrote:What am I doing wrong?
Can you try the latest release of SketchUcation Tools? Version 3.1.5 was put out today to address many niggling issues around ASCII characters and other issues regards Mac OS.
User avatar
Rich O Brien
Administrator
Postby kiwi15 » Wed May 02, 2018 12:36 pm
I had ExtensionStore v3 installed on my Mac su2018 pro. Then I found out that the "My Shortcuts" window turned up empty. Therefore I went online to see if I had an outdated ExtensionStore-issue, and found the new V3.1.5 release that thankfully solved all my problems. ...I just think it would be an idea to add some way of telling us when we do have an outdated ExtensionStore version inside of SketchUp somehow without us having to go check out the website manually.
kiwi15
Premium Member
Premium Member
Postby Rich O Brien » Wed May 02, 2018 12:38 pm
kiwi15 wrote:Hi,
Yeah, v4 will have that. Large amounts of people still use v2 which is getting retired this year.
User avatar
Rich O Brien
Administrator
Postby B2Pi » Mon Jun 11, 2018 9:19 pm
I can't find a reference to this within the forum, but I'm unable to get the Sketchucation ExtensionStore (v3.1.5) working within Sketchup 2017 Make under Wine. Attempting to log in gives "Some error occured please contact the administrator at sketcucation.com". The ruby console helpfully displays nothing
I'll grant that it's not the only problem I'm facing right now (I also can't get cutlist to work, but that's later).
Cheers
B2Pi
Postby Rich O Brien » Tue Jun 12, 2018 9:36 am
We've never tested it on Linux to be honest. Linux SketchUp users are rare as hen's teeth.
User avatar
Rich O Brien
Administrator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to SketchUp Tutorials
Who is online
Users browsing this forum: No registered users and 3 guests
Visit our sponsors:
