General discussion about Animator for SketchUp
by fredo6 » Thu Aug 17, 2017 8:42 am
With Animator 1.7c and LibFredo6 7.7c, Animator provides a first support of VRay for rendering animations from within Animator. I have tested it with VRay 3.40.04. If you have VRay installed in Sketchup, you should see the VRay button in the Rendering options Animator - VRay option.png At the moment, there is the small inconvenience that the VRay Rendering Window pops up at each frame rendering, on top of all other windows, even if you minimize it. The VRay Status Window also pops up, but there is an option to hide it. Hopefully, this should be fixed in a next version. Please use this thread to report any issues or suggestions. Fredo
- PluginStore Author
- Name: Fredo6
- Operating system: Windows
- SketchUp version: 2018
- License type: Pro
- SketchUp use: interior design
- Level of SketchUp: Intermediate
by ithil » Thu Aug 17, 2017 9:08 am
ithil
- Name: Ithil
- SketchUp version: 2015
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by fredo6 » Thu Aug 17, 2017 9:51 am
ithil wrote:Wow Great news! =) Thank you so much.
Special thanks to you for your help in this integration. Fredo
- Name: Fredo6
- License type: Pro
by Mousa_SA » Thu Aug 17, 2017 10:41 am
Awesome, great job for both of you
Mousa_SA
- Name: Mousa Abu Doush
- License type: Pro
by cuttingedge » Thu Aug 17, 2017 3:03 pm
This is really exciting news...I would love to see samples soon from our Vray masters.
cuttingedge
- Name: cuttingedge
by jiminy-billy-bob » Fri Aug 18, 2017 8:34 am
Great!
jiminy-billy-bob
- Name: jiminy-billy-bob
- SketchUp version: 2014
- License type: Pro
by Spartipilo » Sun Sep 24, 2017 8:23 am
Hello! New on this forum. I'm not sure if this is the place to post this problem, but here it goes.
I had a problem with Animator and Vray rendering. I set the animation to last 10s, at 30fps. Left it to render for 8 hours overnight, but I ended up with only 86 out of 300 frames on the render folder. It skipped 3 out of 4 frames (names goes 1, 4, 7, 10, 13, 16...). I configured Vray to save the output renders in another folder, but they weren't saved.
I'm not sure if the missing frames were rendered and not saved, or not rendered at all.
Spartipilo
- Name: Santiago Partipilo
- License type: Free/Make
by fredo6 » Sun Sep 24, 2017 7:08 pm
Spartipilo wrote:Hello! New on this forum. I'm not sure if this is the place to post this problem, but here it goes.
There is a problem with Vray, which tends to re-use the previous path when saving image files with the same name as images generated previously. I fixed the problem in the latest version of LibFredo6 (as of 7.7d). Did you try with this version. Also a good practice when generating a video is to test the video after a few frames. You have a button for that. If OK, you can then resume the generation, or otherwise cancel it. Fredo
- Name: Fredo6
- License type: Pro
by Spartipilo » Sun Sep 24, 2017 8:49 pm
Hi Fredo, thanks for your answer. I updated the Lib and Plugin to latest versions, still had to do some work to set things up, but managet to get a full frame rendering using Timed progressive and 45fps (With 30fps was still missing some frames). Rendering with BF + LC at 1080x1080, only with sun and camera transition based on SU Scenes. This is the result: https://www.youtube.com/watch?v=vFEP59sEp9I Only problem now was the camera shaking, any way to rework that? On a side note: I was using a very far Omnilight to do a 360° "FakeSun" rotation with it, along with a HDRI on a Domelight. It worked, but once I set the path for the "FakeSun" Omnilight, all the scene got clipped, Couldn't recover it back, had to build it on a new file w/o the "FakeSun"
Spartipilo
by fredo6 » Sun Sep 24, 2017 8:53 pm
Good. I think VRay (Chaos group) should fix the problems with image files in a next release.
Regrading the camera shaking, do you get it when you do 'natural' generation (i.e. without rendering)?
- Name: Fredo6
- License type: Pro
by filibis » Wed Oct 11, 2017 9:12 pm
Hi Fredo, I can confirm that camera shaking happens in Vray output with default settings (MP4,MPG,AVI,GIF) but it's fine with 'Natural' rendering.
filibis
- Name: Emir Sinan GÜRLEK
- SketchUp version: 2017
- License type: Pro
by fredo6 » Thu Oct 12, 2017 6:02 pm
filibis wrote:Hi Fredo, I can confirm that camera shaking happens in Vray output with default settings (MP4,MPG,AVI,GIF) but it's fine with 'Natural' rendering.
So this must be related to Vray processing. I made some tests, but with my models and do not get the jerky effect. Actually Animator juts calls the Vray API, so it does not control what VRay does. Maybe you can PM me the model, so that I try. Fredo
- Name: Fredo6
- License type: Pro
by fredo6 » Sun Dec 10, 2017 1:13 pm
As you may have noticed, Animator was no longer compatible with VRay 3.6 (but was for VRay 3.4). I updated the code to support VRay 3.6. You just need to upgrade to LibFredo6 8.0c (no need to change Animator). This new version allows to start the rendering with VRay. HOWEVER, I noticed that there might be a freeze of Vray and Sketchup after rendering a number of frames. I am in contact with Chaos Group about that. So, if this happens to you, please advise in this Thread. Fredo
- Name: Fredo6
- License type: Pro
by Schuppe » Mon May 07, 2018 7:49 pm
Hi Fredo Five month since your last post. I love to work with Animator since 3 weeks ( i am scratching the surface for now  ). I render with ambient occlusion and no problems. Its okay but with v ray it would make lot more fun. Few days ago i gave v-ray 3.6 a chance to render a 200 frame animation. After ca.30 frames its frozen. I expected that but there was a little hope it would do the job. Is there hope for the future that chaos group can/want/will fix that problem? Or is it a dead end with v ray 3.6 or can you do something on your software-side? Schuppe offtopic ( i am struggling with the Positioner save/load. What the hell is the correct USE of this two buttons and theyre managements. I´ve read and seen all about it and finally dont understand- but this is another story, lol - for now i dont touch this buttons and work without them ...like a lot of other users i strongly believe)
Schuppe
- Name: Schuppe
- SketchUp use: hobby
- Level of SketchUp: Beginner
by fredo6 » Mon May 07, 2018 9:03 pm
@Schuppe
For Vray 3.6, I did not get any feedback from Chaos Group. Currently the integration with VRay is based on their existing API for static rendering, and thus suffers from some limitations and problems when used in sequence on a large number of rendering jobs.
As a general statement, there is little traction concerning Animation plugins in Sketchup (not just Animator by the way), and thus this is not a primary target for rendering software. The Reverse method where the rendering software manages the animation is also supported by Animator via its API, but requires some work. Only Thea has implemented it.
The only thing that I will do in a coming release is to enable partial regeneration of frames, so that hopefully, the video can be completed, even in several passes.
Regarding the Positioner: The concept is to save the positions of all objects in the model under a given name and be able to recall later these positions. So one icon is for for Save, the other is for Load. The information is stored in the model. In essence, this is independent from Animator itself. I introduced Positioners as a safety net in case the animation is messed up (bug or other issues). So it is advised to save a clean position of objects once, before playing with Animator.
In the new version 2.0, I have merged all management operations related to Positioners under one single icon and dialog box, where you can load, save, delete, change name and replace positioners.
- Name: Fredo6
- License type: Pro
by Schuppe » Tue May 08, 2018 5:42 pm
Thanks Fredo for your precise answer, i appreciate this. The Chaos Group is a company and sketchup/Animator users are potential customers of their products. If i send a email to them, nothing will happen. But if the comunity start a, lets say " Online-Petition " and lots of people protect/sign this and send it to Bulgaria, maybe they hear us and think about it to implement a reverse method or even more. Dont know how to set up such a "online-petition". But maybe some of the persons who are reading my post could help. I think its worth a try..... Thanks for now Fredo Have a nice day
Schuppe
Schuppe
- Name: Schuppe
by dihe » Wed Aug 08, 2018 6:25 pm
Hi there, I prepare whole animation. view port size is 1541x891 px. When I made it smaller evtyhing is OK but when i made it 1920x1080 all frames are render but file want save. Have you any idea why, and how to fix it?
dihe
- Name: dihe
by fredo6 » Wed Aug 08, 2018 6:32 pm
dihe wrote:Hi there, I prepare whole animation. view port size is 1541x891 px. When I made it smaller evtyhing is OK but when i made it 1920x1080 all frames are render but file want save. Have you any idea why, and how to fix it?
Can you try the Test Image button, to see if the file is generated Fredo
- Name: Fredo6
- License type: Pro
by dihe » Wed Aug 08, 2018 6:57 pm
unfortunately when I test render stop
When I use material override evrything is OK, and render in HD is done. Btw. I change in VRay asset editor higher resolution then 1920x1080
dihe
- Name: dihe
by dihe » Thu Aug 09, 2018 9:57 am
I made test on slower PC borh have Vray 3.6.03 first SKP 2018 secound SKP2017. On slower animator/vray only build light chach and want't render. On faster I made a few more tests and even I made slower resolution test render stop in 3/4. Maybe it is timeout? Have you any idea how to fix it? I don't know why it render scene correctly with material override? Maybe some kind of material crush vraya. But in normal work evrything is OK. Thank you in advanced. Jarek
dihe
- Name: dihe
by dihe » Thu Aug 09, 2018 10:30 am
Highest resolution which finished correctly is 1270x714px. If 1280x720 is setting up vray leave one squere with no rendered pixels... if resolution grow numbers of not rendered pixel is higher... Btw. If I setup in Animator 1270x714px the resolution in vray asset editor also change. But when i made it 1920x1080 resolution in asset editor didn't change...
dihe
- Name: dihe
by snop2205 » Sat Aug 11, 2018 8:41 pm
Hello Fredo! Thank you for all your Hard work! I have the same problem with the plugin as dihe have. The computer stops in the middle of rendering at high resolution and does not save the image. in low-resolution the computer finishes rendering and saves Is there a time out for each render?
snop2205
- Name: snop
- SketchUp version: 8
- License type: Pro
by snop2205 » Tue Aug 14, 2018 11:31 am
fredo6 wrote:dihe wrote:Hi there, I prepare whole animation. view port size is 1541x891 px. When I made it smaller evtyhing is OK but when i made it 1920x1080 all frames are render but file want save. Have you any idea why, and how to fix it?
snop2205
- Name: snop
- License type: Pro
by fredo6 » Tue Aug 14, 2018 11:32 pm
For info, this was due to a time out set for VRay at 2 minutes for rendering.
With LibFredo6 v8.5f, I have increased the time to 10 minutes.
- Name: Fredo6
- License type: Pro
by dihe » Fri Sep 07, 2018 10:04 pm
Hi Fredo, could you add rendering exact frame fe. 165,166,175...
I have problem because now I need to render fram in "secounds" time, and somtimes when I render something simultaneously with animation render I have time out and freame wan't save.
dihe
- Name: dihe
by Immortalis » Thu Sep 20, 2018 6:22 pm
I have a problem with rendering with vray. When I render an animation, it never lets it finish the rendering. After prepass 1of1 is finished, and actual rendering should start, animator just ends the rendering of that frame and continues on another frame. And happens for every frame, until it is stuck on one frame, and after that frame is finished rendering, another frame can't start render.
How to solve this? Thanks
Immortalis
- Name: Immortalis
- License type: Pro
by pejot11 » Thu Oct 04, 2018 11:55 am
Hello Fredo,
thank you for this great extension. Is it possible to set the time out higher than 10 minutes? I would like to render in higher resolution, but every time a frame needs more than 10 minutes this frame is not saved.
Thank you.
pejot
pejot11
- Name: Patrick
by williamj » Wed Nov 21, 2018 1:50 pm
Hi Fredo6,
Love your work firstly. Your extensions are really useful.
Can I echo the same as a couple of people on here? I'm using SU2018 and Vray 3.6(something)
1. Im trying to render an animation where the frames take longer than 10 mins. Is there a way to change the timeout manually, or, is there a reason why were limited to 10 mins?
2. Being able to stop a big render and start again at the exact frame that it left off would be amazing, is there a way to do this?
Keep up the good work and thank you again.
williamj
- Name: William Jonkler
- License type: Pro
- SketchUp use: event and conference planning
by Macon » Sat Dec 01, 2018 9:30 am
Bonjour
Je viens de découvrir ce qu'il était possible de faire. Je trouve cela fantastique, un grand merci à tous ceux qui ont pris le temps de faire une chose pareille!
Une petite question cependant: est il possible de réaliser l'animation d'animator à un moment précis d'une animation de scènes Sketchup? Par exemple Lors d'une visite virtuelle d'une maison, nous traversons un couloir (scènes SU ) avant d'arriver devant une porte qui s'ouvre (animation Animator) et continuons la visite (scène SU). En passant le tout dans Vray....
Un grand merci à tous ceux qui pourront me répondre!
Cordialement
Macon
- Name: Pascal
- License type: Pro
- SketchUp use: woodworking
by fredo6 » Sat Dec 01, 2018 12:33 pm
Macon wrote: Une petite question cependant: est il possible de réaliser l'animation d'animator à un moment précis d'une animation de scènes Sketchup? Par exemple Lors d'une visite virtuelle d'une maison, nous traversons un couloir (scènes SU ) avant d'arriver devant une porte qui s'ouvre (animation Animator) et continuons la visite (scène SU). En passant le tout dans Vray....
This is a feature that is planned. Actually, I introduced the concept of 'Visitor' in earlier versions, but this needs a lot more work to make it usable. SO it is deactivated for the time being. Fredo
- Name: Fredo6
- License type: Pro
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Animator Beta
