Spiral Doric Column
Share or learn with the Pros
Spiral Doric Column
Postby chippwalters » Sun Aug 13, 2017 9:12 am
A quick video on how I use some of my favorite Fredo (and others) plugins to create a simple spiral doric column.
Plugins used:
FredoScale
Curviloft
CleanUp
Set Center Point
Ambient Occlusion
FDD
8
User avatar
chippwalters
Premium Member
Premium Member
Re: Spiral Doric Column
Postby HornOxx » Sun Aug 13, 2017 10:56 am
:thumb: x 5
Impossible to give 5 thumbs up by simply clicking them :D so I give them this way!
many thanks for this most helpful tutorial !
btw: so finally I rediscovered my FDD plugin within my context menu :D
User avatar
HornOxx
Postby nlipovac » Sun Aug 13, 2017 2:56 pm
Great tutorial Chipp!
Thank you. :-)
nlipovac
Premium Member
Premium Member
Postby Box » Sun Aug 13, 2017 3:02 pm
Just like to point out that the default for Move is M, not T.
And you don't need to use ctrl with follow me.
User avatar
Postby rv1974 » Mon Aug 14, 2017 8:46 pm
Chipp you're perfect educator. Keep them coming!
rv1974
Postby chippwalters » Tue Aug 15, 2017 5:14 am
Box wrote:Just like to point out that the default for Move is M, not T.
I set my default to T so it will match some of my other programs. Thanks for the tip on follow me...I seem to remember in previous versions you had to press the CTRL key in order for Follow-Me to work if you previously had selected the path.
User avatar
chippwalters
Premium Member
Premium Member
Postby Box » Tue Aug 15, 2017 5:25 am
I only mentioned the M versus T for users who may be watching your tutorial. T will bring up the tape measure by default and I can see beginners getting confused.
User avatar
Postby jim4366 » Tue Aug 15, 2017 2:37 pm
Nice. Thanks.
Quick question, does anyone know where to get the "set center point" tool?
This looks like something I simply must have.
jim4366
Postby HornOxx » Tue Aug 15, 2017 5:58 pm
jim4366 wrote:...where to get the "set center point" tool?...
Hi, here you can find it:
viewtopic.php?f=323&t=11081
It will add the entry "Add Centerpoint" in the Extension´s menu (no icon bar)
User avatar
HornOxx
Postby david_h » Tue Aug 15, 2017 8:08 pm
Fun little study. I have actually had all of these plugins in my arsenal for years, but sometimes you just forget to use em. Thanks for the tut.
If I make it look easy. . .then it probably is.
User avatar
david_h
Top SketchUcator
Postby jim4366 » Wed Aug 16, 2017 4:42 pm
got it, thanks
jim4366
Postby pbacot » Wed Aug 16, 2017 5:17 pm
Nice job. Thanks for the line up on plugins! The other day just tried doing a basic tuscsan column (not the first time)and entasis by brute force. I should have used FFD.
MacOSX (El Capitan) ShetchUp Pro v16 Layout Twilight Pro v2 M2 Kerkythea PowerCADD
User avatar
Top SketchUcator
Postby CAUL » Sun Sep 17, 2017 10:12 pm
pbacot wrote:Nice job. Thanks for the line up on plugins! The other day just tried doing a basic tuscsan column (not the first time)and entasis by brute force. I should have used FFD.
It's actually quite straight forward to construct a "canonical" entasis in Sketchup for any type of column - smooth or fluted. Canonical here means the recipe engraved in a wall at the temple of Apollo at Didyma (Turkey) some 2500 years ago. The method below is not exactly as described at the Temple of Apollo, but it's very, very close in practice.
Set out an arc with the Pie tool (as in the first image below). Scale this arc all the way to the top. The resulting elliptical curve is the shape of the entasis. The shaft is usually straight the first third of the height and the entasis is only applied to the top two thirds.
To construct an entasis on a fluted column it's possible to use Flowify twice. From the entasis curve, construct a quaded target surface. Construct a projection surface with the full width of the shaft and every quad with the exact same height as the corresponding quad on the target surface.
Connect and group the surfaces into a Flowify support group. Make a copy of the group and rotate it 90 degrees and place it as in the second image below. Flowify a fluted column through the first support group. Flowify the result through the second support group. The entasis is now applied to both the x and y-dimension. Merge the entasis part into the full column.
CAUL
PluginStore Author
PluginStore Author
Postby rv1974 » Mon Sep 18, 2017 6:57 am
Much closer to original :thumb:
rv1974
Postby chippwalters » Mon Sep 18, 2017 8:36 am
CAUL wrote:It's actually quite straight forward to construct a "canonical" entasis in Sketchup for any type of column - smooth or fluted. <snip>
I've done two different tutorials on Flowify and even I had a hard time following this, but it is an ingenious use of the tool!
User avatar
chippwalters
Premium Member
Premium Member
Postby Box » Mon Sep 18, 2017 8:56 am
Do mine eyes deceive me or is there no spiral.
User avatar
Postby CAUL » Mon Sep 18, 2017 10:18 am
I've added a highly exaggerated example file to show the basic principle.
CAUL
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Tutorials
Who is online
Users browsing this forum: Google Bot and 1 guest
Visit our sponsors:
