[Plugin] FredoTools::SolidVolume - v1.4a - 10 Feb 20
Cool!
And about the M2 surfaces faces?
No possibility to add this inside this one? -
Thank you Fredo! You are my hero! This should be incorporated in Sketchup 2016 to prevent people for making mistakes in volume calculations..In the meantime we have Fredo Sketchup.
I am sorry, but plugin has some kind of problem with the geometry you can see in the example. I didn't know the volume calculation problem was so complex.
That's just a bug which I will fix. As long as the shape is a true solid, there is an exact solution.
And the model must be made in the rules of art!
NEW RELEASE: FredoTools::SolidVolume v1.1c - 28 Apr 15
SolidVolume 1.1a is a release with a few enhancements:
- It now computes the faces area of solids in the selection.
- The volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner.
- You can choose your preferred unit and number of decimals for display of values
See main post of this thread for more information.
NEW RELEASE: FredoTools::SolidVolume v1.1d - 29 Apr 15
SolidVolume 1.1d is a release fixing a problem of display of the main dialog box.
NEW RELEASE: FredoTools::SolidVolume v1.2a - 09 Jul 15
SolidVolume 1.2a is a minor release allowing holes for a shape to be considered as a solid. The Volume is computed as if there was no hole, but the area of faces takes the holes into account.
Hi Fredo
I was so happy to find this plug in volumes, but it seems there is a problem with the volumes. i had a complex solid an found a volume that seemed very big. So i try with a small cube with an hole (20 cm for each side) and there is definitively a bug. see image
I downloaded the latest versions of LibFredo, FredoTools (09 Jul 17) and that is the same
anyway, thanks a lot Fredo for all your super plugins !
have a good week !
Alexandre
@alex37550 said:
Hi Fredo
You are right. There is definitely a bug and this is annoying.
I fixed it, and will re-release (as soon as the certification on EWH works again).Fredo
thanks for your reactivity !
will you publish a reply when it will be downloadable?Alex
Just republish, now that EWH certification seems to work again.
Please advise if this fixes your problems.Fredo
I have not seen your post.
Thank you Fredo.
I downloaded all new versions of you plug in and solid volumes works now.Alex
NEW RELEASE: FredoTools::SolidVolume v1.4a - 10 Feb 20
SolidVolume 1.4a is a major release fixing issues in some situations where faces where not properly oriented.
Hi!
Calculation of volume is wrong in certain cases. See attached file.
Got it and fixed it. Need some repackaging and will publish soon.
By the way, the main interest of SolidVolume is that it is supposed to work on pseudo solids too, as shown in the video.
NEW RELEASE: FredoTools::SolidVolume v1.5a - 13 Nov 23
SolidVolume 1.5a is a major release fixing issues in the calculation of volumes in some situations where the solid is scaled. It also adds the capability to compute the volumes of pseudo-solids: objects with multiple solids inside, objects with holes in faces or some mssing faces.
