Delete a list of components by their definitions.
**Hello Dan Rathbun and thank you for your help.
@dan rathbun said:
Then either you wrap what TIG showed you into a method, and call it 3 times from a loop:
How to write the loop?
I have done several tests and I still get this error message:
Error: # <SyntaxError: <main>: syntax error, unexpected '|' For cname in ['CUBE', 'TOTO', 'LOLA'] do | cname | ^>
Then I tried your method by adding:
Cnames = ['CUBE', 'TOTO', 'LOLA']
The ruby console returns:
purge_comps
But nothing changes in SketchUp.
I have to move on from something obvious that I can not understand.
Thank you in advance for your help.**
You are trying to define the variable "cname" twice in the same statement. delete the do | cname |
As usual Dan is right. You just need to wrap TIG's code with
["cube","toto","lola"].each{|name| match = /#{name}/i . . . }
MY BAD! I had a bad example (above.) [ Commented out that " do | cname |" part ]
["cube","toto","lola"].each{|name| > match = /#{name}/i > . > . > . > }
That will actually create a separate undo operation for each entity (and it's materials) and will be much slower.
I gave you a complete working method at the bottom of that previous post !!!!!!
https://forums.sketchup.com/t/ruby-learning-resources-wikilists/22861
Get the old "Pick Axe" book and read it. -
@tntdavid said:
@tig said:
What made you think you need to diverge from my guidance ?
I used a array to "match" because there will be several different definitions to delete.
TIG is showing you how to purge ONEdefinition and it's materials.
@tntdavid said:
Your code works perfectly for a single definition, ...
No it does not. because you made 3 edits that make it NOT work properly.
CORRECTION: Actually I found 4 errors that made it not delete all the components or materials.
The second use of the Regexp was! d.name =~ /#{name}/
(the regexp var ismatch
matsNOTtogo=[]
was defined asmatsNOYtogo=[]
, resulting inNameError
The comparison of back_material was conditional upon inclusion of front material in two statements.@tntdavid said:
... what if we have "CUBE", "TOTO" and "LOLA" to delete?
First, learn how and why TIG's code works for ONE definition, then learn how to modify it for multiple definitions.
for cname in ['CUBE','TOTO','LOLA'] # WHOOPS this not needed --> do |cname| purge_comp(cname) end
... or you build a multi-match regular expression (
Regexp
cnames = ['CUBE','TOTO','LOLA'] match = /#{cnames.join('|')}/
Test file (SU2016):
CubeLolaToto.skp
"Color B04" and "Color J08" are unused.
"Color K03", "Color M06" are used by primitive faces.
"Material 2" is the leader color.So here is a method with extra quirks:
- Returns false if array of cnames is empty.
- Short circuits and returns 0 if no definitions are found to delete.
- Reports both to console and message box number of definitions and materials purged.
- Returns number of definitions deleted.
# To test: # purge_comps('CUBE','TOTO','LOLA') # ... or: # del = ['CUBE','TOTO','LOLA'] # purge_comps(del) def purge_comps(*cnames) # return false if cnames.empty? cnames.flatten! # match = /#{cnames.join('|')}/ # model=Sketchup.active_model # collect matching definitions defstogo=model.definitions.find_all{|d| d.name =~ match } return 0 if defstogo.empty? # collect materials. matstogo=[] defstogo.each{|d| # first used by instances d.instances.each{|i| matstogo << i.material unless matstogo.include?(i.material) } # now used by its entities d.entities.each{|e| matstogo << e.material unless matstogo.include?(e.material) ( matstogo << e.back_material unless matstogo.include?(e.back_material) ) if e.is_a?(Sketchup::Face) } } matstogo.compact! matstogo.uniq! # now check if materials used elsewhere defsNOTtogo=model.definitions.find_all{|d| ! d.name =~ match } # collect materials. matsNOTtogo=[] defsNOTtogo.each{|d| # first used by instances d.instances.each{|i| matsNOTtogo << i.material unless matsNOTtogo.include?(i.material) } # now used by its entities d.entities.each{|e| matsNOTtogo << e.material unless matsNOTtogo.include?(e.material) ( matsNOTtogo << e.back_material unless matsNOTtogo.include?(e.back_material) ) if e.is_a?(Sketchup::Face) } } matsNOTtogo.compact! matsNOTtogo.uniq! # now reduce matstogo as necessary... matstogo.clone.each{|e| matstogo.delete(e) if matsNOTtogo.include?(e) } # defsgone = defstogo.size matsgone = matstogo.size # start and operation to ensure Garbage Collection works... model.start_operation('Purger', true) # now delete the selected entities defstogo.each{|d| d.entities.clear! } # now delete the unneeded materials matstogo.each{|m| model.materials.remove(m) } # clear the arrays of references to deleted objects: matstogo.clear defstogo.clear # commit model.commit_operation msg = "#{defsgone} definitions purged\n#{matsgone} materials purged" puts msg UI.messagebox(msg,MB_OK) return defsgone end
If you absolutely must, you can call
GC.start
to ensure Ruby garbage collection runs. -
CODE: SELECT ALL
match = /#{name}/i
}Great thanks sdmitch,
You allowed me to understand what Dan Rathbun was explaining to me.
@dan rathbun said:
https://forums.sketchup.com/t/ruby-lear ... ists/22861
Get the old "Pick Axe" book and read it.Thanks for the Dan link, I will follow your advice.
Here is the TIG method, which works for several definitions:
["cube","toto","lola"].each{|name| match = /#{name}/i model=Sketchup.active_model defstogo=model.definitions.find_all{|d| d.name =~ match } matstogo=[] defstogo.each{|d| d.instances.each{|i| matstogo << i.material unless matstogo.include?(i.material) } d.entities.each{|e| matstogo << e.material unless matstogo.include?(e.material) ( matstogo << e.back_material unless matstogo.include?(e.material) ) if e.is_a?(Sketchup::Face) } } matstogo.compact! matstogo.uniq! defsnottogo=model.definitions.find_all{|d| ! d.name =~ /#{match}/ } matsnottogo=[] defsnottogo.each{|d| d.instances.each{|i| matsnottogo << i.material unless matsnottogo.include?(i.material) } d.entities.each{|e| matsnottogo << e.material unless matsnottogo.include?(e.material) ( matsnottogo << e.back_material unless matsnottogo.include?(e.material) ) if e.is_a?(Sketchup::Face) } } matsnottogo.compact! matsnottogo.uniq! matstogo.clone.each{|e| matstogo.delete(e) if matsnottogo.include?(e) } model.start_operation('Purger', true) defstogo.each{|d| d.entities.clear! } matstogo.each{|m| model.materials.remove(m) } model.commit_operation }
With your help I reach my goals and I discover more and more the Ruby.
Thank you all for your help.
Your implementation still has a few errors.
David, I say again, that I gave you the code for a complete corrected method above.
It defines a method namepurge_comps(*cnames)
**Sorry Dan, but I can not seem to make your method work.
In your method, how to integrate "CUBE", "TOTO" and "LOLA"?
David**
**Sorry Dan, I had not paid attention to your instructions in the code:
@dan rathbun said:
To test:
... or:
purge_comps(del)
Your method works very well and offers new benefits.
I noticed a small problem:
How to avoid deleting the texture of 'CUBE', if it is used elsewhere in SketchUp?
Thanks in advance for your help.**
It is TIG's method with a few extra "bells and whistles".
How to avoid deleting the texture of 'CUBE', if it is used elsewhere in SketchUp?I'll look at it today a bit and see if there is an issue.
EDIT: Okay, YES I see the issue. The method does not check the model level entities collection for used materials (on primitive entity objects.)
# To test: # purge_comps('CUBE','TOTO','LOLA') # ... or: # del = ['CUBE','TOTO','LOLA'] # purge_comps(del) # # ver: 2.0 def purge_comps(*cnames) # return false if cnames.empty? cnames.flatten! # match = /#{cnames.join('|')}/ # model=Sketchup.active_model # collect matching definitions defstogo=model.definitions.find_all{|d| d.name =~ match } return 0 if defstogo.empty? # collect materials. matstogo=[] defstogo.each{|d| # first used by instances d.instances.each{|i| matstogo << i.material unless matstogo.include?(i.material) } # now used by its entities d.entities.each{|e| matstogo << e.material unless matstogo.include?(e.material) ( matstogo << e.back_material unless matstogo.include?(e.back_material) ) if e.is_a?(Sketchup::Face) } } matstogo.compact! matstogo.uniq! # now check if materials used elsewhere defsNOTtogo=model.definitions.find_all{|d| ! d.name =~ match } # collect materials. matsNOTtogo=[] defsNOTtogo.each{|d| # first used by instances d.instances.each{|i| matsNOTtogo << i.material unless matsNOTtogo.include?(i.material) } # now used by its entities d.entities.each{|e| matsNOTtogo << e.material unless matsNOTtogo.include?(e.material) ( matsNOTtogo << e.back_material unless matsNOTtogo.include?(e.back_material) ) if e.is_a?(Sketchup::Face) } } # now used by model entities model.entities.each{|e| matsNOTtogo << e.material unless matsNOTtogo.include?(e.material) ( matsNOTtogo << e.back_material unless matsNOTtogo.include?(e.back_material) ) if e.is_a?(Sketchup::Face) } matsNOTtogo.compact! matsNOTtogo.uniq! # now reduce matstogo as necessary... matstogo.clone.each{|e| matstogo.delete(e) if matsNOTtogo.include?(e) } # defsgone = defstogo.size matsgone = matstogo.size # start and operation to ensure Garbage Collection works... model.start_operation('Purger', true) # now delete the selected entities defstogo.each{|d| d.entities.clear! } # now delete the unneeded materials matstogo.each{|m| model.materials.remove(m) } # clear the arrays of references to deleted objects: matstogo.clear defstogo.clear # commit model.commit_operation msg = "#{defsgone} definitions purged\n#{matsgone} materials purged" puts msg UI.messagebox(msg,MB_OK) return defsgone end
**Thanks for your reactivity Dan.
Your solution works in the most by cases, but not all the time.
The texture applied to TOTO should not be removed because it is used by the 4 Rectangle to Left:
This mistake this product on my Click-Cuisine 2 furniture, and therefore makes the method unusable.
Here's the SKP file:
If you test your code on other examples the problem will not exist!
For this reason the problem is strange and requires an investigation.
David**
I agree. Sounds like a good learning experience for you.
I've given you enough help for now.
Your turn to do some of the work.
**Hello,
You are right Dan, for the moment I still have not found a solution.
I'm stubborn and I'd end up finding it!
Thanks for your example Dirven
I have tested your code and the components are all removed from the SketchUp scene but nothing is purged.
Is this normal?
Edite:
The Ruby console returns this message when I trigger your method.
Error: #<NameError: undefined local variable or method `i' for Teste:Module> C:/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb:60:in `block in purge_comps_n_mats' C:/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb:56:in `each' C:/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb:56:in `purge_comps_n_mats' C:/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb:75:in `purge_comps' C:/Users/David/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/TNT_Teste/logic.rb:85:in `block in singleton class' SketchUp:1:in `call'
Thank you**
edited my example...
line 55 i is now item...
another way is to Hash the materials and set values for each...
def purge_comps_n_mats(*args) model = Sketchup.active_model defs = model.definitions sel = model.selection view = model.active_view ents = model.active_entities mats = model.materials # add a hasj for materials and entities mats_h = Hash[mats.zip([1] * mats.size)] # this means you don't have to get Regexp right yourself names = Regexp.union(args) # this is similar to defs.to_a.dup.flatten list = defs.find_all { |d| d } # we will still only use one operation as v17 will error model.start_operation('mats') list.each do |defn| defn.instances.each do |i| ###################### # optional 'showtime' for testing sel.add(i) view.refresh sleep 0.2 ###################### dents = defn.entities if defn.name =~ names # get rid of the comps checking their materials mats_h[defn.material] = 3 unless defn.material.nil? mats_h[i.material] = 3 unless i.material.nil? dents.to_a.each do |item| mats_h[item.material] = 3 if item.respond_to? :material mats_h[item.back_material] = 3 if item.respond_to? :back_material end # delete the instance ents.erase_entities(i) else mats_h[defn.material] = 2 unless defn.material.nil? mats_h[i.material] = 2 unless i.material.nil? dents.to_a.each do |item| mats_h[item.material] = 2 if item.respond_to? :material mats_h[item.back_material] = 2 if item.respond_to? :back_material end end end end ents.to_a.each do |item| ###################### # optional 'showtime' for testing sel.add(item) view.refresh sleep 0.2 ###################### mats_h[item.material] = 2 if item.respond_to? :material mats_h[item.back_material] = 2 if item.respond_to? :back_material end mats_h.each { |k, v| mats.remove(k) unless k.nil? || v != 3 } model.commit_operation # end purge_comps_n_mats('CUBE', 'TOTO', 'LOLA')
**Thank you driven, your solution works well but encounters the same problem as that of TIG enhanced by Dan.
The materials applied to the "subcomponents" are not seen by the 2 methods.
To be more precise, here is an example in image:
The goal is that the texture "CUBE" is not deleted because it is used by "Nested component".
Perhaps the solution would be to ask both methods to explore all the subcomponents in SketchUp and collect the materials so as not to delete them?
How to write this in ruby?
I could find a solution by modifying the components of Click-Cuisine 2, but the ideal would be to solve the problem with the code.
If you want to try, here is the SKP file of the example:
Thank you**
you must have changed something because it does work for me...
did you read the code?
it collects all nested materials from 'everything' before removing any materials...
click image to see gif:
attach your test code...
**Yes I read your code driven and am surprised that it does not work for me.
You are right in my last SKP example, your method works.
Make a test with this example:
You will see that the texture of "TOTO" will be deleted.**
**I can not understand why the texture applied to "TOTO" is purged.
If I go through "purge_unused" the texture "TOTO" is not deleted.
So I'll get around the problem with another method.
To delete a list of materials, I can write this:
mat_names = ['TOTO','LOLA','CUBE'] materials = Sketchup.active_model.materials mat_names.each{|mnj| materials.remove(mnj)}
Can we do the same with "purge_unused", so that the unused materials of the list are deleted?
Thank you for your help.**
