Sketchy FFD on 2016
General discussion related to SketchUp Pro and Make
Sketchy FFD on 2016
Postby utiler » Fri Nov 20, 2015 6:02 am
Does anyone know if Sketchy FFD work on 2016? I've tried loading it and can't get it to work.
I'm wanting to deform a sphere; FFC would be the best way to do that, yeah?
purpose/expression/purpose/....
User avatar
utiler
Top SketchUcator
Re: Sketchy FFD on 2016
Postby Box » Fri Nov 20, 2015 6:23 am
What do you want to do to the sphere?
Do you have an image?
Edit:
Haven't used it for years, never took to it.
But loaded and working in 2016 as far as I can see.
3
User avatar
Postby abhininja » Sat Jun 17, 2017 8:33 pm
i am not able to use ffd in 2016
abhininja
Postby pilou » Sat Jun 17, 2017 8:56 pm
Patch FFD has nothing to do with your volume!
(except the fact that you access to the Context Menu! :)
It's a creation of a Grid Surface at the origine! :ugeek:
So FFD is working very fine inside 2016!
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Sat Jun 17, 2017 9:11 pm
And works fine also inside 2017! :fro:
A cool trick is using native Structure palette for Select the FFD box! :ugeek:
and Right Click / Modify FFD Group! (always over the Structure Palette)
Speedy Galerie
User avatar
Top SketchUcator
Postby gilles » Sat Jun 17, 2017 9:24 pm
Just double click…
User avatar
gilles
Top SketchUcator
Postby pilou » Sat Jun 17, 2017 10:14 pm
Just Double Click
Yes for paradisiacal scene! :enlight: Like one volume like above! :)
...but when you a bunch of objects overlaping on the scene, it's a mess to find the right one! :mrgreen:
J'ai déjà vécu ce cauchemar! :)
Chat échaudé craint l'eau froide! :mrgreen:
PS even for the example above when you make a "double click" you don't know visually
if you have enlighted the volume or the FFD volume! :mrgreen:
You must Double click on a Point but not so evident!
It's so easy on the structure Palett! :enlight:
And you make a Double Click less! :ugeek:
Speedy Galerie
User avatar
Top SketchUcator
Postby gilles » Sat Jun 17, 2017 11:09 pm
I mean in Structure…
User avatar
gilles
Top SketchUcator
Postby pilou » Sat Jun 17, 2017 11:27 pm
OK ...so we are agree Structure is very practical!
One time for call FFD
One time for edit it!
:enlight:
Speedy Galerie
User avatar
Top SketchUcator
Postby abhininja » Mon Jun 19, 2017 12:12 pm
thanx pilou, but i am not able to control volume,its showing only 'patch FFD dimention'
abhininja
Postby TIG » Mon Jun 19, 2017 12:23 pm
Do you have Guides set to be visible ? [View menu]
If not, then you'll see nothing to edit.
To edit the points edit the group of FFD guides, as @Pilou showed you earlier, you can easily select it and edit it from the Outliner list...
User avatar
Global Moderator
Postby pilou » Mon Jun 19, 2017 1:07 pm
Sorry Structure in French = Outliner ! ;)
PS For see all the FFD Menu you must have selected a Group! :ugeek:
( and not a Group of Groups : in this case you will see Menu but not effective on all groups)
So explode all and make an unic Group!
Don't work with a Component! :ugeek:
Speedy Galerie
User avatar
Top SketchUcator
Postby abhininja » Mon Jun 19, 2017 5:55 pm
thanx guys
abhininja
Postby dcalanya » Tue Mar 13, 2018 1:39 pm
I am using a lot of plugin.
I downloaded this plugin and installed it. But I couldn't see it to use??
is this plugin only for PRO version?
I am using Sketchup 2016 Make
dcalanya
Postby TIG » Wed Mar 14, 2018 11:35 am
It works in all versions.
Its menu items show up in the right-click context-menu, but only IF a suitable group is selected...
User avatar
Global Moderator
Postby pilou » Wed Mar 14, 2018 2:15 pm
Use the Outliner for an easy selection of FFD groups created!
Speedy Galerie
User avatar
Top SketchUcator
Postby ezzmagic » Thu May 17, 2018 3:45 pm
I have a problem that was working and after a period of stop work .. Is it a solution to this problem?
ezzmagic
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: No registered users and 24 guests
Visit our sponsors:
