[Plugin Beta] Animator - v3.7a - 31 Mar 22
Fredo,
You should put a warning label on this plug-in.........its addictive.Last one for today...........cargo drop via parachute.
Charlie,
Great job. I guess you used the Easing for simulating the take off. And nice utilization of the scaling for the parachute.
One small thing: you could center the plane on the runway by moving the point of contact to be in the middle of the two wheels.
Now you just have to build the landscape and include some views from the cockpit!
@fredo6 said:
Charlie,
Great job. I guess you used the Easing for simulating the take off. And nice utilization of the scaling for the parachute.Thanks Fredo, I am truly honored!& yes I used easing. (see settings attachment)
But this is some form of magic that you do, so all credit to you!@fredo6 said:
Hard to tell but path was in the center....I may have inadvertently moved it though.
I know.....but have to stop for today.
Magnificent job CHARLIE
Thanks for sharing
Thanks to Fredo -
Fredo,
Pretty neat Charlie!!
Thanks all, it was/is fun.
When I click on airplane gif I get this each time:
I've had a similar problem on one other site (The Verge - which fails to even load the home page), so it's likely browser related. Both these have happened since the latest Safari update, so not sure if it broke something.
Anyone know what the issue might be? I'm running Safari on elCapitan (both with latest updates)
If you open this in a browser tab what happens?
https://sketchucation.com/forums/download/file.php?id=147669%26amp;mode=view/rokbox.jpg
Same error. It takes ~ 30 seconds for the tab to load, then it throws the error.
I thought it might be my browser extensions, but the problem persists even with extensions off.
I revised the length of the .gif as I experienced something similar on my Ipad.
So this is a test to see if it is due to a time issue. (see attached)
I will take down problem file if this resolves it.
Charlie
EDIT:
This version works fine on my IPad.
*Admin. Please let me know if you want problem file taken down or? (In case you want it to source problem)
COOOL!
It was only when I tried opening Rich's in a new tab that it took 30 seconds to fail. When I clicked on the gif (without opening a new tab), it threw the error immediately - and still does with the smaller file.
Not to worry... pretty sure the problem is with my browser
fredo,
Per latest Beta release:
Cameras: Still views, Scene views, Tracking camera, all with "fade-out"
Q: Is the "fade out" camera related or content related? (Please indulge me as I am not well versed)
That said......and to attempt to further clarify.....what would "fade out".......items/content camera is "on" or would camera "fade out" or "close" focus in some way.
Again, many thanks for this awesome plug-in.
Best regards,
Charlie -
Pierre,
What a strange machine (a microscope?). I guess you have plenty of movements to demonstrate!
A lemon curd tartlet machine!
It's a part of a sample handler for X-Ray analysis ( Copper industry, not lemon-cake... )
Hi Fredo,
Hereby, some small items I noticed using Animator V1.6a.
( written in French)Pierre
Pierre,
Thanks for signaling these problems. I already fixed them and will re-publish soon.
Note that for time or duration setting, you should just enter the value, not keep the 's' for second .
Hello Fredo
Question: is it possible to insert a dummy sequence in time line that shifts all the following step ?
This could be usefull when some not shown process is working.Friendly
Pierre
