[Plugin Beta] Animator - v3.3a - 22 Feb 21Re: [Plugin Beta] Animator - v1.6a - 25 May 17fredo,
Thank you, ....great plug-in! Q: how to maintain object parallel to path when "helical"? In first .gif I have SU path on single/flat plane, and all behaves as expected. (I introduced 3 rotations: rear wheel lift just before take off and ± 60° rotations through curve(s) In second .gif I have "elevated" the path to a "helical" type shape and the plane maintains +X axis "heading throughout path. Is there a setting to force the plane to follow the path parallel? (Ideally, replicate the action in first .gif in the "helical" type path of the second .gif) Thanks again, Charlie Precision M1710/Win 7 Pro 64 bit/i-7 6920 Quad core 2.9 Ghz -3.8/16Gb ram/NVIDIA M5000M 8Gb
Re: [Plugin Beta] Animator - v1.6a - 25 May 17Why not add the elevation as movement?
There's a frontroom and a backroom....reverse faces
Rich, Umm....because I guess I was too thick headed to even think of that. ![]() (now wishing I asked hours ago) ![]() Thanks, that works great! Charlie Precision M1710/Win 7 Pro 64 bit/i-7 6920 Quad core 2.9 Ghz -3.8/16Gb ram/NVIDIA M5000M 8Gb
Re: [Plugin Beta] Animator - v1.6a - 25 May 17No problem. That's a great little animation!
Mind if I share it on twitter? There's a frontroom and a backroom....reverse faces
(Thanks)Sure, ok to tweet it, though now that I am past my hurdle (thanks again)I was going to add a package dropped via parachute. (scaling)........but don't wait for that.........another learning curve ahead for me. ![]() Charlie Precision M1710/Win 7 Pro 64 bit/i-7 6920 Quad core 2.9 Ghz -3.8/16Gb ram/NVIDIA M5000M 8Gb
Re: [Plugin Beta] Animator - v1.6a - 25 May 17New improvements, it opens a whole world. Great Fredo.
Pierre La Connaissance n'a de valeur que partagée
Re: [Plugin Beta] Animator - v1.6a - 25 May 17Fredo,
You should put a warning label on this plug-in.........its addictive. ![]() Last one for today...........cargo drop via parachute. Precision M1710/Win 7 Pro 64 bit/i-7 6920 Quad core 2.9 Ghz -3.8/16Gb ram/NVIDIA M5000M 8Gb
Re: [Plugin Beta] Animator - v1.6a - 25 May 17Charlie,
Great job. I guess you used the Easing for simulating the take off. And nice utilization of the scaling for the parachute. One small thing: you could center the plane on the runway by moving the point of contact to be in the middle of the two wheels. Now you just have to build the landscape and include some views from the cockpit! Fredo
Thanks Fredo, I am truly honored!& yes I used easing. (see settings attachment) But this is some form of magic that you do, so all credit to you!
Hard to tell but path was in the center....I may have inadvertently moved it though.
I know.....but have to stop for today. Precision M1710/Win 7 Pro 64 bit/i-7 6920 Quad core 2.9 Ghz -3.8/16Gb ram/NVIDIA M5000M 8Gb
Magnificent job CHARLIE ![]() Thanks for sharing Thanks to Fredo Re: [Plugin Beta] Animator - v1.6a - 25 May 17
Pretty neat Charlie!! Re: [Plugin Beta] Animator - v1.6a - 25 May 17Thanks all, it was/is fun.
![]() Precision M1710/Win 7 Pro 64 bit/i-7 6920 Quad core 2.9 Ghz -3.8/16Gb ram/NVIDIA M5000M 8Gb
Re: [Plugin Beta] Animator - v1.6a - 25 May 17When I click on airplane gif I get this each time:
I've had a similar problem on one other site (The Verge - which fails to even load the home page), so it's likely browser related. Both these have happened since the latest Safari update, so not sure if it broke something. Anyone know what the issue might be? I'm running Safari on elCapitan (both with latest updates) Re: [Plugin Beta] Animator - v1.6a - 25 May 17
If you open this in a browser tab what happens? download/file.php?id=147669&mode=view/rokbox.jpg There's a frontroom and a backroom....reverse faces
Re: [Plugin Beta] Animator - v1.6a - 25 May 17Same error. It takes ~ 30 seconds for the tab to load, then it throws the error.
I thought it might be my browser extensions, but the problem persists even with extensions off. Re: [Plugin Beta] Animator - v1.6a - 25 May 17
I revised the length of the .gif as I experienced something similar on my Ipad. So this is a test to see if it is due to a time issue. (see attached) I will take down problem file if this resolves it. Charlie EDIT: This version works fine on my IPad. *Admin. Please let me know if you want problem file taken down or? (In case you want it to source problem) Precision M1710/Win 7 Pro 64 bit/i-7 6920 Quad core 2.9 Ghz -3.8/16Gb ram/NVIDIA M5000M 8Gb
Re: [Plugin Beta] Animator - v1.6a - 25 May 17It was only when I tried opening Rich's in a new tab that it took 30 seconds to fail. When I clicked on the gif (without opening a new tab), it threw the error immediately - and still does with the smaller file.
Not to worry... pretty sure the problem is with my browser Re: [Plugin Beta] Animator - v1.6a - 25 May 17fredo,
Per latest Beta release: Cameras: Still views, Scene views, Tracking camera, all with "fade-out" Q: Is the "fade out" camera related or content related? (Please indulge me as I am not well versed) That said......and to attempt to further clarify.....what would "fade out".......items/content camera is "on" or would camera "fade out" or "close" focus in some way. Again, many thanks for this awesome plug-in. Best regards, Charlie Precision M1710/Win 7 Pro 64 bit/i-7 6920 Quad core 2.9 Ghz -3.8/16Gb ram/NVIDIA M5000M 8Gb
Re: [Plugin Beta] Animator - v1.6a - 25 May 17Hello
Some work in progress. Really useful. Cheers Fredo . La Connaissance n'a de valeur que partagée
Re: [Plugin Beta] Animator - v1.6a - 25 May 17Pierre,
What a strange machine (a microscope?). I guess you have plenty of movements to demonstrate! Fredo
Re: [Plugin Beta] Animator - v1.6a - 25 May 17A lemon curd tartlet machine!
Re: [Plugin Beta] Animator - v1.6a - 25 May 17It's a part of a sample handler for X-Ray analysis ( Copper industry, not lemon-cake...
![]() La Connaissance n'a de valeur que partagée
Re: [Plugin Beta] Animator - v1.6a - 25 May 17Hi Fredo,
Hereby, some small items I noticed using Animator V1.6a. ( written in French) Pierre La Connaissance n'a de valeur que partagée
Thanks for signaling these problems. I already fixed them and will re-publish soon. Note that for time or duration setting, you should just enter the value, not keep the 's' for second . Fredo
Re: [Plugin Beta] Animator - v1.6a - 25 May 17Hello Fredo
Question: is it possible to insert a dummy sequence in time line that shifts all the following step ? This could be usefull when some not shown process is working. Friendly Pierre La Connaissance n'a de valeur que partagée
Re: [Plugin Beta] Animator - v1.6a - 25 May 17The animation made me understand the XRay Analyzer. And Pilou was wrong, not to do with pastry!
I'll do the dummy sequence. I was thinking of it anyway, at least for forcing an adjustable quiet period at the beginning or the end of the clip. Fredo
Is there a way to resize the controls? Using a Macbook Pro Retina, the controls are tiny and hard to read. Probably something to do with the screen resolution... Re: [Plugin Beta] Animator - v1.7a - 09 Jul 17New Release: Animator - v1.7a - 09 Jul 17
Requirement: LibFredo6 v7.7a Major release - bug fixing and cosmetic changes - introduction of Visual Target, which is a visual effect forcing the camera to point to a given point in the model (possibly moving) - Support of high-resolution screens See main post for RBZ files
