[Plugin][$] 3D Tree Maker - New version 1.10.14
Hi everybody :
Is there a Tree Maker plugin for Sketchup 8 ? And where do I get it ? The ones that I DID find are for Collada. garystan
Hello,
Is this plugin still actively supported by the developer? I purchased a license expecting to get a more comprehensive library of trees and grass but after keying in the license, no change of tree collection from the free version.
@sob80sup81 said:
Hello,
Would also like to know this as it doest work in SU2017
@bob james said:
[attachment=0:1xmppw8w]<!-- ia0 -->tree.PNG<!-- ia0 -->[/attachment:1xmppw8w]
works fine here in SU2017 as well
@juju said:
@bob james said:
[attachment=0:1aq04ju1]<!-- ia0 -->tree.PNG<!-- ia0 -->[/attachment:1aq04ju1]
It loads fine as per your image but try the following;
Make a tree
Reconfigure it, using right click, reconfigure
Change tree parameters *
Redraw tree using updated parameters **
You will notice that many of the sliding bars are listed as NaN
** Redraw does nothing after changing any of the parameters
Error in Ruby Console to load a tree:
Error: #<NoMethodError: undefined method `treetemplatename' for nil:NilClass> /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs:1141:in `webtosu' /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs:1117:in `block in initialize' /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs:1171:in `call' /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs:1171:in `find_support_files' /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs:1171:in `populate' /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs:1137:in `webtosu' /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs:1117:in `block in initialize' SketchUp:1:in `call'
OSX 10.11.6 & SU2017
I've had an email back from ppoublan to say he is hoping to get this fixed in the new year.
@loam said:
@juju said:
@bob james said:
[attachment=0:2vnsbkfz]<!-- ia0 -->tree.PNG<!-- ia0 -->[/attachment:2vnsbkfz]
Make a tree
I am having the exact same problem.
has anyone got this to work with su2017?
thanks
jorgensen -
It sure would be nice to know if this will ever work or its just a lost-cause?
I don't really have a need for it but I just installed it now because of your post. It seems to work fine for me. It makes trees like it says on the box.
Works fine for me inside Su2017 Make !
Make your change(s) then Right Click on the selection / Context Menu 3D Arc Studio Tree/ Redraw.
Free version
3DArcStudio Tree Maker Sketchup Plugin can be downloaded for free from this site. The free version gives you access to all features, except you are not granted the right to sell or distribute trees created with the plugin, you will get one message each time you change configuration and little time to wait before the tree starts drawing, and you will not get access to all the tree templates included in the full version. If you like this plugin, you can get a licence for 10 euros that will remove those limits.Possible with the free version
Time was 5 s
Rendered with the free SimLab Composer Light! maxi 1920 * 1080 (a KeyShot like)
Can reload quasi any format of files! -
PS But you right : Configuration Menu works not like inside Su2016!
Seems some parameters are not responsive like "Number of truncs"...
and more curious the 2 buttons Redraw and Draw Proxy!So it's a very good habit to keep old versions of SU!
I downloaded the plugin from Sketchucation store within SU just the other day and read the post about the difference between free and paid so I don't think that's the issue I'm having. The drop down list of templates shows none either for the trees or grass. May be some knows something I don't (which is entirely possible).
The plugin does not work on SU 2017, try with SU 2016 or 2015.
If it doesn't work in SU2017, why did I get trees from it in SU2017?
http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=52540%26amp;start=240#p613826It worked for Pilou with no problem either. Maybe we're doing it wrong.
Perhaps because you use Windows, mwm5053 & me work on Mac, the plugin works fine in SU2016 on Mac but in SU2017 it appears the issue that mwm5053 describes.
I just removed all website data in Safari and Google Chrome ( some plugins I remembered use web dialogue something or other ) like the Fur plugin that I had problems with on Mac but still no choice for choosing type of tree.
Edit the Fur plugin does work in SU 2017 and OS X 10.10.5 Yosemite
I guess it's a Mac-related problem. I've tried to install it on both an iMac and a Macbook pro with SU2017 pro.
Problem 1 is (as other have noted) that the menu is blank - you can't choose any tree type.
Problem 2 is that the plugin dissapears when you quit and restart SketchUp! Yes, it's not disabled - it's not there!
