MSPhysics ice stage for AntonS
Postby faust07 » Mon Sep 26, 2016 10:48 am
This little simulation is made as a big thank you for Anton Synytsia for bringing physics for SketchUp back to life and to a high level. The ice stage with a lot of animated animals, collapsing icebergs, splashing and foaming demonstrates the performance of the plugin.
6
faust07
Re: MSPhysics ice stage for AntonS
Postby thomthom » Mon Sep 26, 2016 11:44 am
Nice!
How did you combine physics with animations for this video?
User avatar
PluginStore Author
PluginStore Author
Postby faust07 » Mon Sep 26, 2016 1:18 pm
Great that you like it!
There are several animation exporters implemented in the MSPhysics plugin.
If no rendering software is installed, you can export the images of the animation in a selected SketchUp style too.
Twilight Renderer also allows to render MSPhysics animations (directly or saved Replay data).
For rendered animations the requirement is that the render program (in my case IndigoRT) is installed for the certain SketchUp version.
If the MSPhysics model is prepared and ready to run the steps are:
- toggle the Record button, push the Play button and after the desired time the Reset button
- answer the following questions with yes
- in Extensions pull-down menu select "MSPhysics", "Export Replay to SkIndigo" (in my case), input the start and end frame numbers ...
- after the following export to igq-files and rendering every frame with Indigo you can
- combine the rendered images with a corresponding software (Windows Movie Maker, Virtual Dub, ...).
faust07
Postby otb designworks » Mon Sep 26, 2016 2:34 pm
Impressive!
Can you give us some idea of how long and how complicated it is to achieve what we are watching? And how long that took to render at what resolution?
Cheers, Chuck
OTB Designworks is on Youtube
otb designworks
Postby faust07 » Mon Sep 26, 2016 6:38 pm
With few previous knowledge in SketchyPhysics I started to learn MSPhysics at the beginning of this year.
In June I started with the Orca experiments because I was excited by the possibilities of the "Buoyancy Plane" for water surface simulation.
AntonS developed parallel MSPhysics further and built the grand Curvy Slider and Piston Joints.
Then there were also minimal knowledge in scripting based on the assistance and the example models of AntonS and PituPhysics.
See the especially the grand MSP concert piano with many self playing songs in 3D Warehouse.
I recommend to install MSPhysics, read the instructions and get started.
Rendering with IndigoRT:
Render Settings: Path tracing, Halt SSP 30 samples per pixel
CPU Rendering on Intel Core i7-4770 CPU 3.40GHz.
resolution 1920 x 1080
average rendering time: 1,5 min per frame.
30 frames per sec.
Here are some pictures, how the model is constructed:
faust07
Postby cotty » Mon Sep 26, 2016 6:42 pm
Great MSPhysics example!
User avatar
cotty
Top SketchUcator
Postby pbacot » Mon Sep 26, 2016 7:12 pm
Wow.... wow!
MacOSX Mojave ShetchUp Pro v19 Twilight Pro v2 M2 Kerkythea PowerCADD
User avatar
Top SketchUcator
Postby solo » Mon Sep 26, 2016 7:58 pm
Awesome, looking as the construction image, I'd go mad, too much happening for my little brain to keep up with.
User avatar
Global Moderator
Postby fredo6 » Mon Sep 26, 2016 8:36 pm
@Faust07
I am really impressed, both by your artistic sense and your technical mastership...and indeed by MSPhysics, which look extremely powerful. You animation is a real movie that deserves a prize!
User avatar
PluginStore Author
PluginStore Author
Postby ntxdave » Mon Sep 26, 2016 10:12 pm
I pretty much agree with what Fredo said. :thumb: :thumb:
I am particularly intrigued with the motion of the various pieces of water movement. The spray and waves are very nice.
User avatar
ntxdave
Postby faust07 » Mon Sep 26, 2016 10:39 pm
Thanks guys for the kind words. But the praise goes with priority to you, because you are advancing SketchUp, either with helping comments in the posts or with fantastic plugins (Fredo6). My goal as a user is to support the combination of SketchUp and Physics, because there lies an incredible potential in it (apart from the game engines).
It seems that there still lack the necessary imagination to recognize the possibilities. Good examples are enough since SketchyPhysics but there is little feedback from users after SketchyPhysics received unjustly.
I wish I had more idea of Ruby programming to translate good examples of SketchyPhysics into the more advanced MSPhysics - but time will tell...
faust07
Postby Anton_S » Tue Sep 27, 2016 5:19 am
Hey Faust,
That's really amazing! Just astounding!
Thank you very much,
Anton
Anton_S
PluginStore Author
PluginStore Author
Postby faust07 » Tue Sep 27, 2016 10:27 am
Nice that you like it, Anton.
That's largely your work and the preliminary work of the people who have developed the physics engine.
I scratch here, of course, only at the top of what is possible.
The simulation and animation of living things could be a little more sophisticated.
A good approach is the model "Real Springs" by PituPhysics (3D Warehouse) and what I hardly dare to dream, the first point on your TODO-list:
"•Implement cloth and soft bodies interface."
The others on the list, I can not wait ( :fro: ) are:
"•Implement user mesh collision interface.
•Add fracture/split interface.
•Add your own convex decomposition algorithm."
;) :thumb:
faust07
Postby Anton_S » Tue Sep 27, 2016 11:12 am
Maybeh one day lol
Anton_S
PluginStore Author
PluginStore Author
Postby otb designworks » Tue Sep 27, 2016 2:28 pm
Thanks for the details! That is one impressive animation.
Cheers, Chuck
otb designworks
Postby faust07 » Wed Sep 28, 2016 9:07 am
Thanks again.
The beauty is that you can achieve great effects with little effort with MSPhysics...
faust07
Postby chri » Sun Oct 02, 2016 8:34 pm
Faust , you are incredible
A fool job for a magnificient poetic result, your are an artist !
Chri
User avatar
chri
Postby pilou » Sun Oct 02, 2016 11:17 pm
Wonderful clip video! :fro:
Bravo! :thumb:
Ps Music by ?
Speedy Galerie
User avatar
Top SketchUcator
Postby faust07 » Mon Oct 03, 2016 7:41 pm
Thanks also to you, Chri and Pilou, for the kind words! And for the setting into the SketchUp "Hall of Fame" ...
On the music I'm not particularly proud of. Here I strummed on the guitar a little and also improvised the text.
I have the piece used because it accompanies the uniformity of simulation and extends over the full duration of the video.
The content of the text does not match the content of the video... Sorry
faust07
Postby pilou » Mon Oct 03, 2016 9:42 pm
No problem ! It's perfect for me! I had believed that was Tom Waits! :fro:
and like this you will not have problem of copyright! :thumb:
Speedy Galerie
User avatar
Top SketchUcator
Postby mptak » Sun Oct 09, 2016 3:08 am
LOVE THE MUSIC....and of course the animation. What a wonderful tribute to a great effort by AS.
mptak
Postby faust07 » Sun Oct 09, 2016 6:43 pm
NOT THE MUSIC... :fro: But the rest - yes!
faust07
Postby Rabtouze » Sun Jan 13, 2019 7:35 pm
Très belle réalisation !!! Bravo
Je la découvre après avoir craqué en essayant de faire tourner mon projet de moteur Stirling. Grr...
Ça fait du bien de voir que, avec de la patience et de la rigueur, on peut faire de très belle choses...
Bref, du coup, je recherche quelqu'un qui pourrait m'expliquer pourquoi mon moteur se disloque après quelques tours. Je crains de ne pas avoir compris les subtilités liées aux paramètres présents dans la fenêtre "MSPhysics UI". Si ça vous inspire, je mets mon fichier en PJ. Si nécessaire, je peux vous donner plus d'explications sur son fonctionnement.
Merci,
Rabtouze
Postby faust07 » Mon Jan 14, 2019 11:12 pm
En premier lieu, la désintégration pourrait être une conséquence de la géométrie concave de certaines pièces.
Par exemple, les pièces avec des trous oblongs devraient être composées d’éléments convexes individuels. Il y a un plugin pour Fredo6.
Vous devez activer "Collision Wireframe" dans l'interface utilisateur de MSPhysics sous Debug Draw et tester la précision géométrique de votre modèle.
Bonne chance! (Google Translator)
In the first place, the falling apart could be a consequence of the concave geometry of some parts.
For example, parts with slotted holes should be composed of individual convex elements. There is a plugin for Fredo6.
You should activate "Collision Wireframe" in the MSPhysics UI under "Debug Draw" and test your model for geometric accuracy.
I wish you success!
faust07
Postby Rabtouze » Mon Jan 14, 2019 11:32 pm
faust07 wrote:En premier lieu, la désintégration pourrait être une conséquence de la géométrie concave de certaines pièces.
I wish you success!
OK, Merci beaucoup pour ces conseils !!!
Je les mets en application dés que je peux et je vous redis si ca marche :)
Rabtouze
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: aliavarseji, discus30, kalis_98, Majestic-12 Bot, me3zone, thienrooney789 and 7 guests
Visit our sponsors:
