Visualizer for SketchUp
Re: Visualizer for SketchUp
Postby ct200224 » Wed Jul 13, 2016 4:28 am
Hey, I'm having a lot of trouble locating Visualizer plugins on my SketchUp.... It doesn't seem to be showing up at all. Here's a picture of my plugins folder in SketchUp 2015 with Visualizer installed:
at path /Users/[yourname]/Library/Application Support/SketchUp 2015/SketchUp
SketchUp 2016 folder (w/o visualizer, duh):
at path /Users/[yourname]/Library/Application Support/SketchUp 2016/SketchUp
Can someone help me at least locate the file?
Maybe someone could just upload the files so that I can manually download them? Please?
ct200224
Postby driven » Thu Jul 14, 2016 11:34 am
ct200224 wrote:Hey, I'm having a lot of trouble locating Visualizer plugins on my SketchUp.... It doesn't seem to be showing up at all.
if you run this in 'Ruby Console' it will move a copy for you into the v16 User/Library...
If you read through the thread, you should have seen that the v15 path is for the HD/Library...
Code: Select all
v15_folder = "/Library/Application Support/SketchUp 2015/SketchUp/Plugins/ImaginationVisualizer"
v15_extension = v15_folder + '.rb'
v16_folder = File.expand_path("~") + v15_folder.sub('5', '6')
v16_extension = v16_folder + '.rb'
command = 'ditto ' + v15_folder.inspect + ' ' + v16_folder.inspect + ' && ' + \
'ditto ' + v15_extension.inspect + ' ' + v16_extension.inspect
system(command)
driven
PluginStore Author
PluginStore Author
Postby Fred* » Mon Jul 18, 2016 10:14 am
Hello
I'm still trying to install Visualizer 1.3 on a Mac running El Capitan 10.11.5 with SketchUp v. 16.1.1451
Can anyone give me step-by-step instructions? Or point me to some?
Fred*
Postby driven » Mon Jul 18, 2016 8:52 pm
Visualizer will not install in SketchUp v16 without tricking it to do so...
temporarily renaming SketchUp 2016 folder in Finder to SketchUp 2015 will allow the download to make the the v15 files...
once downloaded, change the name back and run the ruby code posted in the post above...
driven
PluginStore Author
PluginStore Author
Postby Fred* » Tue Jul 19, 2016 2:46 pm
Thanks, driven, for this help. I find, though, that I don't have a folder called "SketchUp 2016" on my Mac. Do you mean in the applications?
I had SU 8 until now and recently upgraded to SU 2016, in case that makes a difference.
Fred*
Postby Fred* » Tue Jul 19, 2016 2:51 pm
Quick clarification: the folder SketchUp is in on my Mac is just called "SketchUp".
Fred*
Postby driven » Wed Jul 20, 2016 8:58 pm
Applications/SketchUp 2016 is the one I refer too...
driven
PluginStore Author
PluginStore Author
Postby Fred* » Thu Jul 21, 2016 4:21 pm
Got it. Thanks!
I was able to install it. Thanks for your help!
Fred*
Postby willanie » Thu Jul 21, 2016 4:50 pm
Hi Fred,
Just so its clear, because I didnt think it was possible. You managed(with John's help) to get Visualizer installed on a Mac with only Sketchup2016 installed.
willanie
PluginStore Author
PluginStore Author
Postby Fred* » Fri Jul 22, 2016 6:49 am
Hi willanie
Yes, that's correct, and I was glad to see that Visualizer works fairly quickly on my MacBook Pro Retina 13" 2014, with 2.8 GHz Intel Core i5 and 8 GB 1600 MHz DDR3 RAM.
Fred*
Postby ste7ana » Fri Jul 29, 2016 2:42 pm
Does anyone know if there is a 32bit Visualizer version available? Thanks
ste7ana
Postby willanie » Tue Aug 02, 2016 12:50 am
There is no 32bit Visualizer version
willanie
PluginStore Author
PluginStore Author
Postby ste7ana » Thu Aug 04, 2016 7:02 am
:( thanks willanie
ste7ana
Postby tmt0009 » Wed Aug 10, 2016 4:05 am
Hello,
I have installed Visualizer 1.3 and it works with 2015 (on MAC OS). However there are two issues.
The first, is that anytime I close out of the program while modeling it generates a crash report.
The second issue is that it doesn't appear in the Library/Application Support/SketchUp2015/SketchUp/Plugins folder which means I can't copy the Visualizer folder or the ruby file over to the SketchUp 2016.
Anyone have any ideas? Anything would help. Thanks in advance.
T.
tmt0009
Postby ct200224 » Fri Aug 12, 2016 12:58 am
@driven: Thank you! Thank you so much! It's now up and running nicely!
ct200224
Postby AristosOntwerp » Fri Sep 02, 2016 3:22 pm
Hi Pilou,
Quoi faire, si je n'ai pas 2015 comme voi de migrer. J'ai une installation frais de 2016 et installer Visualizer c'est impossible (Vous n'avez pas SketchUp 2013, 2014 ou 2015).
Est-ce que tu a un trick pour cela aussi?
Merci en avance,
Aristos
AristosOntwerp
Postby AristosOntwerp » Fri Sep 02, 2016 3:34 pm
Does something like that work on Windows 7 as well? I tried with renaming the 64-bit program directory from SketchUp 2016 in SketchUp 2015 - but that was apparently too easy... Still the message: You need 2013, 2014 or 2015....
Aristos
driven wrote:Visualizer will not install in SketchUp v16 without tricking it to do so...
AristosOntwerp
Postby willanie » Fri Sep 02, 2016 5:19 pm
Im pretty sure you must at least install 2015 with windows OS.
Here is a link to sketchup forum posting for getting 2015 Make.
http://forums.sketchup.com/t/link-to-do ... make/24281
willanie
PluginStore Author
PluginStore Author
Postby pilou » Fri Sep 02, 2016 6:56 pm
@aristos
Visualizer fonctionne aussi sur la 2015 avec au moins les versions de Window 8 et windows 10 que j'avais installées!
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Tue Nov 08, 2016 3:34 am
Seems Visualizer don't works on 2017 with the previous tricks of installation 2015 - 2016 ! :o
Speedy Galerie
User avatar
Top SketchUcator
Postby juju » Tue Nov 08, 2016 7:56 am
pilou wrote:Seems Visualizer don't works on 2017 with the previous tricks of installation 2015 - 2016 ! :o
somehow I am not surprised
I'm wondering how many other extensions / plugins will be problematic
User avatar
juju
Premium Member
Premium Member
Postby vico44 » Tue Nov 08, 2016 10:24 am
It was working with The 2016 on OS X
Pour cela il fallait juste copier l'ancienne installation sur /Bibliothèque/Application Support/Sketchup 2016/
(Pas dans User/Biblithéque/Application Support/Sketchup 2016/ mais à la racine du disque)
Cela ne marche pas pour Sketchup 2017
vico44
Postby driven » Tue Nov 08, 2016 12:20 pm
the 2016 tricks will not work for this or any plugin that cannot be updated to run on Ruby 2.2...
there is no legal way around this for encrypted extensions...
driven
PluginStore Author
PluginStore Author
Postby masterpaul » Tue Nov 08, 2016 12:31 pm
Yep its busted.
I wish they released the program as opensource.
Code: Select all
C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/Extensions/IRExtension2015x64.so>
C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require'
c:/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_initialize.rbs:67:in `<module:ImgTecVis>'
c:/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_initialize.rbs:10:in `<main>'
C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb:5:in `eval'
C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb:5:in `require'
C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb:5:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `load'
C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer.rb:25:in `register_extension'
C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer.rb:25:in `<module:ImgTecVis>'
C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer.rb:14:in `<top (required)>'
Error: #<NoMethodError: undefined method `get_imgtec_rnd_api' for nil:NilClass>
c:/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_initialize.rbs:23:in `irapi'
c:/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menu_commands.rbs:26:in `<module:ImgTecVis>'
c:/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menu_commands.rbs:10:in `<main>'
c:/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menus.rbs:9:in `eval'
c:/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menus.rbs:9:in `require'
c:/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menus.rbs:9:in `<main>'
C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb:6:in `eval'
C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb:6:in `require'
C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/ImaginationVisualizer/iv_loader.rb:6:in `<top (required)>'
Error: #<NoMethodError: undefined method `enable_statistics' for nil:NilClass>
c:/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menus.rbs:93:in `<module:ImgTecVis>'
c:/programdata/sketchup/sketchup 2017/sketchup/plugins/imaginationvisualizer/iv_menus.rbs:12:in `<main>'
User avatar
masterpaul
Postby spadestick » Tue Aug 01, 2017 11:06 am
The Visualizer website is down! Does anyone have a list of enhanced material names for the different reflection levels?
I only remember gloss and matte
I recall paint plastic / metal somewhere...
thanks-heaps!
spadestick
Postby vidy » Tue Aug 01, 2017 12:22 pm
spadestick wrote:The Visualizer website is down! Does anyone have a list of enhanced material names for the different reflection levels?
thanks-heaps!
Hi Spade,
it's still there, check out this link: http://getvisualizer.com/blog/enhanced-materials.html
Regards,
VD
still so much to learn..
vidy
Postby pilou » Wed Aug 02, 2017 10:34 am
And for French speaking! ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby Nathans » Fri Jun 15, 2018 6:54 pm
Any luck with visualiser on sketch pro 2018 and windows 10?!
Nathans
Postby pilou » Fri Jun 15, 2018 9:39 pm
Works on Windows 10 only till SU 2016 ! :ugeek:
Speedy Galerie
User avatar
Top SketchUcator
Postby Nick1 » Tue Aug 20, 2019 11:57 pm
Has anyone been able to render a sand blasted/ frosted glass in Visualizer. I have tested lots of different ways and no proper results. I know the software is somehow limited in some ways, but I thought maybe someone has been successful with a setting for frosted glass or sand blasted glass that would actually render properly in Visualizer.
Nick1
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Extensions & Applications Discussions
Who is online
Visit our sponsors:
