Ropefall released - draw ropes, wires, cables quickly
• Page 2 of 3 • 1, 2, 3
Re: Ropefall released - draw ropes, wires, cables quicklythanks for checking massimo. It seems I have an issue in the build process, I'll correct it in the evening (EU time).
Ropefall - plugin to easily draw ropes, wires, cables
www.sketchrope.com (with non-expiring licence, no subscription) Re: Ropefall released - draw ropes, wires, cables quicklythe fixed version is available for download!! :arrow:
www.sketchrope.com (with non-expiring licence, no subscription) Re: Ropefall released - draw ropes, wires, cables quicklyThanks Balazs.
where is the webshop? Save the Earth, it's the only planet with chocolate.
Under Draw > SketchRope > Request Licence you can purchase a licence through PayPal There's a frontroom and a backroom....reverse faces
Re: Ropefall released - draw ropes, wires, cables quicklyWent to http://www.sketchrope.com and downloaded it, but where do I buy it?
Re: Ropefall released - draw ropes, wires, cables quicklyHi there,
needless to say, we are super happy to see these questions!! :-p I added some purchase guide underneath the download button at http://www.sketchrope.com Thanks Massimo and Rich for helping out in the meantime! Ropefall - plugin to easily draw ropes, wires, cables
www.sketchrope.com (with non-expiring licence, no subscription) Re: Ropefall released - draw ropes, wires, cables quicklySupported SketchUp versions: 2015+
www.sketchrope.com (with non-expiring licence, no subscription) Re: Ropefall released - draw ropes, wires, cables quicklywow... why can't I do that?
![]() Ropefall - plugin to easily draw ropes, wires, cables
www.sketchrope.com (with non-expiring licence, no subscription) Re: Ropefall released - draw ropes, wires, cables quicklyYou shouldn't compare yourself with massimo... he's always pulling off stunts like those!
Re: Ropefall released - draw ropes, wires, cables quicklyOkay, I tried this and do like it on simple drops, however it's very slow on moderate drops, wished it was faster or there was a way to input a less complicated fall (maybe less smooth).
Next I want to drape a rope ladder however this plugin is limited to a single rope, any plans to expand this?
Re: Ropefall released - draw ropes, wires, cables quicklySolo, thanks for the feedback.
The speed depends mainly on how complex the model is underneath the rope sketch. More precisely, underneath the upper X-Y square of the bounding box around the polyline. So you can speed up roping by temporarily hiding model parts in this volume. What do you mean by "this plugin is limited to a single rope"? You can draw as many ropes as you wish, see Massimo's example pics above. So whats your plan exactly? Ropefall - plugin to easily draw ropes, wires, cables
www.sketchrope.com (with non-expiring licence, no subscription) Re: Ropefall released - draw ropes, wires, cables quicklyps. is there a way to get notified via email about new posts in this topic?
www.sketchrope.com (with non-expiring licence, no subscription) Re: Ropefall released - draw ropes, wires, cables quicklyClick on "Subscribe Topic" at the bottom of the page
Re: Ropefall released - draw ropes, wires, cables quicklyThx Bob, subscribed.
www.sketchrope.com (with non-expiring licence, no subscription) Re: Ropefall released - draw ropes, wires, cables quicklyI love Sketchup
Re: Ropefall released - draw ropes, wires, cables quicklyThank you Collage!!
![]() Come on guys, keep these cool pics coming!!! I am eager to spend part of Christmas holidays to put Ropefall to the next level - ![]() ![]() Would you like to see new features or performance improvement? Some comments on this along with a picture depicting what you use Ropefall for would be most helpful! ![]() ![]() ![]() Ropefall - plugin to easily draw ropes, wires, cables
Hello,I purchased your plugin,but did not receive a serial number And another question,I have 2 computer,one a laptop at home and the other a workstation at office, Can I activate both of my computers? Regards I love Sketchup
Re: Ropefall released - draw ropes, wires, cables quicklyCollage,
thank you for your purchase, I have just sent you the licence key to your paypal email adress. Sorry for the delay. The Ropefall purchase process still involves a manual step, namely signing and sending out the licence key, that takes place within a businesss day after purchase. Now you have the key, please contact me at ropefall@sketchrope.com if you encounter any problems with it. The licence key is technically bound to a single machine (and OS user), thus your key only works on the machine you initiated the purchase from. Nevertheless I am happy to send another key to you for your other machine. I will contact you regarding this. happy roping, Balazs Ropefall - plugin to easily draw ropes, wires, cables
www.sketchrope.com (with non-expiring licence, no subscription) Re: Ropefall released - draw ropes, wires, cables quicklyHy,
I'm posting here some suggestions that I also emailed to the developer (and he suggested that should be posted publicly). Maybe (some) of them you will find interesting too: -bending radius to depend on the diameter (the thicker the "hose", or rope, the loose the loop -also bending radius to be controlled with a rigidity parameter... it doesn't have to be realistic or scientific, but rather empirical is enough. To have sort of 0..1 or 0..100 rigidity values, where 0 means completely soft (it would be nice even if the tube flattens at curves) and 100 means 100% stiff and just a bit of material elasticity would bend it. Like a long wooden stick supported by its ends. Also, another idea was if the rope can be extended to a mesh. After all what's one edges and what's more edges interconnected? I am not thinking here to a dense mesh, but to a proxy, that can be later subdivided using Artisan or subD into a more refined mesh. Also, this mesh could consider "thickness", so after it's folded/dropped, to be able to get thickness using Fredo's Interactive PushPull. Means that the folds would not collapse completely, but they would keep a virtual gap that would allow the thickness to be added ... DESIGNER AND ARTIST DEREI.UK
Re: Ropefall released - draw ropes, wires, cables quicklyindeed, the mass of line and gravitation setup would be nice add
"The licence key is technically bound to a single machine (and OS user), thus your key only works on the machine you initiated the purchase from. Nevertheless I am happy to send another key to you for your other machine. I will contact you regarding this." Is any option to deactivate addon for move license to another machine?; I have the same problem with 2 workstations; Re: Ropefall released - draw ropes, wires, cables quicklyThere is no deactivate option but I create you a new licence key for the new machine within the one year maintenance period. Please send me an email! Thx!
www.sketchrope.com (with non-expiring licence, no subscription) Re: Ropefall released - draw ropes, wires, cables quicklySo, 1st post said this plugin does not expire.
I have not used or needed it for a while, today I need it and get this:
Re: Ropefall released - draw ropes, wires, cables quicklyThe website also refers to non-expiring licence.
Re: Ropefall released - draw ropes, wires, cables quicklyHi Guys, thanks for reporting this.
The licence is valid for a single Ropefall installation, it does not expire. So if you install Ropefall on a Sketchup 2015+, successfully enter the licence key purchased and do not change or modify anything in your Sketchup environment that makes the licence key invalid, then you should be able to use that Ropefall instance forever. So what change can make a licence key invalid? - reinstall Sketchup for some reason (e.g. on a new machine) - upgrade Sketchup version, e.g. from 2016 to 2017 - anything that makes Sketchup registry corrupted In these cases please contact me at ropefall@sketchrope.com and I will generate a new licence key for you, free of charge within the one year maintenance period. Does this help? Ropefall - plugin to easily draw ropes, wires, cables
www.sketchrope.com (with non-expiring licence, no subscription) Re: Ropefall released - draw ropes, wires, cables quicklySeems like the licence terms should be updated as the non-expiring referral is limited.
What are the costs for a licence key regeneration, out of the year maintenance period, when one would have updated your SketchUp installation to a newer version or may have changed machines? Save the Earth, it's the only planet with chocolate.
Since I upgrade SU each year and make/buy a new computer about every 18 months, having to apply for a new license each time is really not viable. i7-4930K 3.4Ghz, 2x GTX780 6GB, 32GB DDR3-1600 ECC, OCZ Vertex 4 500GB, WD Black 3TB, 32TB NAS, 4x 27" Monitors, SpaceMouse Pro, X-keys XK-60
Re: Ropefall released - draw ropes, wires, cables quicklyWhat changed is I got a new machine, what did not change is I get the same issue on my old machine that did not get updated since installing.
Problem is if I get a new generated license now I'll be needing another as soon as SU 2018 arrives.
Who is online
Users browsing this forum: jenul and 0 guests
