by pilou » Mon Jan 11, 2016 7:34 pm
- Top SketchUcator
- Name: Pilou
- Operating system: Windows
- SketchUp version: 2017
- License type: Free/Make
- SketchUp use: hobby
- Level of SketchUp: Advanced
by pilou » Sun Feb 28, 2016 2:01 am
Commands & Scripts on Task Bar!
- Top SketchUcator
- Name: Pilou
by pilou » Thu Mar 24, 2016 12:11 pm
- Top SketchUcator
- Name: Pilou
by pilou » Wed Apr 06, 2016 1:11 pm
Plugin for no seams by Max Smirnov!
- Top SketchUcator
- Name: Pilou
by pilou » Wed Apr 20, 2016 10:17 am
Teasing by Max Smirnov!
- Top SketchUcator
- Name: Pilou
by pilou » Wed Apr 20, 2016 10:18 am
- Top SketchUcator
- Name: Pilou
by pilou » Mon May 02, 2016 8:52 pm
New version of Elephant! By Max Smirnov Animation is more easy!
- Top SketchUcator
- Name: Pilou
by pilou » Fri May 06, 2016 1:36 am
- Top SketchUcator
- Name: Pilou
by pilou » Sat May 07, 2016 12:26 pm
Last version of Elephant by Max Smirnov 7 may 2016 By Max Smirnov
- Top SketchUcator
- Name: Pilou
by pilou » Sun May 08, 2016 12:16 am
Elephant V 0.6 by Max Smirnov
- Top SketchUcator
- Name: Pilou
by pilou » Thu Sep 22, 2016 2:54 am
Return of the Max's Elephant!
- Top SketchUcator
- Name: Pilou
by pilou » Mon Sep 26, 2016 8:58 am
Elephant version 0.8 VF
(contrairement à l'image du post précédent les Tableaux Tab sont devenus Pts)
- Top SketchUcator
- Name: Pilou
by pilou » Sun Feb 26, 2017 2:24 am
Elephant Version 0.90 by Max Smirnov (vf) by Christian
- Top SketchUcator
- Name: Pilou
by pilou » Sun Jul 09, 2017 3:00 pm
- Top SketchUcator
- Name: Pilou
by pilou » Mon Nov 13, 2017 10:15 am
Beta V 4.0 64 bits released!  Export SKP include!
- Top SketchUcator
- Name: Pilou
by pilou » Thu Dec 07, 2017 11:05 am
- Top SketchUcator
- Name: Pilou
by pilou » Tue Dec 19, 2017 11:49 pm
- Top SketchUcator
- Name: Pilou
by pilou » Wed Aug 29, 2018 9:52 am
For owners of the V3 new Version V4 BetaMulticore + GPU By Zarkow
- Top SketchUcator
- Name: Pilou
by pilou » Thu Oct 18, 2018 3:20 pm
else Beta V4 of the 17 Oct 2018 (only for owners of the V3) Do you realize you get the best sub-d to nurbs technology here ? The surface continuity quality is above anything else on the market ( PaQ) By Eugene Sergienko
- Top SketchUcator
- Name: Pilou
by pilou » Fri Oct 19, 2018 12:12 am
Polys to nurbs is working!  The famous ZBrush Demo-soldier
For no jealousy! : Inside MagicaVoxel
- Top SketchUcator
- Name: Pilou
by pilou » Wed Feb 27, 2019 11:03 am
- Top SketchUcator
- Name: Pilou
by pilou » Wed Feb 27, 2019 11:05 am
Tuto express  Render Free Simlab Composer http://www.simlab-soft.com/3d-products/simlab-composer-lite.aspxMax 1920 * 1080 Real Time (Generated Image Can Be Used Commercially!!! ) Realtime Progressive Rendering ! 25 3D formats supported for import and can be mixed! Free Library of Materials, lightning, HDR, 3D Models and Rendering Presets ! No activation Needed : Just install the program then select “lite edition” at the first run (this tutorial is not made with free SimLab even it has some basic modeling functions! And you can save with free only in owner product format !
- Top SketchUcator
- Name: Pilou
by pilou » Wed Feb 27, 2019 11:08 am
New Beta 4.0 26 Februar 2019 (for owners of the V 3) List of news (principally debugging)
- Top SketchUcator
- Name: Pilou
by pilou » Thu Feb 28, 2019 11:05 am
- Top SketchUcator
- Name: Pilou
by pilou » Wed Mar 27, 2019 2:40 am
New fonction: InsertCircle - Bones...
- Top SketchUcator
- Name: Pilou
by pilou » Sat Sep 21, 2019 2:19 am
Repository of the 70 Native nodes of Elephant (created by Max Smirnov) English / French! And you can use it with the free alternation version of Moi3D with out save! As you can make animation with ELEPHANT, you can make screen shot of it!
- Top SketchUcator
- Name: Pilou
by pilou » Thu Oct 10, 2019 4:40 pm
- Top SketchUcator
- Name: Pilou
by pilou » Thu Oct 10, 2019 4:42 pm
Moi 3D Beta V4 10 October 2019 OriginalDimensions, properties, etc.. By Submono
- Top SketchUcator
- Name: Pilou
by pilou » Tue Oct 29, 2019 4:37 pm
10 seconds of relaxation  render the free real Time SimLab Composer (maxi 1920 * 1080)
- Top SketchUcator
- Name: Pilou
by pilou » Thu Oct 31, 2019 8:14 pm
- Top SketchUcator
- Name: Pilou
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Hardware, Software & Gadgets
