Repeat a Component Across Varying Spans
Postby ussmex » Tue Jan 19, 2016 7:00 am
Greetings,
I'm familiar how to repeat a component every X inches, for example, using Position X = 0 +COPY*36, but I was wondering if anyone is familiar with how to space the copies across spans that vary in length based on user input.
My idea was the following:
1) Allow users to define the LenX of "Span0", "Span1", "Span2", etc. via text box.
2) Set Span2!X, for example, equal to Span0!LenX + Span1!LenX.
3) Set CopiedComponent!X equal to Span(COPY)!X, so that the instance of the Span being referred to is defined by the Copy number.
I've been trying it using the formula ="Span"&COPY&"!X, but I'm not getting correct results.
Am I using the correct syntax in the formula? If that won't work is another way to accomplish it?
Thank you!
ussmex
Re: Repeat a Component Across Varying Spans
Postby pcmoor » Tue Jan 19, 2016 7:27 am
use conditional statements
for X attribute, =if(copy=1, span1)+ if(copy=2, span1+span2)....
pcmoor
Postby ussmex » Tue Jan 19, 2016 8:08 am
Thank you pcmoor!
ussmex
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Dynamic Components
Who is online
Users browsing this forum: No registered users and 2 guests
Visit our sponsors:
