by pilou » Sat Sep 05, 2015 6:30 pm
Voronoï Diagram by Max Smirnov Select Voronoi: Name it, Select Polygon: name it Select Voronoi's lines Call Boolean Inter Click Polygon Et voilà!
- Top SketchUcator
- Name: Pilou
- Operating system: Windows
- SketchUp version: 2017
- License type: Free/Make
- SketchUp use: hobby
- Level of SketchUp: Advanced
by olishea » Sun Sep 06, 2015 8:32 pm
does it work in 3D?!
oli
olishea
- Premium Member
- Name: olishea
by pilou » Sun Sep 06, 2015 9:32 pm
You can make yet some things with it!  (and it's work in progress! )
- Top SketchUcator
- Name: Pilou
by pilou » Sun Sep 06, 2015 10:06 pm
- Top SketchUcator
- Name: Pilou
by olishea » Mon Sep 07, 2015 4:56 pm
There is a [ missing from your link mate One day, i swear, there will be a plugin where you just click "apply pattern" and then BOOM it's done! Whatever voronoi/tessellation you like. Just couple of clicks!! One day!!!
oli
olishea
- Premium Member
- Name: olishea
by pilou » Sat Sep 12, 2015 3:14 am
FatLines by Max Smirnov
- Top SketchUcator
- Name: Pilou
by pilou » Sat Sep 12, 2015 3:19 am
Delcorners by Max Smirnov Voronoi, Delcorners, Flow
- Top SketchUcator
- Name: Pilou
by olishea » Sat Sep 12, 2015 6:13 pm
Smirnov is on fire! wow!
oli
olishea
- Premium Member
- Name: olishea
by pilou » Fri Sep 25, 2015 1:31 am
New version of Subdivision by Max!  (Trick for volumes with difficulties like here : export as OBJ with triangles then _importObj (By Max  and voilà!
- Top SketchUcator
- Name: Pilou
by pilou » Sat Sep 26, 2015 6:13 pm
- Top SketchUcator
- Name: Pilou
by pilou » Fri Oct 02, 2015 12:58 am
Teasing by Max Smirnov
- Top SketchUcator
- Name: Pilou
by pilou » Tue Oct 06, 2015 9:49 am
A new 3.1 version of MoI (Mac version), to fix problems when running in OS X 10.11 "El Capitan"  else in few days!
- Top SketchUcator
- Name: Pilou
by pilou » Wed Oct 07, 2015 1:13 am
Subdivision Beta 8 "Open Surfaces"
by Max Smirnov
Pig By Max Smirnov
- Top SketchUcator
- Name: Pilou
by pilou » Sat Oct 10, 2015 9:46 am
beta 9 Subdivision by Max Smirnov
- Top SketchUcator
- Name: Pilou
by pilou » Wed Oct 14, 2015 1:27 pm
[BBvideo 640,480]http://www.youtube.com/watch?time_continue=1&v=n9C9Ydki75E[/BBvideo]
- Top SketchUcator
- Name: Pilou
by pilou » Mon Oct 19, 2015 1:29 pm
System KitBash objects added!
- Top SketchUcator
- Name: Pilou
by pilou » Thu Oct 29, 2015 12:14 am
Nodes arrive inside Moi! (in developpment) By Max Smirnov!
- Top SketchUcator
- Name: Pilou
by olishea » Wed Nov 04, 2015 9:31 pm
Thanks for the updates Pilou! Much appreciated.
oli
olishea
- Premium Member
- Name: olishea
by pilou » Thu Nov 19, 2015 5:15 pm
In fact I didn't spend a lot of time writing it. I decided to finish the main core script, and then share it with community. I still do not have plans to write the whole node-system for MoI.
- Top SketchUcator
- Name: Pilou
by pilou » Tue Nov 24, 2015 2:03 am
This project is very close to alpha release
- Top SketchUcator
- Name: Pilou
by pilou » Thu Nov 26, 2015 2:21 am
- Top SketchUcator
- Name: Pilou
by pilou » Mon Nov 30, 2015 2:18 am
Released! Elephant by Max Smirnov tuto of Install sorry in French Very cool!
- Top SketchUcator
- Name: Pilou
by pilou » Wed Dec 02, 2015 12:00 am
New Node Rotation! Elephant by Max Smirnov
- Top SketchUcator
- Name: Pilou
by pilou » Fri Dec 04, 2015 2:04 am
Radial Pattern by Max Smirnov of course in English for you!   NodeBox 3 for not MAC!
- Top SketchUcator
- Name: Pilou
by pilou » Sat Dec 05, 2015 12:55 am
Mystery of the Loft Node!  Put it at the end! (file ". nod" linked)
- Top SketchUcator
- Name: Pilou
by pilou » Sat Dec 05, 2015 2:25 pm
- Top SketchUcator
- Name: Pilou
by pilou » Mon Dec 07, 2015 2:05 pm
- Top SketchUcator
- Name: Pilou
by pilou » Sun Dec 13, 2015 1:51 am
- Top SketchUcator
- Name: Pilou
by pilou » Sun Dec 13, 2015 10:50 pm
new version of Radial Pattern
All nodes will be rewrited because core of Elephant is allways improved for achieve the perfection! So more prudent to wait the last version! In next version Zoom of the Nodes Editor, Integration of Formula like the existing by Max So we can have that  and maybe that!
- Top SketchUcator
- Name: Pilou
by pilou » Tue Dec 15, 2015 11:45 pm
Animation above! is working fine!
- Top SketchUcator
- Name: Pilou
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Hardware, Software & Gadgets
