auto make multiple group or component
The ideal place for beginners to get help using SketchUp
Postby grjames » Thu Jan 19, 2012 10:16 pm
Hi all,
I've got a couple hundred buildings floating above my terrain. I'd like to make each of these into their own group or component before dropping them down.
Does anyone know of a workflow or ruby that can do this one time? Like i'd select all the buildings at once and then it would make each individual building its own group or component? kinda like a batch process rather than selection each by itself and making it.
tia,
rob
grjames
Re: auto make multiple group or component
Postby mitcorb » Fri Jan 20, 2012 4:38 am
Hi. This is the closest possibility to what I think you are asking. Check it out.
viewtopic.php?t=31892#p281272
May I suggest that you save as and do this on a second file with a similar name?
User avatar
mitcorb
Top SketchUcator
Postby TIG » Fri Jan 20, 2012 12:14 pm
Copy/Paste this code into a new plain-text file called say TIG-selected_connected_into_components.rb in the Plugins folder.
Code: Select all
require('sketchup.rb')
module TIG
 def self.selected_connected_into_components()
  model=Sketchup.active_model
  ents=model.active_entities
  ss=model.selection
  faces=[]
  ss.each{|e|
    if e.class==Sketchup::Face
      faces << e
     faces << e.edges
  faces.flatten!
  faces.uniq!
  cons=[]
  faces.dup.each{|e|
    next unless e.valid? and e.class==Sketchup::Face and faces.include?(e)
   con=e.all_connected
   con.each{|c|faces.delete(c)}
   cons << con
  model.start_operation("TIG.selected_connected_into_components")
  cons.each{|con|
    grp=ents.add_group(con)
   ins=grp.to_component
   defn=ins.definition
   defn.invalidate_bounds
   defn.name="Component#1" ### will increment
  model.commit_operation
### Usage: Select what faces are to become components
### TIG.selected_connected_into_components in the Ruby Console
Its usage is explained at the end of the code...
You select the appropriate geometry [faces], run the tool by typing/pasting its command - TIG.selected_connected_into_components - into the Ruby Console... all "connected geometry" is made into separate components, named Component#1, Component#2 etc...
To be v2014 compatible encode the file as UTF8-without-BOM [Notepad++.exe encoding>convert option]
4
User avatar
Global Moderator
Postby grjames » Wed Jan 25, 2012 1:30 am
Nice! thank you!
grjames
Postby Lersince1991 » Wed Apr 23, 2014 11:23 pm
TIG I just tried to use this ruby script but couldn't get it to work and brings up an error when loading sketchup, could you please help?
Got it sorry!
missed the "TIG-" off the start of the file name and also was saving in rich text format by accident (fresh OS X installed changed defaults)
Lersince1991
Postby dav78 » Fri Sep 12, 2014 3:46 pm
Hi, I can't make it to work, not sure what I am doing wrong...!
Could somebody provide the .rb file to paste in the plug-in folder?
...and perhaps a plainer step-by-step guide.
dav78
Postby TIG » Fri Sep 12, 2014 11:19 pm
Have you actually read the earlier post ?? viewtopic.php?p=379876#p379876
Copy the suggested text and paste it into a new .rb file, and put it into the appropriate SketchUp Plugins folder.
If you have Windows use Notepad++.exe and encode it as 'UTF8-without-BOM' - a MAC should encode the .rb OK - you haven't bothered to give us any useful info in your SCF user-profile, so we are somewhat hampered by your decision...
If you have specific questions, like, "Where is my Plugins folder?", or you don't understand security permission for such folders proir to v2014, then please ask clear questions...
We ARE here to help, but we can't read minds..........
You need to restart SketchUp and type into the Ruby Console to run this script......
User avatar
Global Moderator
possible off-axis default in script?
Postby sketchartist023 » Mon Feb 23, 2015 3:21 pm
Hey Guys :) I tried the code and made the simple txt file into an .rb and created a plugin folder in which it read the rb fine when I went into the ruby console and typed the command. All the selected components were created but when I make components on my own, the axis is offset. I noticed this when I made a cultist and the thickness was all over the place. So basically, this particular ruby has some defaulted off-axis setting for components. When I create my own components from solids to rename manually (since I don't want to use "component #1, ...) as my cultist names, it still is offset and the component boundary is larger than the actual edges of the solid instead of reading the actual volume corners and faces properly.
When I went into the library support (using an iMac with Mavericks), and deleted the .rb file, the components read the axis' correctly when I closed sketch up and then reloaded the file.
Just wanted to share my experience with it so far. It creates components great! Just every other "new" manual component is off axis and seems to have to be set manually. Solids with angles, like 45s in the corners etc do not work well with resetting axis' manually when this script is in the plugins.
Sometime I would like to be able to use this plugin idea and auto create the component description as the text information that is attached to it! That would be amazing!
I will help you diagnose this if you like and be a test dummy if you want :)
I hope that is enough information to help and appreciate the help if you can :)
User avatar
sketchartist023
Postby Kenny » Fri Apr 17, 2015 11:15 am
I've just tried this on SketchUp 2015 and I get the attached error. Does it work on 2015?
If it's not 2015 compatibility at issue then it could be encoding. I created the file in Notepad, which I've also attached. I chose UTF8 encoding however I couldn't see an option for "without-BOM [Notepad++.exe encoding>convert option]". I'm not familiar with coding so I don't really know what this is.
Tig, Ideally it would be good to have this as a standard plugin which could be autoinstalled. :)
Kenny
Postby TIG » Fri Apr 17, 2015 11:42 am
Use Notepad++ to convert the file's encoding to UTF-8_without_BOM and save it.
It IS a standard encoding format in the list.
That is the encoding format required in > v2013, it also works in earlier versions.
Attached is the converted .rb, BUT please check how to do it yourself...
To make it easily installable simply ZIP the RB fie, then rename the file-type suffix from .zip to .rbz...
Again I have attached one, BUT once again, please check how to do it yourself...
TIG-selected_connected_into_components.rbz
User avatar
Global Moderator
Postby Kenny » Fri Apr 17, 2015 2:17 pm
Thanks TIG that's great. The problem was that I was using Microsoft Notepad and not Notepad++ which I had to download.
Regarding the installable file, does it create a menu item anywhere? I can't see any. It would be good if you could select the geometry, then either right click or click a menu item under Extensions which would make the multiple components, rather than having to paste into the Ruby console each time. It's no big deal however as the fact that I can do it all is a massive time saver, so thanks again for creating it.
Kenny
Postby TIG » Fri Apr 17, 2015 4:37 pm
If you read the usage it runs from the Ruby Console with TIG.selected_connected_into_components
It's easy enough to add a menu item...
Edit the file using Notepad++ and at near start find module TIG
Immediately after it, insert these new lines.
Code: Select all
unless file_loaded?(__FILE__)
  UI.menu("Plugins").add_item("TIG.selected_connected_into_components"){self.selected_connected_into_components()}
  file_loaded(__FILE__)
Save it and restart SketchUp to reload...
User avatar
Global Moderator
Postby Kenny » Fri Apr 17, 2015 5:26 pm
Excellent, thanks again TIG.
Kenny
Postby fendarria » Thu Aug 27, 2015 9:15 am
thank you TIG.. but in my case i want to group every face in the model.
for example: i have 63 face in a sofa model. i want 63 seperate group/component in one click.
for your ruby script, it only make component touching all faces.
how can i achieve that?
fendarria
Postby TIG » Thu Aug 27, 2015 10:23 am
@fender
Copy+Paste the one-liner below into a Notepad++ file.
The reason for that is so you can edit the start part n="???", this sets the name of each group Face#1, Face#2 etc... If you are processing several parts it might be useful to have differing names ? They list in the Outliner in alphanumerical order.
Select what you want to separate into groups - only faces are processed so no need to be too careful, just ensure the faces you want to group are included.
Copy all of the text.
Open the Ruby Console.
Paste the text.
Press <enter>.
Now all selected faces are made into separate groups.
It is one step undo-able...
Code: Select all
n="Face";m=Sketchup.active_model;s=m.selection;fs=s.grep(Sketchup::Face);s.clear;a=m.active_entities;m.start_operation("~",true);fs.each_with_index{|f,i|g=a.add_group(f);g.name="#{n}##{i+1}"};m.commit_operation
User avatar
Global Moderator
Postby fendarria » Thu Aug 27, 2015 10:32 am
@TIG
it works perfectly!! thank you so much! you save my day
fendarria
Postby ssokol » Mon Mar 14, 2016 1:08 pm
great thanks!!!
User avatar
ssokol
Postby Klamek » Fri Apr 21, 2017 12:38 pm
Great plugin!
Saved my time for hundreds of separated objects to group/component!
Klamek
Postby keitheseymour » Thu Feb 22, 2018 6:32 pm
Took me a few goes to get it running but got there! This is just what I needed. Huge thanks, Tig.
keitheseymour
Postby maxhouserocks » Mon Feb 25, 2019 5:52 pm
this is such a great time saver for tricky situations. thanks!
Has this ever been officially made into a plugin for the masses?
thanks,
bob
User avatar
maxhouserocks
Postby Ozansahin » Tue Jan 14, 2020 2:55 pm
Hello;
I've tried several times but it doesn't work. I don't understand where is my fault :(.
I cannot see any shortcut :(
I use SU 17 thanks for helping
Ozansahin
Postby juju » Tue Jan 14, 2020 9:56 pm
Ozansahin wrote:I use SU 17 thanks for helping
fix it in your bio (currently showing SU8) then you wouldn't have to remember to type it
User avatar
juju
Premium Member
Premium Member
Postby ansdud » Thu May 14, 2020 3:38 am
omg. it works perfectly. your are god TIG
ansdud
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Newbie Forum
cron
Who is online
Users browsing this forum: No registered users and 3 guests
Visit our sponsors:
