MOI 3D on MAC / PC 10 Oct 2019
Re: MOI 3D 3.0 on MAC OSX PC is now available! 09/20/2014
Postby pilou » Thu Jun 18, 2015 1:00 am
Nuts & Bolts By Max Smirnov
Image of the French version! ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Sun Jun 28, 2015 1:41 am
Dimension by Max Smirnov!
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Sat Jul 04, 2015 1:37 am
Dimensions more and more effective! ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Sat Jul 04, 2015 1:30 pm
By Chri
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Fri Jul 10, 2015 2:46 am
Angles arrived! ;)
and arc circles lenght !
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Mon Jul 13, 2015 4:06 pm
Dimension of curves! :thumb:
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Sun Jul 19, 2015 12:27 am
Dimensions
Release candidate ;) v.99
Added:
Feet/Inches format
Angles > 180
Type names
Type 6 activates circular mode automatically
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Fri Aug 07, 2015 8:19 am
Exotic! :)
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Mon Aug 17, 2015 10:02 pm
HeightMap by Max Smirnov!
Transform image in volume! :fro:
French version ;)
By Max Smirnov
Speedy Galerie
User avatar
Top SketchUcator
Postby olishea » Wed Aug 26, 2015 2:48 pm
Pilou, I just bought MOI3D! Time to get sculpting!
oli
User avatar
olishea
Premium Member
Premium Member
Postby pilou » Wed Aug 26, 2015 4:14 pm
@ Olishea
Bienvenue to the club! :D
Have fun modeling with it! :)
Sure a little less powerful than Rhino but... :fro:
Don't hesitate for any questions!
Here or on the Moi forum where you have direct access with the creator Michael Gibson with very detailed answers!
And this is priceless! :thumb:
Chipp Walters is fan of it! :)
Speedy Galerie
User avatar
Top SketchUcator
Postby olishea » Wed Aug 26, 2015 7:35 pm
pilou wrote:@ Olishea
Thanks Pilou! And thanks for updating this thread, I keep watching the videos.
I am only using MOI for 3D printing projects, so I don't need Rhino....I got tired of trying to make SU do what I wanted. Even just simple intersections/booleans were sending me crazy.
I will surely be frequenting the forum with LOTS of questions haha!
oli
User avatar
olishea
Premium Member
Premium Member
Postby pilou » Wed Aug 26, 2015 8:39 pm
It's perfect for that and others materials! :)
By Samuel Zeller from this creepy original image!
Redrawing in Moi
Result! :fro:
No Problem we are on the same Greenwich Time Zone! :mrgreen:
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Mon Aug 31, 2015 12:15 am
Array3D by Max Smirnov
Speedy Galerie
User avatar
Top SketchUcator
Postby olishea » Tue Sep 01, 2015 10:01 am
this guy is firing out some impressive plugins isnt he!
oli
User avatar
olishea
Premium Member
Premium Member
Postby olishea » Tue Sep 01, 2015 10:04 am
the subdivide plugin is exactly what i needed!
oli
User avatar
olishea
Premium Member
Premium Member
Postby pilou » Tue Sep 01, 2015 10:59 am
SUbdivision
Will work fine with Bridge, Split ;)
New version of Array 3D : Random, Base/ target
Speedy Galerie
User avatar
Top SketchUcator
Postby olishea » Tue Sep 01, 2015 5:37 pm
OK I got all the scripts installed, time to have some fun!
I put the scripts in the command folder but I can't see them anywhere when I open MOI? There are no buttons/icons?
I feel like a newb again! :D
oli
User avatar
olishea
Premium Member
Premium Member
Postby pilou » Tue Sep 01, 2015 6:31 pm
You can make 2 things! :) (if you have a PC ? )
Press Tab and write the name of the plugin!
Here the subdiv's name script is _Subdiv_6 (no sensitive case)
Or make a shortcut ! Menu Options (bottom screen) / ShortCuts
Put in the left column any combinaison of keys
and on the right column _Subdiv_6 :ugeek:
Have fun modeling !
Speedy Galerie
User avatar
Top SketchUcator
Postby olishea » Tue Sep 01, 2015 6:59 pm
OK I will have another go. I am using both PC and Mac...just to confuse you! :D
oli
User avatar
olishea
Premium Member
Premium Member
Postby olishea » Tue Sep 01, 2015 7:07 pm
I am just using my Mac at the moment to have a play....but I am still confused.
I have pasted the script into the commands folder.
Opened up MOI.
Added shortcut.
Then I get the error message? I am simply subdividing a cube for this test.
oli
User avatar
olishea
Premium Member
Premium Member
Postby pilou » Wed Sep 02, 2015 12:19 am
Try with _subdiv_beta6 as you have in your list's files :mrgreen:
Sorry for the confusion, i had changed my name of file! :oops:
After the writing name, of course Enter! :geek:
Ps Of course you can make a Copy / Past of this name file from a Text file of numerous scripts!
(because install more "easy" is some time losted at the beginning : play first with the toy) :fro:
I have these Shortcuts for the "subdivision" modeling process)
Speedy Galerie
User avatar
Top SketchUcator
Postby olishea » Wed Sep 02, 2015 1:52 am
yes pilou! good spot!
thanks for the advice. I am loving MOI so far!
oli
User avatar
olishea
Premium Member
Premium Member
Postby pilou » Wed Sep 02, 2015 2:13 am
yes, it's a true gem :)
New version of the _array3d ;) speed*2!
Speedy Galerie
User avatar
Top SketchUcator
Postby olishea » Wed Sep 02, 2015 6:03 pm
Nice! I got Subdivision to work thanks very much mate!
I just need to work out how well a subdivided solid exports.....when I export to OBJ or STL it seems to go quite jagged even at high resolution/poly.
oli
User avatar
olishea
Premium Member
Premium Member
Postby pilou » Wed Sep 02, 2015 6:47 pm
Example, image, files ? :mrgreen:
Speedy Galerie
User avatar
Top SketchUcator
Postby olishea » Thu Sep 03, 2015 2:09 am
It's OK I'll sort it out. All the mesh previews look unsmoothed when uploaded to the 3D printing websites. It's more noticeable in the first image....it could be because i'm trying to subdivide and then punch holes/fillet afterwards and it causes a messy mesh. The fillets are a different resolution to the subdivided mesh so some conflict will occur. I'll get there I'm just being silly. :D
oli
User avatar
olishea
Premium Member
Premium Member
Postby pilou » Fri Sep 04, 2015 2:02 pm
File 3DM?
In waiting a little tut by Chipp Walters
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Sat Sep 05, 2015 9:29 am
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Sat Sep 05, 2015 6:28 pm
Speedy Galerie
User avatar
Top SketchUcator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Hardware, Software & Gadgets
cron
Who is online
Visit our sponsors:
