The "Duh!" thread (aka the Doh! thread)
General discussion related to SketchUp Pro and Make
Re: The "Duh!" thread (aka the Doh! thread)
Postby cotty » Sat Jun 06, 2015 8:31 am
icedkasz wrote:Just discovered that ctrl+shift+V pastes in place. Didn't know that for 3 versions. I've made messes out of contour maps by being millimeters off.
In the preferences, you can switch those two and use Ctrl+V for paste in place and Ctrl+Shift+V for simple pasting (I'm using pasting in place much more often).
User avatar
cotty
Top SketchUcator
Postby Bob James » Sat Jun 06, 2015 8:25 pm
You're not alone
User avatar
Bob James
Premium Member
Premium Member
Postby JQL » Sat Jun 06, 2015 11:12 pm
You're not alone
I never found that myself because that was exactly the shortcut I used with V8. As I always imported shortcuts I thought that was exclusively my command... I guess that counts as a Duh!
User avatar
JQL
Premium Member
Premium Member
Postby thomthom » Sun Jun 07, 2015 10:04 am
Oh - wait - that shortcut is now out of the box?
User avatar
PluginStore Author
PluginStore Author
Postby JQL » Sun Jun 07, 2015 11:09 am
It isn't? I always export/import it before I try it... so how would I know?
It seems this will get some more duhs!
User avatar
JQL
Premium Member
Premium Member
Postby thomthom » Sun Jun 07, 2015 3:36 pm
I'm glad it's now a default - as it's the first shortcut I ever set up. (Though I also import so I missed this.)
User avatar
PluginStore Author
PluginStore Author
Postby pbacot » Sun Jun 07, 2015 5:58 pm
I set mine to just shift-v long ago and didn't know the default setting. Oddly I made so it is opposite of CAD, instead of changing the regular paste short-cut-- if that makes sense, so really I keep switching from one program to the other. Why am I writing this? Sitting here on first cup of coffee just killing time that I will want for later on...
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
User avatar
Top SketchUcator
Postby jiminy-billy-bob » Sun Jun 07, 2015 6:11 pm
Are you sure?
Not on my PC. No shortcut is assigned to Paste in Place.
User avatar
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby JQL » Sun Jun 07, 2015 9:14 pm
jiminy-billy-bob wrote:Not on my PC. No shortcut is assigned to Paste in Place.
That was the sneaky suspicion I had.
User avatar
JQL
Premium Member
Premium Member
Postby pilou » Sun Jun 07, 2015 10:52 pm
Maybe someones don't know this one! :)
Very uggly speedy test, it was just for see if that is working! :roll:
That's work fine! 8-)
Power of the "<>"! :thumb:
3
Speedy Galerie
User avatar
Top SketchUcator
Postby Wo3Dan » Mon Jun 08, 2015 10:35 pm
pilou wrote:....
And \n for line feed
So when you have a dimension value 2500mm, adding \nceiling height results in:
2500mm
ceiling height
(plain text, not associated anymore with changes in geometry)
But replacing 2500mm by <>\nceiling height becomes:
2500mm
ceiling height
(text with value following changes in geometry)
User avatar
Wo3Dan
Top SketchUcator
Postby pilou » Tue Jun 09, 2015 12:10 am
Thx for the Info! :enlight:
Speedy Galerie
User avatar
Top SketchUcator
Postby Bob James » Sun Jun 21, 2015 10:57 pm
Bob James wrote:
JQL wrote: Apologies accepted if you post it on the Duh thread!
So here goes my duh:
Bob James wrote:This seems so simple that it must already exist, but I could not find it.
For example: I want to make a 4" square post at a specific spot. If I wanted a round post there I would just select the circle tool, place the cursor at the point and drag out (or put a value in the VCB).
I'd like to be able to do that for a square: select tool, place the cursor at the point and drag out (or put a value in the VCB)
I apologize if this already exists
JQL wrote:LOL bob you can make your life difficult if you draw a 4 sided circle and explode it.
Or you can make your life painless if you draw a 4 sided polygon without exploding it.
Those two are native tools. Do you forget sketchup also has native tools?
Your suggestions create 45 deg rotated squares.
Why can't someone just make a simple extension to make an orthogonally positioned square starting from a center point?
User avatar
Bob James
Premium Member
Premium Member
Postby JQL » Sun Jun 21, 2015 11:00 pm
Bob James wrote:Your suggestions create 45 deg rotated squares.
If you hit CTRL while designing your square or your four sided circle, you it will create the squared shape as you wish it to... (at least on 2015 I don't know if it's like this in every SU version)
User avatar
JQL
Premium Member
Premium Member
Postby Dave R » Mon Jun 22, 2015 10:06 am
That was a new feature in SU2015.
Bob, the extension already exists in the Tools on Surface set. I'm sure you must have that one in your library.
User avatar
Global Moderator
Postby pilou » Mon Jun 22, 2015 1:42 pm
The big one of the day! :)
I am sure that will be the same for some other users! :mrgreen:
When you make a Push Pull + CTRL that make a new volume from the start face ok
as usual! :)
but...
that can be used also for make an "impossible Push Pull" ! 8-)
(And thx to TIG for his Solid Solver at the end! :thumb:
Speedy Galerie
User avatar
Top SketchUcator
Postby Bob James » Mon Jun 22, 2015 5:37 pm
Close, but you have to move it around until you find the axis pop-up, enter a length, stretch it in the other axis, and enter the same length. And you have to enter the half-length in each case or the square will be twice the size you want: simple except when the square is to be 4 3/16"
Still seems like a trivial extension to make for a ruby-guy (like sdmitch,for example): pick a point and enter the size of the square (not the half length) and it automatically draws the correct size square on the orthogonal axes.
User avatar
Bob James
Premium Member
Premium Member
Postby Rich O Brien » Mon Jun 22, 2015 8:42 pm
@bob
why not use a component library of predefined sizes?
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby JQL » Mon Jun 22, 2015 10:32 pm
Well that would work with one component alone if you one unit. Insert it at point scale it using CTRL and SHIFT input your dimension.
User avatar
JQL
Premium Member
Premium Member
Postby derei » Fri Jul 03, 2015 4:46 pm
I just "Discovered" the wheel... :ecstatic:
using "deg" or "mm" when setting the camera focal distance, can switch between actual focal distance (35mm equiv) and fov (field of view) measured in degrees. :geek:
DESIGNER AND ARTIST DEREI.UK
User avatar
derei
Postby Pixero » Sat Jul 04, 2015 11:15 am
I have to add one I discovered the other week by pure accident.
Right click on a toolbar to see a list of all loaded and unloaded toolbars.
User avatar
Pixero
Postby pilou » Sat Jul 04, 2015 1:23 pm
On toolbars on The Main toolbar! Not on any toolbars floating on the screen! ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby pbacot » Sat Jul 04, 2015 3:40 pm
Pixero wrote:I have to add one I discovered the other week by pure accident.
I don't think so on a Mac. (SU toolbars and windows on Mac are junk).
User avatar
Top SketchUcator
Postby JQL » Sun Jul 05, 2015 11:51 am
pbacot wrote:I don't think so on a Mac. (SU toolbars and windows on Mac are junk).
I'd say the only thing I envy from SU for Mac is pdf import... we don't get that on windows
User avatar
JQL
Premium Member
Premium Member
Postby david_h » Thu Oct 08, 2015 8:11 pm
I'm posting my query here because it is probably pretty obvious to you guys out there, but I've always struggled with it. . .
I've always found the "Scenes" menu to be counter-intuitive and I can't seem to get it to do what I think it is telling me to do. Specifically, I want one particular scene to be a section but not others I update via the scenes menu, and ONLY that scene but when I tab thru the others the section plane is still active and I have to switch it off. what am I doing wrong. Likewise for things like various styles, or display modes, etc.
Please help me so I can slap my head and go "DUH!"
Thanks,
David H
ps My last query got absolutely no response whatsoever. Still looking for some insight on that as well.
Thx,
D
If I make it look easy. . .then it probably is.
User avatar
david_h
Top SketchUcator
Postby gonashvili » Thu Oct 08, 2015 9:22 pm
I've got a question about [regular] selecting, or deselecting, rather. You hit he SHIFT key and it works as +/-, right? Is there a way to have just the 'MINUS' function, so you actually ONLY deselect?
Cause, when you select some objects and then when you want to deselect you actually might select some undesirable ones, know what I mean? Especially when there are a lot of lines or what not.... It actually acts as an INVERSION, rather than just DESELCTION.
User avatar
gonashvili
Postby massimo » Thu Oct 08, 2015 9:25 pm
shift= +/-
ctrl+shift= -
ctrl= +
User avatar
massimo
Postby gonashvili » Thu Oct 08, 2015 9:41 pm
Oh!!! Hah, thanks a lot man!
I mean, DOH! of course.
User avatar
gonashvili
Postby JQL » Fri Oct 09, 2015 1:13 am
david_h wrote:Specifically, I want one particular scene to be a section but not others I update via the scenes menu, and ONLY that scene but when I tab thru the others the section plane is still active and I have to switch it off.
Basically, you're missing the meaning of having those checkboxes checked.
What they mean is:
- When you're creating a scene only the settings that are checked will be stored. All unchecked settings will be not be stored. (Checking sections box on will store current sections settings. If you have an Active section it will be the active section for the scene. If you have no active section, the scene will have no section affecting it. If there are no sections in the scene, then you'll also have no section affecting it.)
- When you have settings unchecked, then you're not storing a state for that section on the scene. (Unchecking Sections will make the scene don't care if a section is active or not. If you insert a section in the model, the scene will be cut, if you change to another scene and come back to this scene, the section from the other scene will still be active, if you change to a scene that has no active section, coming back will keep the scene without an active setting.) Unchecked settings are, therefore, neutral. They can be either on or off, depending on what was the current state when you changed to that scene...
So, in fact, unchecking sections will not make the model fully viewable. It will "randomize" the sections on that scene, unless you know what you're doing, you'll have no control.
User avatar
JQL
Premium Member
Premium Member
Postby david_h » Fri Oct 09, 2015 3:07 pm
JQL wrote: It will "randomize" the sections on that scene, unless you know what you're doing, you'll have no control.
thanks for the response. I think i got half of that. :bounce: But your last sentence kinda summed it up. Is there a Tutorial or something that talks about this? I thought it was much simpler and clearer back in the old days when these were called "Pages". Seemed to work better. :(
User avatar
david_h
Top SketchUcator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: Google Bot, Sekta, wasi and 3 guests
Visit our sponsors:
