Watercolor palette for shapeways
That is really cool, have you tried on it on a project? I might have to go that a go.
Thanks again for all the help!
s
No, I haven't. The difficult part will be to choose the right fit so that it can be rotated slightly and still holds together.
Stuart, I'm always glad to help you, and even more pleased to you posted publicly. This way others with the same questions will benefit and you get answers faster.
I would try a sort of piano hinge, where half of the hinge parts are on the top of the box, and the other half are on the bottom half, then run a brass rod through for a pin.
(not my image)
1/16" should be thick enough, but you will have to paint or otherwise seal the plastic because it is very porous.
You should also increase the resolution of the circles used to make the paint holding trays so that you get a smoother surface. Running fredo's Roundcorner plugin on the sharp corners is a good idea.
Thanks I will give that a go!
s
I have put some hinges on the boxes.
So the question, is it worth about $60 to print it?
How porous is the plastic, will it leak?
I just noticed I have to put some bump outs by the hinges, so when it is open it will stay flat..
thanks for all the help!
s
The hinges you made look great! Yes, the plastic will leak unless you paint it. $60 sounds about right for commercial printing. You could get it printed cheaper on a small desktop FDM machine, but the quality won't be nearly as good and you'll still have to seal it with paint or epoxy.
I bought the four well side of the palette, $23 bucks delivered. I chose white polished plastic...
I thought I would see how good it is before buying the other side.
Thanks for all the help!
Stuart
good thinking to just print a small part for testing, Stuart. Please let us know how it goes!
Looks great, Stuart!
Thanks for all your help!
It went great and I'm looking forward to doing more 3D things!s
