Visualizer for SketchUp
Re: Visualizer for SketchUp
Postby vidy » Wed May 13, 2015 2:08 am
willanie wrote:Hi Driven,
Interesting suggestions, but I don't think they are a better workaround then rendering Visualizer twice.
In fact, making an alpha channel outside of Visualizer may result in some edge mismatch.
The creation of the alpha channel in Visualizer was refined to the point where compositing in paint software like Gimp or Photoshop works without any edge fringing.
willanie
Got it Willanie, thanks for your information
Regards,
VD
still so much to learn..
vidy
Postby pilou » Wed May 13, 2015 9:01 am
It's not a so hard work to render twice! ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby willanie » Wed Jun 10, 2015 4:47 pm
An example of Visualizer1.3 enhanced mode.
This mode can often result in very bright single pixels also known as "fireflies" caused by an extremely bright light source like the sun.
The despeckle noise reduction feature is there to help remove them.
The back wall in this scene is assigned a material with a name that includes the word "mirror" for sharp reflections.
willanie
PluginStore Author
PluginStore Author
Postby pbacot » Wed Jun 10, 2015 7:00 pm
Thanks for the notes Wilanie
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
User avatar
Top SketchUcator
Postby vidy » Thu Jun 11, 2015 2:02 am
Nice one Willanie..
vidy
Postby willanie » Mon Jun 15, 2015 7:09 pm
another example ... this one took about 35 minutes to render on my desktop
a couple of the fireflies weren't removed by the despeckle mode but it still looks pretty nice
willanie
PluginStore Author
PluginStore Author
Postby cotty » Mon Jun 15, 2015 7:15 pm
Yes, very nice!
:thumb:
User avatar
cotty
Top SketchUcator
Postby pbacot » Sun Oct 11, 2015 7:23 pm
I looked at the enhanced material settings. Which is best for car paint? The metal settings are too metallic. Plastic doesn't quite make it.
User avatar
Top SketchUcator
Postby driven » Sun Oct 11, 2015 9:34 pm
you can link them together for different effects e.g. shiny_plastic, shiny-tile...
driven
PluginStore Author
PluginStore Author
Postby Mike Lucey » Sun Oct 11, 2015 10:51 pm
I've been using Visualizer since it first launched. It suits me as I'm not really into spending any time on producing renders. I was disappointed when they announced that they would not be further developing the application but at least they made the current version free to use.
A couple of days ago I came across AmbientOcclusion for SketchUp http://www.ambientocclusion-sketchup.com
Its much like Visualizer, couple of clicks and after a few minutes you have a render. It also offers the option of rendering in the SketchUp viewport which I rather like as against rendering in a window. After seeing the first in-viewport render I thought that Trimble SketchUp should buy this app and include it in SketchUp Pro ........ just a thought. It definitely would distance SketchUp Pro from SketchUp Make!
There are two versions of AmbientOcclusion, Lite at $39 which only produces mono renders and Pro at $89 that does color, textures and depth-of-field effects.
Its expensive when compared to Visualizer, originally at $20 and now free, but I think the output quality is far superior to Visualizer in far less time, just a few minutes for me in most cases, quite impressive.
I have emailed the developers and they advise that they have lighting among other features on the 'to do' list. Hopefully they will keep improving the plugin without making it bloated.
Here is a Visualizer and AmbientOcclusion render of a little project I'm working on. Both renders were done in around 3 minutes and I spent zero time fiddling around with settings.
User avatar
Mike Lucey
Mayor
Postby willanie » Mon Oct 12, 2015 12:40 am
I do like the added shape detail provided by the ambient occlusion shading. Can you get reflections?
willanie
PluginStore Author
PluginStore Author
Postby pbacot » Mon Oct 12, 2015 2:01 am
Thanks, I thought so but I wasn't sure it was doing anything. I'll experiment more. I need reflections for exterior shots. I'd like to see more AO than Visualizer but not quite happy with what I see in the AO 4 SU app. If I want to spend more time, I go to Twilight.
BTW with the poor materials window on Mac Sketchup, it is still slow and tedious just to change material names to try different effects.
User avatar
Top SketchUcator
Postby Mike Lucey » Mon Oct 12, 2015 2:05 am
willanie wrote:I do like the added shape detail provided by the ambient occlusion shading. Can you get reflections?
I think so Will. Attached is an image from the AO site which shows reflections. I have not tried it out yet.
User avatar
Mike Lucey
Mayor
Postby pilou » Fri Nov 20, 2015 3:58 am
For SU 2016 (Visualizer yet installed on SU 2015)
Installation don't work directly ! :shock:
(I suppose that is working directly if Visualizer don't yet installed!)
A little trick! (For Windows 8.1 - I don't know Mac's world! )
Make this new folder Plugins (don't existing because 2016 is new and empty)
and copy past from the ProgramData / SU 2015:
Folder ImaginationVisualizer and file ImaginationVisualizer.rb
That's all! :ugeek:
You must have that! :)
Works like a charm! :fro: And works in duplication 2015 2016 ! :ugeek:
Speedy Galerie
User avatar
Top SketchUcator
Postby driven » Fri Nov 20, 2015 4:36 am
on a mac just move /copy the folder and file into the User plugin folder and it works fine...
driven
PluginStore Author
PluginStore Author
Postby willanie » Fri Nov 20, 2015 7:41 am
Great! ... I was wondering if making it work for 2016 was as easy as that.
thanks
willanie
PluginStore Author
PluginStore Author
Postby pbacot » Tue Nov 24, 2015 6:25 am
Has anyone had luck with pool water for enhanced materials? With a texture you get ripples, but the pool water only comes out very dark blue for me, not good for swimming pools. "Water" texture under NON enhanced textures looks OK but no ripples.
User avatar
Top SketchUcator
Postby willanie » Tue Nov 24, 2015 8:24 am
Hi pbacot,
You can use a png image with an alpha channel that is less than 1.0 or 255
Here is an example.
willanie
PluginStore Author
PluginStore Author
Postby pbacot » Tue Nov 24, 2015 8:55 am
Thanks! So the trick is the texture?
User avatar
Top SketchUcator
Postby pilou » Tue Nov 24, 2015 11:50 am
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Tue Nov 24, 2015 12:08 pm
And with the 2016 it's very more easy because there are some new Materials !!! ;)
So nothing to do! :fro:
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Tue Nov 24, 2015 12:16 pm
Nothing to do, just wait 10 secondes for undarkness! :)
So you can re-import it in the 2015 and render if needing! :D
WIth Ivy ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby pbacot » Tue Nov 24, 2015 5:44 pm
Thanks Pilou! That might make DL 2016 worthwhile. (I have to update Mac OS--2016 does not work on Lion I think.)
User avatar
Top SketchUcator
Postby frankwil » Wed Nov 25, 2015 9:08 am
Can anyone expound on getting Visualizer to work in Sketchup 2016 for Mac OS X? I'm seeing no plugins, or folders for that matter, anywhere inside Sketchup 2015 that I can identify as belonging to visualizer, though I know it's there and is working for that version of SU. My problem is that I've just drawn some fairly complex models in SU 2016, but can't get visualizer to work after a normal install, and don't want to have to recreate them in SU 2015.
frankwil
Postby juju » Wed Nov 25, 2015 10:23 am
frankwil wrote:My problem is that I've just drawn some fairly complex models in SU 2016, but can't get visualizer to work after a normal install, and don't want to have to recreate them in SU 2015.
Unfortunately I can't help with the earlier part of your query, but you should be able save the SU2016 file as a SU2015 file without any trouble at all, no need to recreate the model...
User avatar
juju
Premium Member
Premium Member
Re: Visualizer for SketchUp 2016 or 2015
Postby beacharch » Fri Dec 04, 2015 3:58 pm
How can I get the APP to work on Mac OS X? I saw the earlier post and saw no answer. How can I get to work?
beacharch
Postby willanie » Mon Dec 07, 2015 7:17 pm
Hi beacharch
This approach assumes you have already installed Sketchup2015 or Sketchup2014 and Visualizer.
After installing Sketchup2016
dont start Sketchup2016 yet and go to folder
/Library/Application Support/
If there isn't one already create this folder hierarchy(exactly matching upper and lowercase)
/Library/Application Support/Sketchup 2016/Sketchup/Plugins
from /Library/Application Support/Sketchup 2015/Sketchup/Plugins
copy these two items(one is a folder the other is a ruby file)
paste them into
Now launch Sketchup2016 you should see Visualizer under the Extensions pull-down.
If Visualizer doesn't show up in the Extensions pull-down
click on
Sketchup->Preferences->Extensions
you should see Visualizer with an unchecked toggle box ... check that toggle on
close the preferences window
and Bob's your uncle Visualizer running in Sketchup2016
(you may have to relaunch Sketchup)
4
willanie
PluginStore Author
PluginStore Author
Postby beacharch » Mon Dec 07, 2015 7:39 pm
Thanks, that worked fine!
beacharch
Postby minimalex » Thu Dec 10, 2015 4:33 pm
Attempting to get Visualizer to work on 2016 OS X. I am getting this error message:
Error Loading File ImaginationVisualizer/iv_localization
Could not find included file 'ImaginationVisualizer/iv_localization'
Error Loading File ImaginationVisualizer.rb
Error: #<NoMethodError: undefined method `TRANSLATE' for ImgTecVis:Module>
At first the files didn't copy correctly, but even after I made sure they were I got this message. Any ideas are appreciated, thanks!
User avatar
minimalex
Premium Member
Premium Member
Postby willanie » Mon Dec 14, 2015 8:04 pm
Hi minimalex,
Have you managed to get Visualizer working with Sketchup2016. If not I have some questions.
Is Visualizer working with previous versions of Sketchup?
Did you recently upgrade the OS X version? What OS X version are you running?
I'm a bit confused by your description of the copy procedure. What went wrong initially and how are you confirming that required ruby file and folder is now correctly copied?
willanie
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Extensions & Applications Discussions
cron
Who is online
Users browsing this forum: No registered users and 4 guests
Visit our sponsors:
