[Plugin] $ SpaceDesign - Atttributes and Reports
@thomthom said:
@al hart said:
I suspect that Cyrillic characters will not work, but we will test them if we can find a way to input some.
Looks to be that the webdialog's HTML isn't marked with an UTF-8 character encoding meta tag.
Maybe someone can upload a small .SKP with a Cyrillic named Component, and we can try it out. Setting the Component Description to Cyrillic characters will also help in debugging.
We use Windows dialogs from a DLL, but they are not compiled in Unicode. We can handle some languages - but probably not all.
i have try Chinese language .it not support. -
Still no luck downloading the demo of this. Getting an error in both Firefox and Google Chrome. Any suggestions Al?
I'll have Rich send you a HTTP location, and we can see if that works better.
I plan to make a new version this PM, so lets wait for that.
Al
Is there a plan to somehow pull the prices from an external DB or even an Excel file?
Maintaining the prices of components will be hell of a task to keep up with in some industries.
We have a way to load prices, or other attributes, from a CSV file and then load them into you components which are then saved on the warehouse or into a library
Hi Al,
Thanks, very interesting. Now this plugin has my attention
Is this way documented? Where can I get the specifics? -
@erkan said:
Hi Al,
Is this way documented? Where can I get the specifics?There is a lot of documentation.
Such as [anchor= goto=http://www.renderplus.com/wp2/wk/SpaceDesign_Attributes.htm:2svelgdb]Space Design Attributes[/anchor:2svelgdb]
But you will still, probably, need our help to get this set up properly.
Hey, the installer seems to detect SU2015 but when installation is complete I open SU and all I get is an option saying "SpaceDesign:Load". When I click this nothing happens. There is no option to turn on the Space Design toolbar and there seems to be no way to get SU2015 to recognize SpaceDesign using RBZ....
On windows 7 with SU2015?
Anyone else faced this/dealt with it?
Can you open the Ruby console before you click load and then copy and paste the contents in an email to suport@renderplus.com
Thanks,
Al
*support@renderplus.com?
