[Plugin] FullScreen v5.1.1 (12 September 2021)
@cadfather said:
ok, so that's strange, it happens on all my versions (8, 2014, 2015-x64).
i guess you may want to wait if anyone else has the same problem while i investigate further for conflicts etc. win7 64bit.
Thanks Anton
Hmm...
I thinkswo_on_quit
observer from the new AMS library doesn't work properly. I will look into it. Just to ensure that other observers work, I would like you to do a simple test:- Open Window Settings dialog, and use the menu bar option (Menu)Window > Settings > Full Screen to switch SU full screen. See if the dialog updates its radio-button mode.
- Another test, maximize and restore your SketchUp window using the maximize button on the upper right corner of the window. See if the dialog updates its radio-button mode.
If the dialog doesn't updates, then there is a problem with the whole observing system in my new library; otherwise, it's just this
swo_on_quit
observer not working for some...I would appreciate your tests,
Thanks -
ok, on all tests the radio buttons update properly. this with 2015x64
Phew! It's just the
swo_on_quit
observer method that doesn't work on all systems. I will investigate. -
phew!
I think I know why it isn't working. Basically, when you close the dialog, by default the dialog unregisters the observer, which prevents the
swo_on_quit
observer method from being triggered. But, just to ensure theswo_on_quit
is working, paste and submit this code into ruby console and quit SketchUp. This should show the 'Works!' message box.class AMSObserverTest; def swo_on_quit; UI.messagebox('Works!'); end; end; AMS::Sketchup.add_observer(AMSObserverTest.new)
exactly as you described it - i got a 'works!' button as i quit SU.
(on reopening i still got the green bar)
Ghurait! Try the new version!
(The test you did was meant to check AMS Library observer, which had nothing to do with changing how AMS Window Settings 4.0.0 worked.)
yeeeeaaa! fantastic Master Anton, works ghurait now!
Hi Anton
The settings dialog icon from your plugin tries to open the SU program dialog for an instant but closes and just opens your settings.
No way to move to another monitor or make floating.
just a fixed location per my screen clip.
(Your settings is grayed out by screen capture software)
Win 7 pro
SU 2015 pro
FirfoxThis is a must have script and thanks thanks thanks.
A fix would sure be appreciatedDave
I removed the pick and drag feature, just cause I thought upper-right corner of the view was the best location for the dialog. I might re-add it in the next release.
It looks like my plugin tries create a new dialog, but in fact, that's the same dialog with border and caption removed. I will make it do such procedure faster, so it's done before the dialog is set visible.
Anton
The pick-and-drag gang will beg
Thanksdtr
Hi Anton
The border and caption (SU)will be needed to drag the plugin.
Also to locate the plugin on another screen.
ThanksDave
@dtrarch said:
Hi Anton
ThanksDave
I won't add the border and caption, cause I think the widows frame doesn't look so good, but I will make the green heading draggable and clippable...
Hi Anton
Good news to be able to drag.
Will it lock to other SU captions ?
Very handy to set a typ screen org for templates.
Here is how I use them in any case.
(in line here)
SU Window Settings is on screen #2
Your plugin should have been part of SU from the very beginning.
Thanks for getting back too.Dave
4.1.0 has been released!
- Added pick, drag and clip feature to the new dialog.
- Made borders hide faster.
- Added localization to dialog.
Click on green caption to drag the dialog, easy as that...
Anton
V4.1.0 did not drag (or move) green title and would not close menu when arrow was clicked.
SU title hide was still slow.
Show/Hide toolbars and dialogs killed all my on screen settings for both when invoked.
SorryDave
@dtrarch said:
Anton
SorryDave
It works well on my windows 7. What operating system are you using and what internet explorer version?
Edit: I tested on my Windows XP (with IE9) and it doesn't work just like you described. There is not much I can do about compatibility other than retrieving the original version. So, if you use IE9, use the old version which is compatible in SU2014 and below. You need AMS Library 1.0.9 for the old version too. Here are the links:
ams_lib_1.0.9.zip
ams_WindowSetttings_3.8.1.zip -
Hi Anton
I have Win 7 pro
SU 2015 pro
(this is the problem SU version)
(Not much else installed)
Tig extrude lines.rb
Wiki tools
Works fine on SU 2014 Pro
Firefox browser most updated
Win Explorer 11 installed
Dave -
Ok, I will look into it
By your screenshots I noticed you're using windows classic theme. If that so, try settings it to aero theme in see how it goes.
