[Plugin] FullScreen v5.1.1 (12 September 2021)
It's not, because AMS library isn't.
Thank you Master Anton!
(can't believe i was even few weeks without WS!)laptop is smiling again.
true... and you should see it now!
PS. easy with your psychic powers.... (i sold it today)
They say there's one born every minute.
hahaha... not at all mister, this is a beast which should last plenty (unless you jinx it!)
only strange thing i found, the green settings window always pops up on start, even if i uncheck the option. not sure it's supposed to be that way.
It shouldn't show up if you uncheck the "Show on Start" option. I tested it on my Windows 7, SU8, 13, 14, and 15 64bit. Can you give give me your system background, such as OS and SU version?
ok, so that's strange, it happens on all my versions (8, 2014, 2015-x64).
i guess you may want to wait if anyone else has the same problem while i investigate further for conflicts etc. win7 64bit.
Thanks Anton
Thanks Anton
Hmm...
I thinkswo_on_quit
observer from the new AMS library doesn't work properly. I will look into it. Just to ensure that other observers work, I would like you to do a simple test:- Open Window Settings dialog, and use the menu bar option (Menu)Window > Settings > Full Screen to switch SU full screen. See if the dialog updates its radio-button mode.
- Another test, maximize and restore your SketchUp window using the maximize button on the upper right corner of the window. See if the dialog updates its radio-button mode.
If the dialog doesn't updates, then there is a problem with the whole observing system in my new library; otherwise, it's just this
swo_on_quit
observer not working for some...I would appreciate your tests,
Thanks -
ok, on all tests the radio buttons update properly. this with 2015x64
Phew! It's just the
swo_on_quit
observer method that doesn't work on all systems. I will investigate. -
phew!
I think I know why it isn't working. Basically, when you close the dialog, by default the dialog unregisters the observer, which prevents the
swo_on_quit
observer method from being triggered. But, just to ensure theswo_on_quit
is working, paste and submit this code into ruby console and quit SketchUp. This should show the 'Works!' message box.class AMSObserverTest; def swo_on_quit; UI.messagebox('Works!'); end; end; AMS::Sketchup.add_observer(AMSObserverTest.new)
exactly as you described it - i got a 'works!' button as i quit SU.
(on reopening i still got the green bar)
Ghurait! Try the new version!
(The test you did was meant to check AMS Library observer, which had nothing to do with changing how AMS Window Settings 4.0.0 worked.)
yeeeeaaa! fantastic Master Anton, works ghurait now!
Hi Anton
The settings dialog icon from your plugin tries to open the SU program dialog for an instant but closes and just opens your settings.
No way to move to another monitor or make floating.
just a fixed location per my screen clip.
(Your settings is grayed out by screen capture software)
Win 7 pro
SU 2015 pro
FirfoxThis is a must have script and thanks thanks thanks.
A fix would sure be appreciatedDave
I removed the pick and drag feature, just cause I thought upper-right corner of the view was the best location for the dialog. I might re-add it in the next release.
It looks like my plugin tries create a new dialog, but in fact, that's the same dialog with border and caption removed. I will make it do such procedure faster, so it's done before the dialog is set visible.
Anton
The pick-and-drag gang will beg
Thanksdtr
