[Plugin] Compo Spray 1.4.2 Updated
Hello,
no match for me with CS modified and given by Oxer few posts above. I've tried to install the plugin in "C:\Program Files (x86)\SketchUp\SketchUp 2014\Tools" (even then we should'nt use this folder as explained by TIG) and in "C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins" but no success.
Cherry on the cake, i would like to install this plugin in an additional plugin folder using the Fredo6 tool (doesn't work in this folder neither of course).
Any one to help me ?
Thanks a lot !!
Thanks so much Oxer and MTriple. Your file works perfectly with my sketchup 2014!
To anyone who using Windows and still can't install it: Please extract files(ComposprayToolbar.rb and 1 folder Compospray) to "C:\Program Files (x86)\SketchUp\SketchUp 2014\Tools".
DON'T EXTRACT FILES TO "C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins"
AND IF THEY WERE THERE (Because you tried to install it) Just DELETE. -
Agreed. This works in 2014! Thanks!!!
Hi there,
I do not see any window when clicking on Draw / Compo spray (SU 2013)...
Any idea ?
Thanx -
How I manage to make it work on SU 2013, here in Spain (with bloody accents everywhere...)
1- Copy/Paste CompoSpray folder + .rb in Plugins file as usual
2- Remove all .lingvo but CompoSprayUS.lingvoand it works perfectly ! Nada mรกs....
Not for me in France !
Still not working with my config...
Broken again in 2015!!!
Didier has agreed to allow me to update some of his Plugins that are in in the PluginStore.
I have already done of few of the easier ones...
I'll try and have a look at this one sometime this year ! -
I have now updated 'Compo Spray' for Didier - it is now v2014/2015 compatible, and also works from any custom Plugins folder.
Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=compoSpray
If you have messed on installing it in Tools etc please remove it manually and get/install the latest version... -
Thanks TIG, tested in SU2014 & SU2015 on Mac OSX 10.9.5 and the plugin works fine.
Thanks for the update!
Didier, they're coming in faster than i can download them!
Same here in Win7 64 bit - I hit the button and nothing.
Your message is at odds with the ones following the update
Works fine for me in Win7 64bit !
You do have the latest version installed from the PluginStore?
You have restarted SketchUp ?
AND you have removed any earlier versions of the tool before this ?
Are there any error messages in the Ruby Console ?
When you say you 'hit the button', do you mean the toolbar's button or the dialog's button ?
More feedback please... -
Make sure you have a surface to spray on.
same here and I do have a plane to spray on.
As tig already said, Which Button? Do you get the settings dialog? or does it not even work from the point of clicking the menu?
What button exactly ?
Also any Ruby Console errors ?
Have you definitely removed all of the legacy stuff before installing it ?
Some of you were installing the older version into the Tools folder, and all manner of foolishness !
The updated version clearly working for many of us in v2015, so we need to find what you troublemakers are doing differently -
Error; #<NoMethodError; undefined method `dec' for 0.0;Length> c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;10;in `initialize' c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;98;in `new' c;/users/pete/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/compospray/compospray.rbs;98;in `compoSpray_main' C;/Users/Pete/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/compoSprayToolbar.rb;19;in `block in <top (required)>' SketchUp;1;in `call'
