by JQL » Fri Sep 26, 2014 10:54 am
Breathtaking...
JQL
- Premium Member
- Name: JQL
- Operating system: Windows
- SketchUp version: 2017
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by Krisidious » Fri Sep 26, 2014 7:18 pm
I have no idea what I would do with it... But I like it.
Krisidious
- Name: Krisidious
- SketchUp version: 2015
- License type: Pro
by pep75 » Fri Sep 26, 2014 8:17 pm
One of the best plugins for Sketchup in years!!
pep75
- License type: Pro
- SketchUp use: interior design
by smuncky » Fri Sep 26, 2014 9:10 pm
wow! this is touching into rhino territory.
smuncky
- Name: smuncky
- License type: Pro
by hdpv » Sat Sep 27, 2014 3:07 am
Thank all! it's the same a game
hdpv
- PluginStore Author
- Name: Huynh Duong Phuong Vi
- SketchUp version: 2018
- License type: Pro
by Box » Sun Sep 28, 2014 8:31 pm
It's a great plugin but it has the annoying persistent toolbar problem. Could you look at adjusting it for your next update. TIG wrote: If an author has made his tool's loading code 'unfriendly' it will always open its toolbar, even if you last exited with that toolbar closed... For example if a plugin has the overly simple code: tb.show Which always opens the toolbar, irrespective of your wishes ! To open a toolbar only if the user previously exited with it open [OR it's the first time it's used, e.g. a new installation] the loader code needs adjusting to read something like: tb.show if tb.get_last_state.abs == 1 # TB_VISIBLE/NEVER Which is the code used by the SketchUcation toolbar...
- Name: Box
- SketchUp version: 2020
- License type: Pro
- SketchUp use: other
- Level of SketchUp: Intermediate
by Stinkie » Sun Sep 28, 2014 9:21 pm
Wow.
Stinkie
- Name: Stinkie
- SketchUp version: 2014
- License type: Free/Make
by hdpv » Mon Sep 29, 2014 2:19 am
Box wrote:It's a great plugin but it has the annoying persistent toolbar problem. Could you look at adjusting it for your next update. TIG wrote: If an author has made his tool's loading code 'unfriendly' it will always open its toolbar, even if you last exited with that toolbar closed... For example if a plugin has the overly simple code: tb.show Which always opens the toolbar, irrespective of your wishes ! To open a toolbar only if the user previously exited with it open [OR it's the first time it's used, e.g. a new installation] the loader code needs adjusting to read something like: tb.show if tb.get_last_state.abs == 1 # TB_VISIBLE/NEVER Which is the code used by the SketchUcation toolbar...
maybe on Mac,on Win is no problem I fix for next update,
hdpv
- License type: Pro
by Box » Mon Sep 29, 2014 7:25 am
I don't have a mac.
- Name: Box
- License type: Pro
by hdpv » Mon Sep 29, 2014 8:00 am
i don't know this error,but this code is OK "tb.show if tb.get_last_state.abs == 1"
hdpv
- License type: Pro
by Box » Mon Sep 29, 2014 8:28 am
I know nothing about coding so I gave you a quote from Tig when the issue came up before. I just wanted to point out that your Plugin's toolbar was always popping up whether open or closed previously. I've just installed and tested your Slice plugin and it doesn't do it, so that suggest there is a difference in the code.
I don't mean this as a criticism, simply a bug fix.
- Name: Box
- License type: Pro
by hdpv » Mon Sep 29, 2014 9:19 am
no difference in the code.I use Sketchup 2014,win64 this bug fix is no expect.
hdpv
- License type: Pro
by HornOxx » Fri Oct 24, 2014 11:51 am
hi HDPV, first thank you for this great tool! I have used it for some time and it worked great so far, but since a few days I get the message that I should do an update as soon as I use the plugin (please see screenshot). This is the only plugin that causes this error by now. I run SketchUp 2013 Pro and SketchUp 8 Free on Win7 64bit. I get this message on both versions.
any help is appreciated - thank you
never trust a skinny cook
HornOxx
- Name: HornOxx
- SketchUp version: 2019
- License type: Pro
by hdpv » Fri Oct 24, 2014 12:13 pm
Sorry HornOxx, This trial is expired.
hdpv
- License type: Pro
by Dave R » Fri Oct 24, 2014 12:20 pm
hdpv wrote:Sorry HornOxx, This trial is expired.
Could you change the wording in the message? That message doesn't indicate at all that the trial period has expired and that the user needs to pay up or discontinue the plugin. Perhaps you could change the message to something like, "Thank you for trying S4u_Transformer. The trial period has ended. Please go to [your website] to purchase the a license."
- Global Moderator
- Name: Dave R
- SketchUp version: 2021
- License type: Pro
- SketchUp use: woodworking
by HornOxx » Fri Oct 24, 2014 12:36 pm
Sorry - how embarrassing to me!!  I didn´t even notice that this is a purchase-plugin. Regards to All
HornOxx
- Name: HornOxx
- License type: Pro
by hdpv » Fri Oct 24, 2014 4:13 pm
Thanks Dave!
hdpv
- License type: Pro
by Berserk » Fri Jul 14, 2017 7:39 am
This is incredible
Berserk
by pipinek » Sun Jun 16, 2019 12:13 am
To the Author (S4U).
Should it be any discount, upgrade price for the v1 users? If yes how can one apply it?
pipinek
- Premium Member
- Name: HansKloss
- License type: Pro
- SketchUp use: urban planning
by hdpv » Mon Jun 17, 2019 8:49 am
Hi Now,the update is free. Mail to me if you purchased it.
hdpv
- License type: Pro
by rv1974 » Thu Oct 31, 2019 11:38 am
Hdpv, Say I have multiple components, some of them have scale -1 (=mirrored) on some axis, some do not. Is there way to take only those with scale -1 and flip it to 1? Thank you
rv1974
- Name: rv1974
- License type: Pro
by hdpv » Mon Nov 04, 2019 9:08 am
Hi rv1974! s4u Transformer can't do it. You try this code: sel=Sketchup.active_model.selection axis=[0,5,10] s=sel.group_by{|e| e.transformation.to_a[axis.z]>0}.values[0] # you can change axis.x or axis.y sel.clear sel.add s
hdpv
- License type: Pro
by rv1974 » Mon Nov 04, 2019 9:59 am
Hdpv thanks for reply! I tried the code- nothing happens. what am I doing wrong? ------- Error: #<TypeError: wrong argument type (expected Sketchup::Entity or Array of Sketchup::Entity)> <main>:4:in `add' <main>:4:in `<main>' SketchUp:1:in `eval'
rv1974
- Name: rv1974
- License type: Pro
by hdpv » Tue Nov 05, 2019 8:21 am
First,You select all components.
hdpv
- License type: Pro
by rv1974 » Tue Nov 05, 2019 2:51 pm
IDK I select all and ... no magic happens Sometimes I have no reply in Ruby console, sometimes diffrent errors. In any case nothing flips to original
sel=Sketchup.active_model.selection axis=[0,5,10] s=sel.group_by{|e| e.transformation.to_a[axis.z]>0}.values[0] # you can change axis.x or axis.y sel.clear sel.add s Error: #<TypeError: wrong argument type (expected Sketchup::Entity or Array of Sketchup::Entity)> <main>:4:in `add' <main>:4:in `<main>' SketchUp:1:in `eval'
or
Error: #<TypeError: wrong argument type (expected Sketchup::Entity or Array of Sketchup::Entity)> <main>:4:in `add' <main>:4:in `<main>' SketchUp:1:in `eval' Error: #<SyntaxError: <main>: syntax error, unexpected ':', expecting end-of-input Error: #<TypeError: wrong argument ... ^> SketchUp:1:in `eval'
rv1974
- Name: rv1974
- License type: Pro
by hdpv » Wed Nov 06, 2019 10:44 am
Hi You change axis.z to axis.x sel=Sketchup.active_model.selection axis=[0,5,10] s=sel.group_by{|e| e.transformation.to_a[axis.x]>0}.values[0] # you can change axis.x or axis.y sel.clear sel.add s After,you use s4uTransformer with center origin and ratio scale x_axis: -1
hdpv
- License type: Pro
by rv1974 » Wed Nov 06, 2019 1:42 pm
 Wow! You are my hero! You see 3ds Max hates negative scale entities and it causes huge PITA. May I humbly ask you to shape it as .rb? And if you could merge with 'Reset Transformer' as one new script it'd be amazing. Many thanks for assistance.
rv1974
- Name: rv1974
- License type: Pro
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Plugins
