? [Question] - A Ruby Calculator ?
Re: ? [Question] - A Ruby Calculator ?
Postby Jim » Sat Nov 07, 2009 4:31 pm
A minor thing - require 'Sketchup' causes sketchup.rb to load a second time. Loading sketchup.rb again doesn't really break anything, but it does create a duplicate Ruby Console entry in the Window menu.
It should be - require 'sketchup' (small s)
Jim
Global Moderator
Postby Gruff » Sun Nov 08, 2009 2:53 pm
Thanks for the advice Jim.
I updated the Ruby_Calc Zip attachment with your change. For any who get this far there are two calculators in this thread.
1) TG_Calc.exe which is a Compiled Windows program. It has a number of features.
2) Ruby_Calc.rb which is just a simple calc with no features.
Both only work with Windows and require the win32ole.so file.
both work by pumping keystrokes into the SU environment.
Resistance is .... Character Forming. *Grin*
Gruff
Postby JClements » Fri Aug 15, 2014 2:15 am
I thought this worked. I tried the zip file contents in both SU2013 and SU2014.
I also tried installing via the SketchUcation Plugin Store.
User avatar
JClements
Premium Member
Premium Member
Postby TIG » Fri Aug 15, 2014 11:17 am
The script hasn't got require 'langhandler'
Add that after the require 'sketchup'
If an earlier loading script has already required it it might mask the lack of it.
However the line:
UI.menu("Tools").add_item($exStrings.GetString("Ruby Calc")) { rubycalc }
will also fail if $exStrings is undefined as it loads - as that might get setup by another script too.
Frankly I'd forget about the langhandler completely, and change it to read:
UI.menu("Tools").add_item("Ruby Calc"){rubycalc}
User avatar
Global Moderator
Postby JClements » Fri Aug 15, 2014 6:23 pm
Thanks TIG. Works now per your post.
If I wanted to add info to the taskbar below such as:
"[+] = Add, [-] = Subtract, [*] = Multiply, [/] = Divide, [%] return remainder, [**] = exponent, [ ( ) ] = group functions"
what would be the proper ruby format and where should it be inserted?
# Ruby Calc
# by Gruff
# Oct 29th 2009
# Many thanks to a4chitect for the win32ole section
# Ruby Calc is a simple SketchUp for Windows calculator.
# Feel free to hack and wack it.
# Since it is run as a loose procedure rather than a class
# it does not kick SU out of the currently running tool
# Bind the Menu Item 'Ruby Calc' to a short cut key
# For ease of use. (I use Alt-Q)
require 'sketchup'
require 'win32ole'
def rubycalc
prompt = [""]
default = [" "]
input = UI.inputbox prompt, default, "Ruby Calc"
fanswer = eval input[0]
sanswer = fanswer.to_s + "{ENTER}{ENTER}"
# Create an instance of the Wscript Shell
wsh = WIN32OLE.new('Wscript.Shell')
#Try to activate the Sketchup window:
if wsh.AppActivate(' - SketchUp Pro') || wsh.AppActivate(' - SketchUp')
wsh.SendKeys(sanswer)
else
puts "Impossible"
if( not file_loaded?("ruby_calc.rb") )
add_separator_to_menu("Tools")
UI.menu("Tools").add_item("Ruby Calc") { rubycalc }
file_loaded("ruby_calc.rb")
User avatar
JClements
Premium Member
Premium Member
Postby Dan Rathbun » Sat Aug 16, 2014 5:57 am
v 2.0.0 cleanup by Dan Rathbun : 16 Aug 2014
  1. Module wrapped in Gruff::RubyCalc
  2. Method renamed: Gruff::RubyCalc::command()
    • statusbar help text displayed during input
    • evaluation rescue wrapped with retry
    • exits for empty input and cancellation
  3. Tweekable text placed in module constants
    I'm not here much anymore. But a PM will fire email notifications.
    User avatar
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby Dan Rathbun » Sat Aug 16, 2014 6:12 am
    Gruff has not logged in to SCF for a year and 4 months. Is he OK ?
      User avatar
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby JClements » Sun Aug 17, 2014 2:43 am
      Thank you for your help, Dan and TIG.
      User avatar
      JClements
      Premium Member
      Premium Member
      Postby turbodizayn » Wed Nov 29, 2017 9:27 am
      Hi! Does it work in SU2016 ? I have a message, " Could not activate SketchUp application window."
      turbodizayn
      Postby Dan Rathbun » Sat Dec 02, 2017 1:51 am
      turbodizayn wrote:Hi! Does it work in SU2016 ? I have a message, " Could not activate SketchUp application window."
      I just tested version 2 of "ruby_calc_2.rb" in SketchUp 2016, and this works.
      Version 2 is in this post:
      viewtopic.php?f=180&t=22660&view=unread#p535117
      What is "it" you refer to ?
        User avatar
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        by Ad Machine » 5 minutes ago
        Ad Machine
        Robot
        Previous
        Return to Developers' Forum
        cron
        Who is online
        Users browsing this forum: No registered users and 5 guests
        Visit our sponsors:
