[Plugin] Flattery papercraft tools
• Page 3 of 3 • 1, 2, 3
Re: [Plugin] Flattery papercraft tools@jbb
You have a typo in the update. It no longer works in <v14 You have added vertecies = Set.new --> vertecies = Set.new when it should be vertecies = Set.new --> RUBY_VERSION.to_i < 2 ? vertecies = Set.new : vertecies = Sketchup::Set.new I'll correct it and add it to the PluginStore later... TIG
Re: [Plugin] Flattery papercraft toolsOh? Sorry, I must have mixed up the files...
Re: [Plugin] Flattery papercraft toolsI've just added v1.0.2 files to the PluginStore [previously it had linked to the author's site where the incompatible file still resides].
If the original author [who still has full credit] wants to remove it let us know. He is also free to take the corrected version and use it on his own site if he wishes... Under the clear terms of the (c) notice at the top of each of his files, he allows changes and reissue, provided his (c) is kept intact - which it is... TIG
Re: [Plugin] Flattery papercraft toolsCan anyone please help me? On my old laptop flattery worked just fine. Now WIN8 , SU2013 version and installed flattery, all worked correctly but I just can't export the drawing. I click save but it wont appear in the folder. Also tried SU8 but didn't work neither.
Re: [Plugin] Flattery papercraft toolsI copyed the file into the extension folder, but it doesn't show up on the menu bar on SU2014. Anyone could help me out?
Thanks! kind regards, Magnar Totland Re: [Plugin] Flattery papercraft toolsWhat do you mean you "copyed [sic] the file into the extension folder"?
Did you just download the .rbz file and copy it? And what extension folder? Did you place the .rbz file into the Plugins folder? If so, that's not the correct way to install plugins/extensions. Find the .rbz file and remove it back to Downloads or the desktop. Open SketchUp and go to Window>Preferences>Extensions. click on Install Extension, navigate to where you put the file, select it and choose Open. Continue with the installation. You should then see the toolbar for it under View>Toolbars. Etaoin Shrdlu
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: [Plugin] Flattery papercraft toolsPlease complete your SCF User Profile, we don't know your OS or SUp version.
We can offer more targeted advice if you had... Most Plugins are available in the PluginStore: http://sketchucation.com/pluginstore?pln=Flattery The RBZ archive can be automatically installed with any SketchUp >= v8 using Preferences > Extensions > Install.... button... If you installed the RBZ version of the SketchUcation PluginStore toolset, then you'll be able to AutoInstall from the PluginStore without even worrying about the RBZ download - every step is doe automatically... Don't forget that most Plugins are 'free', so carping on about inadequacies is not constructive... Perhaps the author is a code whizz who can't explain himself well?... but you as an erudite chap could help by sharing knowledge and make the work a better place - rather that making people feel bad. Post a useful tip, like, "Flattery Tip: After selecting and indexing, you'll need to deselect and reselect before 'unfolding'..." TIG
Re: [Plugin] Flattery papercraft toolsI need some help;I've tried installing this plugin and cant seem to get it to work. (Sketchup (Make) 2014, Win8). following the procedure: Window>Preferences>Extensions. click on Install Extension, navigate to where you put the file, select it and choose Open. the toolbar doesn't show up and upon closing/reopening Sketchup I get the error dialog:
Error Loading File C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/toolbar.rb Error: #<SyntaxError: C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/tabtool.rb:238: syntax error, unexpected ':', expecting keyword_then or ';' or '\n' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/tabtool.rb:276: syntax error, unexpected ':', expecting keyword_then or ';' or '\n' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/tabtool.rb:287: syntax error, unexpected ':', expecting keyword_then or ';' or '\n' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/tabtool.rb:291: syntax error, unexpected keyword_end, expecting end-of-input> C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in `require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in `require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/toolbar.rb:24:in `<top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in `require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in `load' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery.rb:28:in `register_extension' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery.rb:28:in `<top (required)>' Re: [Plugin] Flattery papercraft toolsWhere did you get the version of Flattery that you downloaded? It shouldn't be installed in the Tools folder but from the error messages, it appears it has been installed there. It would appear you have an outdated version. You should first navigate to the tools folder and delete any all files related to Flattery and start from scratch with a fresh copy. The correct version is in the Plugin Store. Use it to auto-install the plugin correctly.
Re: [Plugin] Flattery papercraft toolsThanks Dave R,
just tried that. deleted all instances of Flattery and auto-installed from inside Sketchup. The toolbar still does not appear. Window>Preferances>Extensions shows it in the active list. but no joy. The Plugins Manager shows it as loaded, however the Extensions Manager show it as Disabled. Re: [Plugin] Flattery papercraft toolsWhat does the following mean exactly?
How did you install it? Did you download a fresh copy? Or did you use the Sketchucation Plugin Store to install it? What happens when you attempt to enable it in the Extensions Manager? Is there an entry for Flattery in the toolbars list? If you close SketchUp and reopen it, are there any messages? What are they? Etaoin Shrdlu
Re: [Plugin] Flattery papercraft toolsI've deleted every instance I could find ad will try again.
I installed with the Sketchucation plugin store; searched the plugin store within Sketchup, click autoinstall, well, I was doing it as I was typing a blow-by-blow and lo and behold it worked. Don't know what I did differently this time. I've tried at least a dozen times to install it both manually and thru the plugin store. Hmm, dunno. At least its working now. thanks for your help! Stan Re: [Plugin] Flattery papercraft toolsCan you specify material thickness with this plugin? Thanks Re: [Plugin] Flattery papercraft toolsI tried following the instructions provided by http://www.pumpkinpirate.info/flattery/
which did not result in a toolbar. The email address provided does not work either. My wife found the answer that works. I could not get along without her! Go to the Menu Window> Preferences> Extensions> Click the Install Extensions... button Browse to your downloads folder Select the file Flattery_v1.0.2.rbz Click the Open Button Follow the usual "Yes, OK, I Agree" type options. Now Flattery is correctly installed and you will have the menu bar you expected. I Hope this helps you too! Re: [Plugin] Flattery papercraft toolsOr you could just use the Sketchucation Plugin Store to install it automatically and not have to go through all those steps.
It already works with SU2015. Etaoin Shrdlu
Re: [Plugin] Flattery papercraft toolsAs DaveR says, it was fixed sometime ago to work with the newer SketchUp versions [ i.e. >= v2014 ].
The original download on the author's website is old, and therefore incompatible with anything > v2013. I do not believe the author is supporting this tool any longer... However, under the terms of the tool's (c) license I updated it in April this year, and so that version of it is available from the PluginStore [but not elsewhere!]... http://sketchucation.com/pluginstore?pln=Flattery TIG
Re: [Plugin] Flattery papercraft toolshi
please find after a small animated explanation. ( done with GifCam : http://blog.bahraniapps.com/gifcam/ ) Chri Re: [Plugin] Flattery papercraft toolsI have installed your Flattery plugin and it is doing a great job unfolding designs. However, when I click on the SVG button, I get the pop up menu to select where to save the file but the svg file type does not appear in the lower box. In fact, no file type appears. Any idea how I can fix this?
Re: [Plugin] Flattery papercraft tools@BRG
I assume you have the latest version from the PluginStore, which has some compatibility issues fixed: The SVG export works fine for me. Have you got a 'Flattery' group? It must be the only thing selected when you activate the Flattery-SVG exporter ? Then you get the export-dialog with a named.svg etc... TIG
Re: [Plugin] Flattery papercraft toolsHi
I've translated the Flattery plugin Doc in French look at the Download link for PDF J'ai traduit le plugin Flattery en Français voir le lien Download pour le PDF Download: https://1drv.ms/f/s!AFl38Tl2pzx-g-gv Re: [Plugin] Flattery papercraft toolsWhat I downloaded was only a .php file, not .rbz as normal plug-ins are.
Please help.I got 'pluginserv_joomla.php', did I do anything wrong?? Re: [Plugin] Flattery papercraft tools
Evidently you did do something wrong. If you'd followed TIG's link it would have taken you to the Sketchucation Extension Store page for Flattery. When you get there, click the Download button. You might need to sign in first. When you click Download, the RBZ file should download to your computer. Why not install the Sketchucation Extension Store? Then you can let it automatically download and install extensions and help you keep them up to date when they get revised. Etaoin Shrdlu
Re: [Plugin] Flattery papercraft toolsSketchUcation Extension Store
Yes, this is a helpful tool that aids in keeping extensions/plugins updated after install. The use of plugin Sets is another helpful tool. Thank you SketchUcation team!
Re: [Plugin] Flattery papercraft toolsI use SU 2017 and Flattery doesn´t work well. I can unwrap but I cannot change edges and add tabs too.
Any idea what I must do wrong?
Who is online
Users browsing this forum: iniciusv, JulianLaConcha, ledoods, vanegvila, wellingtondsf07 and 10 guests
