[Plugin] FreeDXF Importer
• Page 3 of 5 • 1, 2, 3, 4, 5
Re: [Plugin] FreeDXF Importer v0.57 (2012-09-01)Hi -
I am having trouble getting the plugin to run. I'm on a Mac running OSX 10.6.8 and Sketchup 8.0. I downloaded the latest version v0.57 and put the .rbz file in my plugin folder. There are lots of other plugins there, though no others of type rbz. When I start Sketchup, there is no FreeDXF Importer item in the Plugins menu. I am probably missing something really simple -- I'm a pretty new Sketchup user. Any help is much appreciated! Thanks! Bill Re: [Plugin] FreeDXF Importer v0.57 (2012-09-01)MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
Re: [Plugin] FreeDXF Importer v0.57 (2012-09-01)Doh - thanks for that, it's all working now! Bill Re: [Plugin] FreeDXF Importer v0.57 (2012-09-01)I have sketchup 8.0 free and have put this .rbz ruby into the plugins folder but its not appearing when I load sketchup. Incidentally, nowhere does it let you unzip it either? Am I missing something? i'm trying to import a vector file from scan2cad
kind regards Re: [Plugin] FreeDXF Importer v0.57 (2012-09-01)
To use RBZ packages you need to install them using the Install Extension feature in SketchUp: http://www.thomthom.net/thoughts/2012/0 ... z-packages Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] FreeDXF ImporterI bumped the version to 0.7.1. For v0.7.0 I must have uploaded the wrong file. If your version says anything other than v0.7.1 then please update.
Thanks. Hi
I agree, and I am working on it. Hi
![]() Then after the import is done [inside its own 'container' [definition]], you can simply apply an XYZ scaling transformation to the container's entities, based at the ORIGIN. A simple lookup list of 'scaling_factors' based on inches to feet/m/cm/mm is all that is needed to make a single 'transform_entities' ? You could also ask for the 'Keep-CAD-Origin?', or NOT. If not, then the entities can be transformed [translated] by the vector from their bounds.min back to the ORIGIN - i.e. the instance's insertion-point... TIG
Re: [Plugin] FreeDXF ImporterJust updated to v 0.8.0 with a dialog for selecting the import units.
Re: [Plugin] FreeDXF Importerhey jim,
i'm trying to import a dxf file but it comes in scaled to inches. as an example i tried to import 1000x1000 square with a unitless autocad setting dxf and it came to sketchup 2540 x 2540 mm. i've choosen mm when the pop up displayed. do you think something was wrong? Re: [Plugin] FreeDXF Importer1000 'units' read from a DXF file are taken as 1000 inches.
When you 'scale' it 'to mm' the 1000" --> 25400mm NOT the displayed 2540mm ? BUT looking into your DXF file... the box's edges are actually 100 'units' long! NOT 1000, so therefore it ought to produce 2540mm when 'scaled' as you showed ?? If your DXF says something is 100 'units' long [taken as 100" as SketchUp's base-units are inches] and you tell it to scale it to 'mm' - then logically you will get something 2540mm long [which is 100" !] If you want to get it to assume the 100 'units' is actually 100mm then the scaling needs to be NOT 'TO mm' but 'FROM mm'. The scaling factor would then be: 100.mm / 100.inch which is actually 1/25.4 So 100 'units' --> 100" - which is then rescaled to be the smaller 'mm' dimension of exactly 100mm [100 / 25.4 = ~4" (3.93700787401574803") in base-units ] TIG
Re: [Plugin] FreeDXF ImporterI don't understand why should i scale imported drawing. I have nothing to do with inches, want to import like SU Pro. My base SU file always in cm or mm unit and always draw in Autocad unitless.
Finally my su file's unit is cm and I draw a 100 x 100 square in Autocad and I want to see it in SU as 100 x 100 cm. Is it possible with that plugin or not? Re: [Plugin] FreeDXF ImporterThis importer always takes the DXF length of 100 as 100".
Jim's latest update is intended to allow you to 'scale' the input to whatever units you desire. So if you choose "to-mm" then it currently applies a scaling factor to make 100 into 2540mm My point was that it should take 1/25.4 as the scaling factor 'from-mm' and therefore you'd get 100mm as your result. I'm sure Jim will address this shortly... ![]() TIG
Yes I botched the importer scale. It is now fixed and version 0.8.1 is available in the Plugin Store. Hi
Re: [Plugin] FreeDXF ImporterHey Jim, please don't mention it : )
But the same problem is here, I've attached the screenshot. I've also tried clean install, but no way. Re: [Plugin] FreeDXF ImporterI found it - this had to do with updating the options from the UI rather than incorrect scaling factors. Check for version 0.8.2 soon.
Re: [Plugin] FreeDXF ImporterJust today loaded and tried with Make 2014 on Win 7 x64. Does not work!
Removed Re: [Plugin] FreeDXF ImporterThen you must be doing something wrong, but as you've given no information about how it hasn't worked for you nobody can help.
Re: [Plugin] FreeDXF ImporterBox. Your right of course so here is the error info. SU reports on startup
------ Error: #<SyntaxError: C:/Users/Laptop/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Dxf_In_v2.2.rb:306: formal argument cannot be an instance variable ramFile.each do |@line| #search for entities @line by @line ^> ----- Thanks for any help. Maybe just using provious version of Google SU will be easier. Re: [Plugin] FreeDXF Importer
Sorry you are having difficulty. How did you install FreeDXF? What version did you install? The only supported download is from the SketchUcation Plugin Store. The most recent version is 0.8.7. In recent versions of FreeDXF this version number appears right in the Plugins menu. Is this what you see after installing? Hi
This error is not from FreeDXF - it is from a different plugin named Dxf_in. Hi
Re: [Plugin] FreeDXF ImporterThanks, still new to this and thought I installed the correct plugin. Works now.
Re: [Plugin] FreeDXF ImporterI'm also having trouble installing this plugin into Sketchup 2014. I may have the wrong version; I see above that the latest is 0.8.7, but in the filename I downloaded it's 0.8.2, which appears to have been created 2 months ago, and I can't find a more current version. Is "0.8.7" a typo? If not, is there a link to the newer version? I got it from the following link at the Sketchucation download store:
http://sketchucation.com/pluginstore?pln=freedfx The filename is freedfx_v0.8.2.rbz I pasted the file to the following folder on my computer, and restarted SketchUp: C:\Users\tom\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins When I try to find it in SketchUp, I don't see a "plugins" icon anywhere, and when I open Ruby console, nothing appears. Have I left out a step? Thanks in advance, Tom Tom Wootton
Re: [Plugin] FreeDXF ImporterThe latest is v0.8.2. You need to install the RBZ archive's contents, using Preferences > Extensions > Install... button... No need to mess on accessing your Plugins folder at all, for this kind of Plugin... Just 'AutoInstall' it... TIG
Re: [Plugin] FreeDXF ImporterSU 14.1.1282
FreeDXF 0.8.2 Win7 Pro Jim - when I open the plug-in I'm getting this empty dialog box. I tried reinstalling both the plug-in and SU14, no changes. Any suggestions? Re: [Plugin] FreeDXF ImporterOpen Internet Explorer > Safety > Delete Browsing History and empty the cache...
SketchUp uses IE for its web-dialogs, irrespective of your default browser. Sometimes the cache is messed up and needs clearing... Report back... TIG
That wasn't it. I deleted temp downloads, cookies, history, and tracking protection from IE, no changes. Did the same in Chrome (my default browser) just to be sure. Restarted SU and still have an empty dialog box when I call up the plugin.
Who is online
Users browsing this forum: chris_no_akumu, fred.dy, Hangarscope, mark blackburn, piter_sketchucation, Shefali00 and 20 guests
