[Plugin] FullScreen v5.1.1 (12 September 2021)
Thank you for the report laudhi.
I found and fixed it. Download the latest version of AMS Library.
thanks Anton_S,now everything is running smoothly without any problems with other plugins
i love the floating window....
3.6.0 Jan 29, 2014
- Figured out a way to keep all shortcuts working while the menu bar is removed. The fancy shortcuts sections and the show/hide menu bar option were removed. They are no longer required!
- Fixed the get screen resolution function in AMS library. Now, it will return the size of all monitors combined. This fixes an issue where the dialog could not be moved to another screen.
- Simplified and improved stuff.
Master Anton strikes again - thanks!
Thanks for this plugin Anton, it's arguably the number 1 plugin for me as it enables me to quickly clear my screen for online client presentations. The only thing is could the floating black dialog be made smaller?
Thank you, CadFather!
I'm glad you like it. I've been thinking about making another collapsible on top, that would collapse/uncollapse all other collapsibles. Perhaps this feature could be available in the next release. Thanks for suggestion!
@unclex said:
and i can not dare try the Menu Option, if i close it, how reopen it ??
Yes i'm encountering with the problem It's bad to me, 'cos I've already hidden everything in the window include the menu bar, then, how can I bring it back again?? I've got nothing to do with my Sketchup now even if I reinstalled both SU and this plugin. Please tell me.
Didn't you download the latest version? Use F12 to toggle the menubar and it would be a good idea to assign more shortcuts, as well. For example, SHIFT-S could be used to toggle statusbar, SHIFT-D could be used to toggle toolbar containers, and F11 could be assigned to toggle fullscreen. The latest version automatically assigns F12 shortctut at the begging of use.
If you don't have any shortcuts, and made it so all elements hide at start, do the following:
- run regedit.exe
- If using SU6-SU8, locate to HKEY_CURRENTUSER/Software/Google/Sketchup[n]/, otherwise locate HKEY_CURRENTUSER/Software/SketchUp/SketchUp[n]/
- Delete the Plugins_ams folder. This will reset all plugin data.
Next time, have assign shortcut to reset.
@vicxp0518, I updated the plugin so the menubar remains visible on start, under certain conditions. Download the latest version 3.7.3 and your good to go.
this is wonderful plugin
my shortcut is almost full
request if can future updates
add Full Screen Button toggle on / off for toolbarthank you again
Really nice plugin, Anton. Thank you.
I have a proble when running this plugin(latest version) on sketchup pro 2014,it shows like the photo below. Can anyone tell me what should I do to fix it??? it would helps,thats really a useful plugin.
It seems
Sketchup.register_extension
is undefined. Scroll down to line 33 and add :: in from of the wordSketchup
, save, and test.
It should look like this:
::Sketchup.register_extension @extension, true
If it doesn't work then your SU was modified, or some files were deleted. Try re-installing SketchUp and see what happens.
Windows 8, SU 2014. There's no Plugins folder to unzip ams_Lib_1.0.8.zip so I extracted the files to the folder Tools.
Fullscreen still doesn't work.
How to I get rid of the annoying popup stating, Download ams_Lib? Or remove the plugin?
Thanks in advance.
@archieA The plugins folder is located in %appdata%\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
This plugin is not a standalone plugin. It requires AMS Library. Here is the link: http://sketchucation.com/forums/viewtopic.php?t=55067#p499835 Extract AMS Library in the plugins folder as well.
Thank you. I got it working on SU 2014 on Windows 8. Easy enough when it's clear. I've started using it using F12 to toggle. Great plugin!
Hi Anton
You have done a great job
Is-it difficult to create a file ( rb for example ) to change the commands language ?
I have done a french example of what i mean on the next pictures .Bye
Chri
Very well, I'll add the description to first post.
Yeah, its quite difficult to translate webdialogs.
I heard Aerilius created a method, that could translate the Webdialog, so we'll see.
Thanks for request.
Hi Anton,
I don't think this plugin is 2015 ready or is it?
